Amarok 2L vs V6
Results 1 to 20 of 33
Thread: Amarok 2L vs V6
    Thanked: 51
    Default Amarok 2L vs V6
    Hi
    I know there has been a thread with quite some chat about the differences between these two as well as some pro's and con's, some by guys who have owned both, but I have searched and can not find the thread. If anybody knows the thread name, please post it here.
    If anybody who has owned both is in a mood to give their comments please do. I realise power wise there is no comparison, but I'm interested in differences in fuel general consumption, handle, feel, and just how they differ in day to day use.
    Much appreciated.
    Thanked: 4092
    Default Re: Amarok 2L vs V6
    Quote Originally Posted by idea40 View Post
    Hi
    Much appreciated.
    As I've said on the other thread. The 2l Bi-TDI auto Amarok is the best DC on the market in general all-round use. I will buy one any day of the week.
    But then I will always look at the V6 with envy. So V6 it will be
    Gert Grobler
    VW Touareg V6 Tdi Escape; Land Cruiser 105
    Bush Lapa Boskriek 816
    Dec 2018
    It's simple, if you not towing anything heavy get the 2.0 otherwise v6 for the win!
    Vanderbijlpark
    Thanked: 793
    I owned a 2L and have drive my dad's V6 extensively.
    Beside the power, which is a massive difference, the V6 is much more refined and less noisy, especially at cold start ups.
    Fuel consumption is more or less the same as the 2.0, but quite a bit better on the highway.
    The biggest advantage for the V6 is while towing, it really is effortless.
    Negatives:
    1st gear could have been longer, it really is way too short.
    Induction noise is higher than the 2.0, but then it is a nice noise, so no problem.
    For most people the 2.0 would just fine, as it did for me in the 4 years I had it. But, the V6 is just so much better. Overtaking at speed for example, is simply in another class. The way it goes from 100 to silly speeds is astonishing. The fact that it doesn't use more fuel is also a plus. Only downside is the higher price, but if you can afford it, just get it and be done.
  5. The Following User Says Thank You to clubbie For This Useful Post:
    Thanked: 51
    Thanks for the replies so far. Itching...
    Thanked: 51
    Are you guys sure the V6 fuel consumption is similar to the 2L auto and even better on highways..?
  8. The Following User Says Thank You to idea40 For This Useful Post:
    May 2007
    Thanked: 18
    The 3.0 is definitely not heavier than the 2.0 on fuel. If anything, it does better than the 2.0, especially at higher speeds.
    I don't agree with the comments that the 3.0 is more refined than the 2.0. I agree that outside the vehicle, it sounds a lot better. But from the inside, the 2.0 wins when it comes to refinement. I never felt any vibration from the 2.0l engine. With the 3.0, it is not uncommon when in gear to feel a slight vibration through the steering and seat when idling in gear. The gearbox (especially downshifts), is harsher with the 3.0.
    The ride quality of the 2.0 is much better than that of the 3.0. The 3.0 is much bumpier over uneven surfaces and add bigger wheels (17" vs 19") to that and the ride quality of the 3.0 is disappointing (for Amarok standards at least).
    Two friends with 3.0's had warned me that I'll experience a vast improvement in engine performance and fuel consumption once the engine has been run in. That is absolutely true. The 3.0 was drinking diesel during the first 1,000 kms like crazy and the performance was disappointing. But after 5,000 km, it is a totally different story.
    The seats of the 3.0 Ultimate are fantastic. The best seats I've ever had in a vehicle were those in the Range Rover. The Ultimate's seats are almost as good.
    The pulling power of the 3.0 is amazing.
    Bottom line is that despite the awesomeness of the 3.0, it confirms what an excellent vehicle the 2.0 is.
    The 3.0 has an interesting quirk - the engine is sometimes noticeably noisier under light acceleration than other times. The engine sound chances, almost like a pinging petrol engine. It comes and goes and there is no noticeable pattern as far as I can tell. A friend experiences the same with his 3.0.
    2019 Amarok 3.0 Extreme Auto with Roll-n-Lock tonneau cover.
    Gone: 2013 Amarok 2.0 Auto
    2018 Audi SQ5
    Gone: 2015 Audi S8
  10. The Following User Says Thank You to 949BFN For This Useful Post:
  11. #8
    Vanderbijlpark
    Thanked: 793
    Quote Originally Posted by 949BFN View Post
    My dad fitted his 17s from his 2.0 to the V6, and it drives almost exactly the same. It is slightly harder, but you are comparing a new car to a 3 year old one. His engine is also smoother than what my 2.0 was.
    One negative I forgot about, is the irratic idling when stationary. It will sometimes go from 800 to over 1000rpm. Apparently this is normal.
  12. #9
    Kathu
    Thanked: 3005
    The orgasm in a v6 is 10 minutes longer than in a 2.0l.
    Have seen them both offroad no comparison. The v6 is one mean dune machine. Crawling rocks you cannot beat low down torque. The v6 have more of that.
  13. The Following User Says Thank You to grips For This Useful Post:
  14. #10
    Thanked: 51
    the orgasm in a v6 is 10 minutes longer than in a 2.0l.
    ;d;d;d
  15. #11
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    Quote Originally Posted by clubbie View Post
    it's the DPF cleaning cycle.
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
  16. #12
    Vanderbijlpark
    Thanked: 793
    Ah, OK.
  17. #13
    Thanked: 4092
    I've not noticed this in the Touareg.
    Gert Grobler
  18. #14
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    Nys, despite the engine in your treg being roughly similar - it is a number of years earlier , some of the emissions laws has changed in between and there was the whole diesel gate. So how stuff was implemented in your touareg and how it is implemented in the current amaroks is quite different. Often there are a lot of differences even just between how stuff is done between one range of engines form say a golf to a polo just because of the platform they are in even though they share a basic motor.
    You can't simply say hey I have a 3l v6 it must do everything the latest version of them does in a different platform.
  19. The Following 3 Users Say Thank You to Stephan van Tonder For This Useful Post:
  20. #15
    Mar 2012
    Hi
    Much appreciated.
    Buy the V6 had both, yes thirstier but you will get 10km/L if you keep to the speed limit Roof racks and bigger wheels make it heavier on fuel and influence the top speed
  21. #16
    Thanked: 180
    You seem to be quite clued up when it comes to VAG engines. My V6 Rok has a slight (and annoying) whine between 1000 and 1200 rpm. Also happens when in park and I wind it up, so not the gearbox. Should I be worried and have it checked out?
  22. #17
    May 2016
    Thanked: 3098
    Just for interest sake - the VAG 3.0 TDi engine is capable of much more than it provides in the current vehicles:
    The most exciting news on the engine front however is the release of a diesel-powered S4 TDI, which get a 255kW, 700Nm version of the VW Group’s 3-litre TDI engine. This oil-burning TDI sprints from zero to 100km/h in just 4.8 seconds, according to claims.
    Lag-free acceleration is assured by an electric compressor, which forms part of the vehicle’s 48-volt main electrical system.
    https://www.iol.co.za/motoring/lates...iesel-23257761
    2006 VW Touareg V10 TDi
  23. #18
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    Quote Originally Posted by Makaira View Post
    I always hate commenting on noises on forums etc as one cannot gauge where it comes from, how loud it is etc. etc and so to say if it worth worrying about etc. is impossible. But if you have any doubts pop past a VW dealer and let them listen to it. Or see if you can find another owner and compare to his.
  24. #19
    Thanked: 242
    I own a 2.0 tdi Tiguan and 3.0 tdi Touareg:
    I am a 3 liter slut...... I confessed your honour
    It is such a magnificent engine with so much flexibility, brilliant towing engine....
    Find the solutions, not the problems.
  25. #20
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    I have said for years and years it is one of the WAG group's best engines ever. I really love them.
