How do I fix this LED Stop Light Array
Results 1 to 16 of 16
    Gaborone, Botswana
    Thanked: 1029
    Default How do I fix this LED Stop Light Array
    This High Mount Brake Light started to flicker early this week. Since this morning it is dead. There is still 12V on the plug when pressing the brake pedal.
    There are only 4 components on the pc board. 6 LEDs on the other side. What can go wrong?
    The Data Sheet : https://www.lumileds.com/uploads/99/DS29-pdf
    Kobus
    Nissan
    Langebaanweg
    Thanked: 908
    Default Re: How do I fix this LED Stop Light Array
    If you have a very fine soldering iron, try to re-do the joits.
    It might just be a dry joint.
    Gaborone, Botswana
    Thanked: 1029
    I checked the joints under a magnifying glass. Cannot see any thing suspect.
    I will give it a go. It may just be the problem.
    Kobus
    Nissan
    Thanked: 11280
    Did you check voltage on the PCB? If you give it 12vdc now from croc clips, does anything happen?
    Thanked: 847
    I had the same problem, after soldering, checking etc I bought a new on, OEM on ebay.co.uk..Was cheaper than stealers and I did not want my daughter pulled over by "police" on some dark road for an iffy tail light..
    Gaborone, Botswana
    Thanked: 1029
    It is the High Mount brake light in the rear window. Legally no problem if it doesn't work.
    I prefer it to be functional.
    Could not find one online yet. 2003 RAV4.
    Kobus
    Nissan
    Gaborone, Botswana
    Thanked: 1029
    I connected it to a battery.
    This is what I measure. See picture.
    Battery = 12.8V
    Between segment 1 and 4 : 12.5V The Red and Black dots is where it is connected to the PCB
    Between segment 1 and 3 : 11.1V
    Between segment 1 and 2 : 0V
    Between segment 2 and 3 : 0V
    Between segment 2 and 4 : 0V
    Between segment 3 and 4 : 0V
    Kobus
    Nissan
    Thanked: 847
    Go to stealers, get the part number and then search on that number. Send me the number and I'll see if I can get one in the UK for you. Probably be a lot cheaper than in SA
    Gaborone, Botswana
    Thanked: 1029
    @NewLandy
    I looked up the VIN/Chassis at www.toyodiy.com. It shows RAV4 model ACA21W-AWPNH. The brake light on their parts list is not even close to what I have.
    Searching Toyota Mid Brake lights, I saw something that uses the same PCB.... but the plastic assembly is different. See Part no 81570-AC030 at Amazon +- US$85. Add shipping and 30% customs duty on vehicle parts.
    Kobus
    Nissan
    Thanked: 847
    I can't find it either, not even a used one from an Avalon.
    May 2019
    Harrow
    Battery = 12.8V
    Based on these values and the circuit diagram, I’d check the first two LEDs to see if they are open circuit.
  12. The Following User Says Thank You to peterten For This Useful Post:
  13. #12
    Thanked: 413
    As the LEDS work as 2 in // and then 3 pairs in series it does seem like a break in one of the 2 pairs and that the last pair is fine due to the 11.1V reading which indicates they are conducting otherwise you would have also got 0V. The 11.1V also shows the 2 resistors are fine as well as the diode next to them.
    You could perhaps de solder each pair of LEDS and test in the diode scale if they conduct and solder back if fine. Observe the polarity when desoldering.
  14. The Following 2 Users Say Thank You to ekkekan For This Useful Post:
  15. #13
    King Williams Town
    Thanked: 973
    Also check for broken tracks but it sounds like an led has blown.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  16. #14
    Wilderness
    Thanked: 1106
    Buy a strip of red LEDs from your local China shop and insert. R30.00
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  17. The Following 2 Users Say Thank You to Pieterk For This Useful Post:
  18. #15
    Gaborone, Botswana
    Thanked: 1029
    I bought some red LEDs. Will see what I can do.
    Kobus
    Nissan
  19. #16
    Gaborone, Botswana
    Thanked: 1029
    The ones I bought (post above) did not work.
    I needed Super Bright LEDs. The only way was a LED tail light for a truck/trailer. Took a few off and replaced the blown ones on my setup. (I needed some help with this )
    Everything is working again.
    Kobus
    Nissan
  20. The Following 2 Users Say Thank You to KobusDJ For This Useful Post:
