T-Max x power HEW-12500 winch replacement part urgently needed...
Results 1 to 2 of 2
    Jan 2016
    Fochville
    Default T-Max x power HEW-12500 winch replacement part urgently needed...
    Hi...
    I have a T-MAX X POWER HEW-12500 winch installed on my Amarok... but the connector is broken... who is a T-Max agent in South Africa? Or where can i buy parts? The part i need is the socket on the winch side.. to which the remote plugs in...
    I have attached photos from the instalation manual...
    Part No. 732900. 6A-11
    Description CJPT 16H-5X
    Thanks in advance...
    J.P
ID:	552732   Click image for larger version.
ID:	552733   Click image for larger version.
    Sep 2017
    Randburg
    Default Re: T-Max x power HEW-12500 winch replacement part urgently needed...
    4x4 Megaworld are the Tmax agents in SA I believe.
