Gas bottle for Echo 4
Results 1 to 10 of 10
    Jun 2008
    Fish Hoek
    Thanked: 15
    Default Gas bottle for Echo 4
    The older Echo trailers have a gas bottle compartment that is only 29 cm deep. Which presents a problem since all new generation gas bottles seem to be at least 32 ++ cm high.
    Even my old generation 5 kg bottle with regulator is higher that 29 cm.
    My options seems to be :
    1) find a gas bottle that is less than 29 cm high with regulator - does any anybody know where I can find that ??
    2) Fit an inline regulator - does that exist and where do I find it ??
    3) Fit a high pressure gas stove - any suggestions ??
    I need some advice please.
    Thanked: 134
    Default Re: Gas bottle for Echo 4
    Quote Originally Posted by TheoP View Post
    Echo can refit the new plastic bumpers that take the new gas bottles. Or you go look at cash crusaders for the the old type bottles that fit (cheaper option).
  3. The Following User Says Thank You to vnielsen For This Useful Post:
    Thanked: 98
    Look at the Pabar gas bottles, they make both a #7 and #10 size bottles which has very similar dimensions as the old Cadac bottles. The new Chinese made Cadac bottles rated in kgs do not fit the older brackets.
    Geoff Craig
    '98 Suzuki Samurai - Sami the Samurai
    '09 Toyota Fortuner 3.0 D-4D 4x4 (M)
    '10 Conqueror Comfort
  5. The Following User Says Thank You to Wave For This Useful Post:
  6. #4
    Thanked: 642
    Quote Originally Posted by vnielsen View Post
    Same predicament here - any idea of the cost of the bumpers?
    Tx
    Jul 2007
    Pretoria (PvR)
    I have two Echo bumpers that I bought for spares.It is the newer ones that are made for the larger bottles.I bought it for R 1500.00 second hand.If I get my money back you can have them.
    Albert Gravett
    Isuzu KB6 3.0 D-Teq D/C 4x4 Auto
    ORRA Call Sign B66
    Thanked: 642
    Hi Albert
    Thanks - does it look like this more or less?
    Jul 2007
    Pretoria (PvR)
    Yip, dis presies hulle.Jy kan my bel by 08twee 87nege 049vier
    Albert Gravett
    ORRA Call Sign B66
    Thanked: 642
    Dankie Albert - kontak jou more of so. (Net eers 'n ander hekkie oorsteek)
    Thanked: 134
    Quote Originally Posted by AlbertG View Post
    If Pieter doesn’t take them, I will.
    Thanked: 642
    Hi Albert
    Many thanks but I won't be taking up your offer unfortunately.
