Fitting a Provent Catch Can to a diesel
Results 1 to 9 of 9
    Oct 2007
    Wichenford, United Kingdom
    Default Fitting a Provent Catch Can to a diesel
    I am thinking of fitting one of these to our 2012 Jeep Grand Cherokee. Has any one fitted on to their diesel as it is supposed to help with economy plus keep the engine clean. See https://youtu.be/f4_dW98oJ1A Here is the video for fitting the unit into a post 2011 Jeep Grand Cherokee. https://www.youtube.com/watch?v=UPBPNN5RGlU
    2012 Jeep Grand Cherokee Overland Summit CRD chased by a 2018 Buccaneer Cruiser twin axle caravan.
    Default Re: Fitting a Provent Catch Can to a diesel
    The only economic saving is going to be salvaging the oil that would normally be drawn into the intake and burnt.
    I'm in the middle of making a catch can for my D2, because at 360k it has a blowby problem and the inlet manifold is always wet inside with oil.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Centurion, Pretoria, SA
    [QUOTE=JohnnoK;4141816]The only economic saving is going to be salvaging the oil that would normally be drawn into the intake and burnt.
    Plus the turbo pipes will not be softened and eventually fail at some stage due to the effect of the oil.
    See comment here: showthread.php/314793-Turbo-Booster-pipes?p=4139943&highlight=#post413
    SOMETIMES I WAKE UP GRUMPY,
    Aug 2011
    Brackenfell
    I have been looking into this for some time now. Noticed on Youtube the Ausies rate this as a decent upgrade.
    Which brand/type is better/more cost effective?
    Have seen these at our local "racing" supply shop
    Jul 2016
    Paarl
    I would also be interested to know if anybody has used the Provent product. Considering fitting one to my Pathfinder but it looks like I am going to have to have it shipped from Oz/US. Installation looks pretty straigforward, and looks more stock than the blingy items I have been able to find locally.
    Paarl
    If you do enough googling, there was one of the Isuzu's that had a catch can fitted as standard...
    I bought one (the local ones mentioned) for my C180 as the old lady is starting to breathe and makes the engine bay look awful...however I haven't been able to fit it as there is no space in the engine bay...
    1996 Discovery 1 (SOLD)
    2001 Mercedes C180 (SOLD)
    2012 Nissan Xtrail 2.0 (Weekend Wagon)
    2010 Kia Sedona 2.9Crdi (Written off)
    I'm making one for my Disco.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Paarl
    You should know by now Johnno...pictures or it never happened
    In some material I have read, it appears that a correctly-installed Provent might allow service intervals to be extended, especially on older IDI diesel engines.
    The idea is that if you can create sufficient vacuum in the crank-case, then the dirty gasses leaking past the rings will be drawn through the catch-can and either filtered out or returned to the gas stream.
    I would want to look at oil analysis before actually extending service intervals myself though...
