Recording phone calls - Page 2
Results 21 to 40 of 40
    Swakopmund
    Thanked: 441
    Default Re: Recording phone calls
    No recording apps work on Android 9. The only way to record the other party is to have the call on speaker.
    Quote Originally Posted by MarcR View Post
    Thanks for that info... that is a deal breaker for me. I'll have to keep an eye open to see how it gets fixed.
    Don't worry Marc, that information above is incorrect. As stated further above, call recording still works.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
    Thanked: 1876
    Quote Originally Posted by albertvl View Post
    To whom do you submit written consent to?
    Just have it available if needed. Piece of paper stating you give your consent to recording of voice in discussions of which you are part. Signed and dated by yourself and a witness.
    <insert all your cars, your wife's car, your kids pram model and your underpants size here - apparently it adds value and boosts you ego>
  3. The Following User Says Thank You to George For This Useful Post:
    OdM
  4. #23
    Thanked: 1876
    What app gets to create APIs that doesn't exist? Would love to test it also.
  5. #24
    Dec 2009
    Thanked: 61
    Most reviewers on Google Play store for ARC confirms that recording of the other party on Android 9 is not working.
  6. #25
    Swakopmund
    Thanked: 441
    The app called Call Recorder works on my A8 with Android 9. Only function which doesn't work anymore is identification of the caller.
    2012 FJ Cruiser
  7. #26
    Dec 2006
    Thanked: 80
    n Android Pie they only blocked the call identification for call recordings, e.g. you can still have calls recorded, but you would then have to manually add the caller's name or number, which previously was done by the app.
    Call Recorder also works without problems.
    I
    I use ACR as well, initially downloaded from Google Play. When they decided to stop the Caller ID, I downloaded same app from Galaxy store and all back to normal again
    Landcruiser 79 Series D/Cab 4.2L Diesel
    Bush Lapa Miskruier (no: 34)
  8. The Following User Says Thank You to Sebastiaan For This Useful Post:
  9. #27
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 879
    Quote Originally Posted by Sebastiaan View Post
    Strange, caller ID still works on my S7 Android 8.0.0 ?
    Chev Aveo and Atos and Polo.
  10. #28
    Thanked: 1876
    I've got that one too (and tested all the others). None works on my non-rooted S9+
  11. #29
    Dec 2007
    Thanked: 92
    For some reason ACR works on my non-rooted Note 9 - Pie .
    '08 Fortuner 4x4
    Metalian Maxi
  12. #30
    Thanked: 416
    From the horse's mouth... from the ACR support page...
    https://nllapps.com/apps/acr/support.htm
    Android 9/Pie
    We would like to inform our users that there will be no call recording workaround on Android 9. No 3rd party call recording app will be able to do so.
    However, it may be possible to record from the internal speaker with some clarity on some phones such as Huawei or Pixel phones.
    https://nllapps.com/apps/acr/android9.htm
    Android 9 does not support real two call recording. However, there is still good news...
  13. #31
    Dec 2007
    Thanked: 92
    Android 9 does not support real two call recording. .
    Guess I'm lucky that mine still works then !
    '08 Fortuner 4x4
    Metalian Maxi
  14. #32
    Thanked: 201
    If you have a Hauwei phone you can record calls courtesy of a Hauwei app. It was witten, apparently, as part of Hauwei's EMUI (Their user interface layer which sits atop Android) but never distributed, for whatever reason. Anyway, one can download the APK and install it, it's called HWCallRecorder.apk.
    Works perfectly on my Hauwei, and integrates with the dialler app so it even has a setting to enable automatic call recording. It then stores the recorded audio in the voice recorder app, and names each recording as the contact name that was called (or the number that was dialled).
    Alas I think it only works on Hauwei phones, though.
    *** ADMIN REMOVED ***
  15. #33
    Thanked: 416
    Quote Originally Posted by 4x4 wannabie View Post
    Did you install it from Google play or the Samsung store?
    Having asked that, if the api is not available in Android 9 PIE, can you confirm your Android version?
  16. #34
    Thanked: 1876
    For the exact wording refer to the RICA act, chapter 2 sections 4(1) and 5(1).
  17. The Following User Says Thank You to George For This Useful Post:
    OdM
  18. #35
    Oct 2014
    Tzaneen
    Thanked: 26
    I use Call recorder - works perfectly on ANDROID 9.
    2017 Amarok V6 HiLine+
    2014 Amarok 4Motion Auto (Sold)
    1983 Suzuki SJ410V
    2019 Nissan X-Trail 2.5 Tekna CVT
    1985 Suzuki SJ413
    Mazda Cx7 Turbo(Sold)
    Fiat 500 1400MTA (Tweety)
  19. #36
    Dec 2007
    Thanked: 92
    Yes, installed ACR from Playstore.
    Android version : 9 with 1 April 19 security patch.
    '08 Fortuner 4x4
    Metalian Maxi
  20. The Following User Says Thank You to 4x4 wannabie For This Useful Post:
  21. #37
    Thanked: 1876
    There's a couple of apps called Call Recorder. Please specify which one (perhaps add the developer name). Would like to test them all again - perhaps they found a sneaky work around.
    I've currently got this one, which doesn't record incoming sound (unless on speaker) - Automatic Call Recorder by developer "recorder & smart apps"
  22. #38
    Thanked: 416
    I am not surprised that the issue seems to be fixed... but at how a major change like that went in so quietly... can you imagine a change like that in the Apple environment? I find this quite unsettling.
  23. #39
    Sep 2014
    Thanked: 86
    I have previously had call recorder apps that worked perfectly.
    With the new updates, mine also only records the other person's voice if I talk to them on speaker. I have tried a few apps and all of them are the same, they don't work anymore.
    I have previously (and still have) Automatic Call Recorder from Appliqato that I can only use with the speaker.
    Also interested in any other recording app that has found a way to work around Android 9.
    I think for those who's apps still work as before, you are indeed very lucky as I don't think that is the norm.
    2018 Ford Ranger XLT 4x4
  24. #40
    Thanked: 416
    So, the issue is clearly not resolved yet!
