How to remove silicone from windscreen
Results 1 to 20 of 38
    Default How to remove silicone from windscreen
    Evening all
    I have been struggling with mounting my Garmin DriveAssist in my vehicle- the suction cup for the windscreen really has not been up to the task when we have been offroad. So I tried using silicone sealant, as recommended in some threads here on the Forum... epic fail basically as it all fell off on our latest trip, and Iím now trying dash mounts and will probably try a RAM mount. But meanwhile, I have a really annoying disc of old silicone adhesive in mid-windscreen. Tried peeling it off, careful scraping with a sharp blade, nail polish remover... no luck. Can anyone tell me of a magic product or method to get rid of the silicone?
    Thanks in advance!
    Sep 2016
    Default Re: How to remove silicone from windscreen
    Maybe apply heat? Heat gun or hairdryer to soften it.
    Harties
    Bostik and others make a silicon remover.
    Freely available at hardware stores.
    If you make a noise or need music in the bush or on the beach, youíre missing the point.
    Nigel
    A razor blade. Or a Stanley blade. Last little bit with your thumb. Silicone is extremely stable and doesn't react to anything. But, if it is a cheap one, like Home, or Bath or the likes, it will react to a solvent like thinners, petrol, acetone.
    Just be careful. There is a film inside your windscreen. When you scratch, keep that blade extremely shallow. Try to not make it dig deeper than the silicone.
    Uniglide
    +27 zero eight 2 four 95 9252
    I will get me to a Builders as soon as possible- thank you!
    Nov 2011
    Langebaanweg
    Quote Originally Posted by Roberto Betta View Post
    I would be careful with heat. If concentrated it might lead to cracking.
    84' Land Rover Defender 110 V8 4-speed Hardtop (Meisiekind) Sold after 12 years of fun and hard work
    Aug 2017
    Silicone is fairly stable at increased temperatures, so heat is not effective.
    Silicone remover is the best bet, otherwise acetone and a blade.
    Nov 2011
    Langebaanweg
    Yes I understand. I was referring to the glass.
    Aug 2017
    I am agreeing with you, but also indicating that it would be.a waste of time.
    Jul 2007
    Putfontein, Benoni
    petrol will affect most silicone sealers. If that fails pop past you local goldwagen and get this
    https://www.liqui-moly.com.au/produc...spray-aerosol/
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
    Jan 2017
    A heat gun is going to do zip to it. Silicone is bitch to get off. Evwn that silicon remover only works on very cheap ones. Wd40 or acetone also helps a bit. Its not an adhesive that glues things together it fails dismally as a glue as far as I am concerns and makes a mess that takes hours to het off. Dont know why it keeps being recommended to stick things together. Ita meant to seal around glass and showers etc. You will have more luck sticking that holder to your windscreen with bostic contact and it will be easier to remove when you want to take it off as acetone dissolves it.
    Wartburg
    Quote Originally Posted by Fishing1 View Post
    Was the recommendation for better adhesion not silicone spray on the suction cup rather than silicone sealer? Agreed on the utility knife suggestion with shallow angle, at least to get most of it off.
    Thanks for all the input. I have scraped quite a bit off with a sharp utility blade, without scratching the glass so far. So the bulk is off. I will try some petrol tomorrow, then off to find silicone remover if still have a problem.
    Jun 2012
    this, petrol work by far the best it makes the silicone go gummy and easy to remove.
    edited to add, you may need a couple of applications. wipe the silicone with a petrol soaked rag, give it a couple of minutes and then scrape off the silicone that has gone soft. Repeat as often as is required to get through all the layers.
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
    Jan 2017
    Definitely going to try petrol next time thanks
    Jan 2015
    pretoria
    Just be carefull wirh petrol and thinners and stuff....if it gets on your dash there might be a problem. I would use benzine, harmless to your dash but will soften the last layer silicone to scrape of with your nail. Then windolene to clean your windscreen .
    joburg
    3M make a very thin double sided tape, when peeled it's almost like a jelly, sticks like you can't believe. My Garmin is stuck onto dash with a pop socket (so surface area just bigger than a R5) and hasn't budged for months.
    Gaborone, Botswana
    Quote Originally Posted by sparewheel View Post
    It is Removable Gel Tape.
    When it gets dirty, wash with water and it is good as new.
    Kobus
    Nissan
    Apr 2017
    PUMULA
    Agood old razor blade is the best. Stanley blade is good, just watch the edges and scratching. the round blade of a leathermans works, just need to scrape more. (can't scratch the glass). (remember the windscreen is curved so scrap carefully.)
    followed up with a damp cloth with meths, just to finish it off..
    chemicals will do damage and heat will not work and will do damage. Watch the dash and ceiling.
    Current off-road vehicles: *** Great family accommodation. See Facebook, Google maps and airbnb. Wild Wind Ranch/Mkulu Kei
    * 1975/8 SHREK Land-Cruiser FJ40 DIESEL P/U, BFG 31x10.5 muds. 2 x 1.6 ton tirfor winchs
    * 1994 Land-Cruiser J70 DIESEL P/U, my truck recovery vehicle. 15000 warn winch. And 3.5ton tirfor winch. Back full of appropriate sized recovery gear. BFG31x10.5 muds
    * 2014 Land-Cruiser LX V8 76 DIESEL STATION WAGON, BFG's 285 all terrain
    * 1988 HILUX TOYOTA 4x4 D/C.
    FOR SALE
    * 2011 HILUX 4X4 P/U, BFG 31x10.5 all terrain
    * 1999 PAJERO 3.5 V6 Mitsubishi (sorry not a Toyota), BFG 31x10.5 all terrain
    * 2006 FORD ranger 2.5 diesel. 4x4, (what was I thinking, also not a Toyota!) I have a spare 5000 warn winch I might fit.
    * 2011 Isuzu bakkie 4x4
    * FIONA - Rhino Yamaha 660 4x4. Warn winch. Mud tyres
    * 4x4 trailer, 1987, BFG all terrain
    * GSA 1200 BMW ADVENTURE LC 2018, the closest motorbike to a land cruiser
    * A Massey Fergusson 375 tractor. Not BFG's and not a 4x4
    Mar 2011
    Walker Bay
    Never liked those suction cups. My Garmin is attached to a friction mount which I can move anywhere on the dash. Good even on corrugated roads.
