outdoor-fishing-rod-light
Results 1 to 20 of 25
    Sep 2012
    Thanked: 88
    Default outdoor-fishing-rod-light
    Has anyone used one of these whether camping, fishing or for other purposes?
    Are they worth getting and if so are there any other suppliers that sell them?
    Looking for one that has a longer rod extension and higher watt.
    https://www.4x4andmore.co.za/product...hing-rod-light
    Mar 2016
    Thanked: 1813
    Default Re: outdoor-fishing-rod-light
    We used one at camp.
    Was brilliant
    Sep 2012
    Thanked: 88
    Quote Originally Posted by Oppies3800 View Post
    Was brilliant
    Where did you source yours?
    Mar 2016
    Thanked: 1813
    1st Outdoor - 021 948 2006
    Stikland
  5. The Following User Says Thank You to Oppies3800 For This Useful Post:
    Thanked: 27
    Different models/brands available. Same concept/parts - Stand, Telescopic fishing rod, light - (different power outputs), cigarette plug and clamp set. With some, also a remote. Can switch on/off, dim with quite a number of settings between full power and off.
    Works brilliantly! Light could be direct as you wish. With the rod extended to max level it is nice to pitch tent and set up camp, thereafter it could be lowered and dimmed without light polluting the neighbouring stands (they would not appreciate it).
    Should you need an emergency light, just use it without the pole.
    Bought at Zambezi China mall in Pretoria for R495.00. similar to https://www.banggood.com/12V-500W-Te...r_warehouse=CN
  7. The Following User Says Thank You to JP vd Merwe For This Useful Post:
    Thanked: 290
    Just a point that confused me at 1st. The 500W is the equvalent power and the power actually used. A real 500W would not be able to run from a 12V 7Ah battery and these lights do for 8 plus hours.
  9. The Following User Says Thank You to ekkekan For This Useful Post:
  10. #7
    Apr 2014
    Thanked: 13
    Someone on this forum posted a place in Alberton that had them for around 350. It was last year sometime, i will try and look for the thread.
  11. #8
    Thanked: 1103
    I am a bit confused, on the website it says 360 degrees of light. Yet it looks directional and a previous poster said it won't bother your neighbours?
    Defender 2.8i
  12. #9
    Feb 2017
    Thanked: 7
    I have the exact same product you are enquiring about bought from the same supplier. I have blown 2 remotes and can only use it on the brightest setting ( without the remote in line) this is a pitty as the remote is very handy to dim the light to appropriate level and also to switch on and off. I am looking for a remote that will work with a higher amp rating. It is my opinion that the remote supplied with this product is rated too low hence the reason for it blowing within the first couple of munites of usage. Otherwise, the light really works fine.
    FORD RANGER XLT 3.2 4x4 AUTO (Face Lift)
  13. #10
    Thanked: 27
    #8m Albertvl, light source is LED, stuck onto one side of Alu plate, therefore cannot be 360 deg. However, there are different models with different shapes and different output specs, also some with two plates of LEDs.
    The rod, being telescopic, does obviously not have to be extended all the way. It appears that there are different rod lengths available as well, and could also be angled depending the direction of the “stand”.
  14. The Following User Says Thank You to JP vd Merwe For This Useful Post:
  15. #11
    Thanked: 1103
    Quote Originally Posted by JP vd Merwe View Post
    Methinks the website copy might be incorrect.
    Defender 2.8i
  16. #12
    Dec 2013
    Pietermaritzburg
    Thanked: 79
    US$ 10.99 each if you buy a batch of them
    (about R158.00)
    Pajero Sport 2013 3.2 A/T
  17. #13
    Roodekrans
    Thanked: 140
    I have not used this person on FB or know him, but pricing looks reasonable
ID:	529380   Click image for larger version.
  18. #14
    Feb 2012
    I use them very cool. Got it from bushgearrsa.co.za. Click image for larger version.
  19. #15
    Mar 2019
    Plumstead
    Quote Originally Posted by MariusvdM View Post
    I bought mine from Soundtech in Ottery Centre for about just over R300. Same box, with remote control.
  20. #16
    Dec 2012
    jhb
    They were available at the OUTDOOR-X show last year may, which is happening this year 1st, 2nd June in Meyerton on the farm MALONJENI.
  21. #17
    Sep 2012
    Thanked: 88
    Quote Originally Posted by bushbasher86 View Post
    Where are they situated? I can't seem to locate them on the web.
  22. #18
    Mar 2016
    Thanked: 1813
    https://bushgearrsa.co.za/12-volt-area-lighting-kit/
  23. #19
    Feb 2012
    It's our side business I can help. We based in Randburg. If you would like you can contact me on WhatsApp 064 512 5903
  24. #20
    Feb 2012
    You can WhatsApp me on 064 512 5903 I can help
