Amarok Auto Electrical "glitches"
Results 1 to 5 of 5
    Melkbosstrand
    Thanked: 172
    Default Amarok Auto Electrical "glitches"
    Need a bit of guidance here...
    This morning as I pull out of the garage, the bakkie seemed to momentarily cut out and then restart... almost like someone flicked a light switch off and then on again... weird.
    But then as I drove around the corner, the whole dashboard seemed to turn off... ABS and TC lights came on, then nothing for about a second, then back on again... concerning.
    This ABS/TC light issue then happened briefly (flickered) 2 more times on the drive into town...
    A previous thread makes mention of a dirty ABS sensor... could this be the issue? Just concerned about the dash lights too.
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
    Jan 2010
    Harrismith
    Default Re: Amarok Auto Electrical "glitches"
    My dog chewed on the wires. Had the same effect. It could be a rat or mouse as well
    Thanked: 13556
    Nope, it is rodent season. Check for rodents inside the engine compartment, it will be very obvious: rat poo and bite marks on wires and pipes.
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    Can be sooo many things.
    bad earth
    bad connection atbthe battery
    fuses connector at the battery
    ignition switch
    body control module
    etc etc.
    very hard to diagnose those type of things but looks like a main power supply gets interrupted.
    It basically reset the ignition as if you have turned it off and on.
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
  5. The Following User Says Thank You to Stephan van Tonder For This Useful Post:
    Melkbosstrand
    Thanked: 172
    No rodents...
    Quote Originally Posted by Stephan van Tonder View Post
    bad earth
    ignition switch
    body control module
    etc etc.
    Thanks... was a shot in the dark
    Need to get underneath and just double check everything... Thought I heard a knock as I pulled out the garage (been storing stuff under the car) so might have loosened something.
