Wheel weight - Ford Ranger
Results 1 to 2 of 2
    Oct 2007
    Default Wheel weight - Ford Ranger
    I recently changed the wheels on my Ranger Wildtrak. Went from 265/60R18 to 255/70R16. Both had the same model Continental tire on. Made quite a difference in the ride quality and fuel consumption.
    This was expected as the sidewall was now 11.1% higher (178mm vs 160mm), and the circumference was 1.3% less (2398mm vs 2433mm).
    When I swapped them back I decided to weigh them. 26kg-ish for the 16inch and just above 31kg for the 18inch, that is 20% more unsprung weight per wheel.
    I am guessing the ride quality and fuel saving is as much related to the weight as to the other factors.
ID:	529074Click image for larger version.
    1997 Suzuki Samurai (Coily)
    1.5 inch spring lift
    30x9.5 BFG KM2 muds
    4.16 RockLobster
    2017 Ford Ranger Wildtrak 4x4
  2. The Following User Says Thank You to kingjake For This Useful Post:
  3. #2
    Thanked: 97
    Default Re: Wheel weight - Ford Ranger
    Very interesting, I recall reading in one of the American magazines that a bigger wheel vs tyre combo (lower sidewall) is normally lighter so good to see that this is not always the case.
    Andrew
    2010 Mazda BT-50 3.0 CRDi
