How to remove silicone from windscreen - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 38 of 38
  1. #21
    Thanked: 44
    Default Re: How to remove silicone from windscreen
    Interesting- how does it work? Post a picture if possible please?
  2. #22
    Mar 2011
    Walker Bay
    Thanked: 1066
    They come in all shapes and sizes and to fit the various devices: Must be compatible with the device.
    https://www.garmin.com/en-US/search/...iction%20mount
    https://www.ebay.com/sch/i.html?_fro...unt+for+garmin
  3. #23
    Apr 2012
    Bela Bela
    Thanked: 226
    Quote Originally Posted by sparewheel View Post
    3M make a very thin double sided tape, when peeled it's almost like a jelly, sticks like you can't believe. My Garmin is stuck onto dash with a pop socket (so surface area just bigger than a R5) and hasn't budged for months.
    I have been in Pretoria East for the past 2 days and no hardware store that I went to knew of this tape. Where did you get it? If possible please post a picture of the packaging.
    Thanks.
    Pete
    ADVENTURE BEFORE DEMENTIA
  4. #24
    Gaborone, Botswana
    Thanked: 1123
    3M and Scotch
    Kobus
  5. The Following 3 Users Say Thank You to KobusDJ For This Useful Post:
  6. #25
    Jan 2015
    pretoria
    Thanked: 244
    Ek gebruik daai rooi 3m by die werk, daai 2way tape klou Ů koek hou.
  7. The Following User Says Thank You to chris dippenaar For This Useful Post:
  8. #26
    joburg
    Thanked: 442
    It's not normally in hardwares, a customer of mine who worked for "Sellotape" gave me a roll a few years ago, so I don't even know cost. I treat it like gold, but persevere and find some you won't be sorry.
  9. The Following User Says Thank You to sparewheel For This Useful Post:
  10. #27
    Aug 2017
    Durban or Centurion
    Thanked: 1248
    Just look for the high strength double sided tape at Builders or similar places. They have different brands, and usually all have red backing tape.
    Example: https://www.builders.co.za/Fixings-F...iABEgIZyPD_BwE
    I usually get the Sellotape brand.
  11. #28
    Gaborone, Botswana
    Thanked: 1123
    The wife showed me her roll of "No More Nails" tape. It is like the pic below. Not sure if is the removable gel type.
    Kobus
  12. #29
    Apr 2012
    Bela Bela
    Thanked: 226
    The specs for the No More Nails state "Maximum holding power can be reduced at higher temperatures". I think it may not work too well if using it to attach a GPS bracket to the windscreen.
    Pete
  13. #30
    Gaborone, Botswana
    Thanked: 1123
    Quote Originally Posted by petewill View Post
    I don't think the No More Nails is the same as the 3M Gel tape.
    Kobus
  14. The Following User Says Thank You to KobusDJ For This Useful Post:
  15. #31
    Thanked: 44
    An update: I got busy with petrol and a rag, followed by more scraping with a blade, and am very happy to report that the beastly silicone is GONE.
    Thank you 4x4 community!
  16. The Following User Says Thank You to jcole For This Useful Post:
  17. #32
    Thanked: 978
    Petrol dissolves silicone. That is why you cannot seal something with silicone if it holds petrol or if petrol runs through it.
    Malcolm van Coller - retired 2013 but remained in Johannesburg (maybe will look at moving south, Robertson or Wellington type of town, once the wife retires)
    Ex 2011 Conqueror Supra II
    Ex 1995 Sani 3.0 V6 Exec
  18. #33
    May 2013
    when my GPS kept falling off the windscreen I stuck some heavy duty Velcro to the bottom of the mount and some on the dash and it has never come off again while driving not done any serious off road though
  19. #34
    Nigel
    Thanked: 2257
    Quote Originally Posted by travoski View Post
    The serious corrugation take no prisoners. I def want to find some of that 3M double sided stuff.
    Uniglide
    +27 zero eight 2 four 95 9252
  20. #35
    Sinoville Pretoria
    Thanked: 570
    Black (suction cups) absorb light and heat, i wonder whether a white suction cup would not stay on longer. I am now trying to treat cause not symptom.
    Obviously, using a cup not affected by heat would not require glue of sorts.
    I agree, cell phones etc falling from windscreens irritate me endlessly. Have bought a light blue (did not have much option) suction cup with a magnetic base and it seems to work well
    Henk Pretorius D4 3,0 SDV6 HSE
    EX AFRICII SEMPER NOVUS
  21. #36
    Feb 2017
    Ramsey
    Thanked: 86
    For windscreen problems, marks, adhesives etc., I find my local windscreen replacement depot a mine of products and advice. Once I came back to my car to find the rear view mirror had come off and all my attempts failed miserably. All the usual 'sticks anything to anything' adhesive carried warning NOT for windscreen use. Called by the windscreen folks and the job was done in minutes. They also had cleaners too.
    But for my Garmin I use one of these. Easy to demount when renting a car and proved to be Van Zyl's and East Africa proof.
    https://www.amazon.com/ChargerCity%C.../dp/B00PBHI5P4
    Albert
    Progress might have been alright once, but it has gone on too long.
  22. #37
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    You will find the gel tape is serious strength versions at hobby shops that sell model helicopters.
    Like aerial concepts
    http://aerialconcepts.co.za/
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
  23. #38
    Thanked: 2110
    Acetone kills silicone, we often use it here in the workshop, give it a go
    Henk
    Follow us on Facebook
