Advice on fitting fender flares
Results 1 to 10 of 10
    Sep 2012
    Thanked: 78
    Default Advice on fitting fender flares
    I got myself a set of fender flares for the Hilux.
    They come with double sided tape but that did not manage to hold on.
    I've heard some say you can use Sikaflex. Will Sikaflex be ok? If so, which one?
    Any suggestions on what else I could use?
    Its not about how fast you are but about how quick you get there...
    Thanked: 12812
    Default Re: Advice on fitting fender flares
    The industrial strength double sided tape should work.
    Please bear in mind that any decent adhesive that can hold a fender flare on properly will NOT be easily removed from the paint later....
    The Sikaflex acrylic adhesive should work, but it has a long curing time, not sure how you're going to keep the flares in the right place in the meantime, unless you again use some double sided tape as a temporary adhesive.
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    https://zaf.sika.com/content/south_a...1a001sa02.html
    Looks like sikaflex 552AT is the one for you or sikaflex fix.
    if you have any doubt speak to their head office in Isando and they will tell you which is the right one.
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
  5. The Following User Says Thank You to Stephan van Tonder For This Useful Post:
    Jun 2013
    Thanked: 2591
    Have a look for VHB (very high bond) tape. That will work.
    BMW R1200R
  7. The Following User Says Thank You to Stranger For This Useful Post:
  8. #5
    Apr 2019
    Cape-town
    Thanked: 12
    I used double sided tape and put some blobs of sikaflex for the extra grip . If you decide to take the flares off a petrol soaked cloth and elbow grease will remove the sikaflex without damaging the paint
  9. The Following User Says Thank You to Rayhau1 For This Useful Post:
  10. #6
    Thanked: 2092
    A bit of obvious advice, make sure that all grease and wax is removed from the surface you intend sticking on. Car wax forms a layer that does not come off easily and stuff does not stick to it well
    Henk
    Follow us on Facebook
  11. The Following User Says Thank You to hbannink For This Useful Post:
  12. #7
    Sep 2012
    Thanked: 78
    Quote Originally Posted by Rayhau1 View Post
    thanks. Thats what I am planning to do. Which sikaflex did you use and where would i get it? I see that builders only has one variation of it.
    I got the VHB tape. It's holding to the body but not too well to the flare itself.
  13. #8
    Apr 2019
    Cape-town
    Thanked: 12
    Quote Originally Posted by Die$eL View Post
    I bought it a builder's, black and silver tube, for automotive use. Code 221 color black. I used 3m tape about 2mm thick and about 10mm wide
  14. The Following User Says Thank You to Rayhau1 For This Useful Post:
  15. #9
    Sep 2012
    Thanked: 78
    Thanks!!! Will stop at builders today
  16. #10
    Sep 2012
    Thanked: 78
    Got it sorted. Thanks for the advice.
    Used 3M tape with Liqui Moly sealant. Its holding great.
    Here is how I held it in place while the sealer dried. Lol
  17. The Following User Says Thank You to Die$eL For This Useful Post:
