Broken bushwing arm
Results 1 to 20 of 39
    KB
    Default Broken bushwing arm
    Has any one experienced a bushwing arm on a Bush Lapa breaking in a windstorm? See attached photos.
    The next arm also has a hairline crack on the weld!
ID:	528272Click image for larger version.
ID:	528273Click image for larger version.
    Plett/Paulshof
    Thanked: 832
    Default Re: Broken bushwing arm
    Quote Originally Posted by frans k View Post
    That must have been some storm! Were you in Mozambique?
    I have been in 2 huge storms and no damage. Speak to BL directly.
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Baobab 1873, Fusion 17 boat-Yamaha FT100hp 4st.
    KB
    Fairly mild storm at Cape Vidal where the camp sites are quite protected! Have spoken to Bush Lapa directly.
    Apr 2008
    Secunda
    Thanked: 261
    That looks like a pretty good straight "break" to me my last altercation with a grinder and aluminium had the same result
    Never heard or seen something like this on a BushWing
    2013 Toyota Hilux 3.0D4-D 4x4
    Bush Lapa 810 Miskruier
    ORRA Call Sign: X85
    Gerbers Alu Canopy
    Howlingmoon RTT
    Apr 2009
    Thanked: 215
    that is not possible for a 1 piece tube.. that had to be 2 pieces joint together somehow, and eventually failed.. interesting
  6. The Following User Says Thank You to D-tox For This Useful Post:
    May 2012
    pretoria
    Thanked: 69
    Why would they join square tubing? Cost cutting? Unbelievable for such an upmarket product!
    Plett/Paulshof
    Thanked: 832
    Quote Originally Posted by eloffmare View Post
    Earlier model may have had different design. The other tube does not look like it has a join.
    May 2011
    Thanked: 521
    Badly made joint between 2 pieces of square tube. Agree, would not expect such cost cutting and shoddy work on what is supposed to be a prime product.
    '89 LR 110 V8
    FOURWAYS GARDENS
    Thanked: 396
    Sitting on my hands, it is only fair for the factory or factory representative, Kooskop to respond
    Take Care
    Stay frosty (Be alert at all times: We Live in a war zone)
  11. The Following User Says Thank You to tgwinduna For This Useful Post:
    Plett/Paulshof
    Thanked: 832
    Quote Originally Posted by Mike N View Post
    Why jump to conclusions here? Who knows why this happened? Why it was joined? Did the OP buy this BL new or secondhand? Was it maybe repaired for some or other reason? I love the way people judge before having all the details.......If I am wrong and this came from the factory like this then I apologise.
  13. The Following 3 Users Say Thank You to BruceHun For This Useful Post:
  14. #11
    Thanked: 2908
    That is BL 94 so one of the firsts. I am confident BL will come to the party here. OP please keep us updated.
    VW Touareg V6 Tdi Escape
    Bush Lapa Boskriek 816
  15. #12
    May 2016
    Thanked: 2898
    That looks like a butt weld, ground down, without chamfering the ends first.
    (if so, I think the cost of the joint is more than the cost of a new length of tubing).
    2006 VW Touareg V10 TDi
  16. #13
    Feb 2013
    Thanked: 299
    I had the back arm break where it is welded to the hinge section. When I refer to the back arm, it is the single arm that runs above the Miskruier door when the wing is open. Namibia's roads is not always your friend... Took the Miskruier in to BushLapa (Andre at the time) who had it re-welded.
    Bush Lapa Miskruier: B116
  17. The Following User Says Thank You to HJB01 For This Useful Post:
  18. #14
    May 2011
    Thanked: 521
    If it looks like crap and smells like crap it most probably is crap.
    '89 LR 110 V8
  19. The Following 2 Users Say Thank You to Mike N For This Useful Post:
  20. #15
    May 2015
    Krugersdorp
    Thanked: 6
    It looks as if that is a fused join. It has been welded. The discoloration in the galvanising or cold galv process does show. It has been slightly ground down. How old is the arm? I would say that with that join, it has lasted for a very long time. If metal stays stable for a long period of time where it was joined, it should last a very long time. With our lifestyle and it being towed and twisting, expect failure to take place. It is part of life.
  21. #16
    May 2012
    pretoria
    Thanked: 69
    Quote Originally Posted by HJB01 View Post
    Road should not break any arm when it is in the stowed position.
  22. #17
    Helderkruin
    Thanked: 389
    Die square bar is aan mekaar gesweis dit is al hoe dit so mooi kan breuk
  23. #18
    Jan 2010
    Thanked: 3642
    Looking at the number of the van, no 94, it was made in early 2013. Ours is 87 and the last or second last that was completed in 2012.
    So the wing on no 94 of the first 10 wings made probably and the design have since changed multiple times. We did not take a wing when we bought because it was still sort of in prototype stage. We upgraded to.a wing 2 years ago and ours have no welds on the arms and have stood up to massive winds.
  24. #19
    Thanked: 1166
    Jip Christa, early days in wing design that has been in 6+ years of use on this van. Still not something that should happen. I look forward to feedback from the OP on interaction with BL.
    I've heard of a few where the 1st one above the door was bent and then broke when trying to bend it back. Aluminium does not like that.... Those are however due to operating error when opening the wing before popping the roof. The nut on the gas shock then hooks the arm and forces it upwards as the roof opens. Been there when I had the 1st prototype of the wing on B8. I fortunately noticed in time before any damage occurred. New owners are given a demo and there are instructions as well as video clips to help anyone who purchases new or 2nd hand BL's.
    I'm sure the other +- 1,800 BL's out there have nothing to worry about....
    Toyota FJ Cruiser
    BMW F800GS
    When in doubt, paint it black
  25. #20
    KB
    I have again spoken to the guys at BL. The arm will be re-welded. Thanks.
  26. The Following User Says Thank You to frans k For This Useful Post:
