disco 2 alarm
Results 1 to 18 of 18
Thread: disco 2 alarm
    Nov 2016
    Cape town
    Default disco 2 alarm
    hi hoping someone can help me
    i have a disco 2 td5 and my alarm was disabled by LR service about 2 years ago then 3 days ago after locking the car with the key the alarm reactivated and since then i cannot get the fobs to work neither the eka code as holding the key in the turned position for 5 seconds gives me no response at all
    please any info would be much appreciated
    thanks
    Oct 2015
    Romania/Hungary
    Thanked: 114
    Default Re: disco 2 alarm
    Hi, i might be able to help but i need some more info, first of all do you mean that the disabled alarm started to work on it's own i mean it yells with the sounder and flashing hazards or it's just immobilised without sound and doesnt crank while the red LED is on? ... also when you lock then turn the key to unlock do all the doors unlock then? was a tester plugged in before that?
    2000 Discovery Td5 ES manual, tuned
    Hawkeye v.6, Nanocom EVO,
    VDM UCANDAS, oscilloscope
    i DON'T ANSWER TO TECHNICAL QUESTIONS IN PM'S
    ALL MY ADVICES ARE BASED ON MY OWN EXPERIENCE AND MY WAY OF UNDERSTANDING THE DESCRIPTION AND OPERATION OF SYSTEMS... I'M NOT A LAND ROVER SPECIALIST JUST AN ADDICTED ENTHUSIAST
    Nov 2016
    Cape town
    Quote Originally Posted by sierrafery View Post
    Hi thanks for the reply
    Yes it started to work like never before the sounder and hazards goes off if I unlock with the key and all doors unlock
    No a tester hasnít been plugged in since LR turned alarm off about 2 years ago
    So Iím really confused
    Oct 2015
    Romania/Hungary
    Thanked: 114
    In this case as long as you don't get the EKA sequence start audible warning when you turn the key to UNLOCK unfortunately you have to replace BCU and for that complex programming is needed with dedicated diagnostic tool.
    Nov 2016
    Cape town
    Ok thanks will try and find a replacement bcu
    Regarding replacing the bcu will it be just plug and play and maybe just the fobs that will need to be re added
    Thanked: 1574
    There will be a need for some Nanocom or similar input. The BCM will need the vehicle VIN added to it as well as programming the fobs into the new BCM.
    If you are still stuck at the end of June ( I hope not, for your sake), I will be back in SA and can plug you into my Nanocom.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  7. The Following User Says Thank You to JohnnoK For This Useful Post:
    Nov 2016
    Cape town
    Thanks a lot will let you no if I manage to sort it out
    Think I might need to invest in a machine
    Oct 2015
    Romania/Hungary
    Thanked: 114
    I respect your helpfulness but it seems that you are a bit confused about the bolded part or i misunderstood you, i'm sorry... here it's about a Discovery 2 which has a BCU(not BCM) and no need for any VIN thing just fob programmin,. enhancement's instrument settings and make the engine ECU lear the security code.. Good luck
    Thanked: 1574
    Thanks for clarifying that.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Nov 2016
    Cape town
    Hi all
    So itís finally been diagnosed as a faulty bcu
    Is it possible to have it replaced with a second hand one and if so is there anyone that could assist with that or a referral as too who I could call on would be much appreciated
  12. #11
    Oct 2015
    Romania/Hungary
    Thanked: 114
    You can fit second hand BCU but as i said in post #4 a dedicated diagnostic tool for D2 is compulsory cos it needs complex programming made by someone who know what's about. If the approach is not the proper one you can end up with it immobilised then you can bin it or pay more than it's price to be unlocked by specialists
  13. #12
    Thanked: 1574
    If you are up to it, you can use my Nanocom to do the job.
    Read up on it and give me a shout next week. I get home from work on Saturday.
    Bring beer for rental...
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  14. #13
    Thanked: 559
    THAT is just plain scary!!!
    ENJOY!!!
    Ettienne
    196? S2B FC "Over Lander" Camper
    1980 Range Rover
    2002 Defender Td5 D/C
    2004 Disco Td5
  15. #14
    Nov 2016
    Cape town
    Hi thanks I will definately be taking you up on that offer
    Will be in contact next week
  16. #15
    Feb 2012
    Thanked: 58
    Question on EKA codes.
    Was given a code of 7047 by Land Rover as the EKA code for my Disco 2. Does 0 mean I have to turn the key 10x times?
    When turning the key the horn starts beeping at certain turns.
    Gary W
    Discovery 2 (Td5) Best 4x4xfar
    BMW GS 1200 Adventure. For when the road ends...
    Jurgens XT120..home away from home.
  17. #16
    Oct 2015
    Romania/Hungary
    Thanked: 114
    7074 can't be a correct EKA code, .. are you sure it's not D ? then it would be 13 as EKA numbers can be in hexadecimal system too, 0 alone is not an option, for 10 must be 10 or A.
  18. #17
    Feb 2012
    Thanked: 58
    Not sure. This is number given by LR. Will call another dealer and see if it is the same.
    Gary W
  19. #18
    Feb 2012
    Thanked: 58
    Quote Originally Posted by Tsotsi View Post
    Aha! First code was the Key code. Got a code now with Numbers and Letters. Guy from LR explained what number the letters represent as well.
    Now to practice on keying in the code.....
    Gary W
