Wrnd
Results 1 to 20 of 92
Thread: Wrnd
    Thanked: 11
    Default Wrnd
    Hi. I’m interested in the possibility of buying a WRND dc to dc auxiliary battery charger but have had no success in contacting the company. I have tried calling them a number of times but each time the call goes to message, I have tried emailing them more than once but received no response and I have tried using their “contact us” facility in their web site, again with no response. Can anyone help me to get in touch with the company or advise me on what might be going on with them. Regards, Don
    Apr 2017
    Hillcrest
    Thanked: 11
    Default Re: Wrnd
    Rather buy from 4x4Direct- easier to contact.
  3. The Following 2 Users Say Thank You to DenzilB For This Useful Post:
    Wartburg.
    Thanked: 495
    Default Re: Wrnd
    Second that.
    Use 4x4 Direct, awesome service!
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    Thanked: 11
    Default Re: Wrnd
    Thanks for your response and recommendations. I have been in touch with 4x4 Direct and will almost definitely purchase through them
    Mar 2015
    Thanked: 78
    Default Re: Wrnd
    Quote Originally Posted by Don P View Post
    Companies like this should not be supported purely because of the levels of service they offer especially when the buyer must resort to a thread like this asking for help.
    With the exception of the service offered by 4x4 direct which is well above par, there are other brands of dc/dc chargers available. Have a look at HCDP, NL etc...
    Ford Ranger 3.2 Auto 4x4 XLT
    Paj DiD SWB Auto
    E92 335i 430kw at the wheels!
    VW G6 GTi DSG
  7. The Following 2 Users Say Thank You to Kish2604 For This Useful Post:
    Jun 2015
    Default Re: Wrnd
    I have tried HCDP as well and know responding back to me both an Email and Maanie cell ?
    Jan 2009
    Bronkhorstspruit
    Thanked: 8
    Default Re: Wrnd
    I have never had any issues contacting Wean from WRND. Phoned him for advise and emailed him. He always answers calls and emails.
    Jan2011 Toyota Fortuner 3.0 D4D 4x4
  10. The Following User Says Thank You to janvg For This Useful Post:
  11. #8
    Polokwane
    Thanked: 478
    Default Re: Wrnd
    Quote Originally Posted by janvg View Post
    Ditto
  12. #9
    May 2007
    Welgelegen, Cape Town
    Thanked: 136
    Default Re: Wrnd
    I installed a WRND charger, charge seems fine, but when the vehicle is switched off, the WRND Red led comes on, but every now and again switches to blue.. Why does it do that? Normal?
    Toyota D4D Legend 45
    Nissan Kingcab 2007 4x4
    Bushlapa Vlooi 652
  13. #10
    Polokwane
    Thanked: 478
    Default Re: Wrnd
    Quote Originally Posted by Kaptein Jack View Post
    "If the engine is turned off charging will stop once the primary battery settles at 12.8V. "
    The red light stays on for a couple of minutes, after the vehicle is switched off, untill the battery's volts setels.
    The blue light should not come on.
    If a 220v charger is connected to the main battery the blue light might come on.
  14. #11
    May 2007
    Thanked: 136
    Default Re: Wrnd
    Thanks, somewhere, somethings wrong, my main battery is being drained, I can actually see it on the Nat Luna batt monitir connected to my auxillaru batts, it remains high up in the green leds..
    Bushlapa Vlooi 652
  15. #12
    Mar 2013
    Molopo
    Thanked: 77
    Default Re: Wrnd
    What is the voltage of your main battery after switching off the car?
  16. #13
    May 2007
    Thanked: 136
    Default Re: Wrnd
    Thanks, found the problem child, I connected the mode wire (extended wire) onto car bat, must not connect that wire unless your vehicle charges your primary batt at less than 13.5v.
    Bushlapa Vlooi 652
  17. #14
    Jan 2019
    White River
    Default Re: Wrnd
    I put a switch in that wire. It gives me the option to override the voltage cutout should I wish to.
  18. #15
    May 2007
    Thanked: 136
    Default Re: Wrnd
    Just a quick one, your fridge or fridges, did you connect it to the auxillary battery ports as well, or directly to the batteries??
    I connected my two fridges to the aux batt ports on the WRND, dunno if that is good or bad??
    Bushlapa Vlooi 652
  19. #16
    May 2007
    Thanked: 136
    Default Re: Wrnd
    At what volts, does the WRND cut out?
    Bushlapa Vlooi 652
  20. #17
    Aug 2017
    Thanked: 888
    Default Re: Wrnd
    Yes, run the fridge(s) through the WRND, instead of directly from the battery.
  21. #18
    May 2007
    Thanked: 136
    Default Re: Wrnd
    Thank you Sand
    Sorry for all the questions..
    I have noticed, if I put the main battery on charge, the charge also goes "through" to the auxillary batts, is that normal?
    Is this good or bad? Should one install a cut off switch between the main batt and the WRND?
    Bushlapa Vlooi 652
  22. #19
    Aug 2017
    Thanked: 888
    Default Re: Wrnd
    Thank you Sand
    Yes, its normal. When the primary battery is charged without disconnecting from the WRND, it will charge the secondary battery. Nothing wrong with that, unless you specifically do not want to (e.g. to get the primary battery charged up quicker).
    I wouldn’t install a switch between the two batteries. The WRND takes care of that, unless you have specific reason, as stated above. Assuming you have appropriate fuses etc in place.
  23. #20
    Mar 2011
    Work in EG - Live in Port Elizabeth
    Default Re: Wrnd
    I am using WRND that i made the battery-box myself. Working great.
    Franna
    Swambo= Porsche Boxster
    Myself= Triton 3.2 Auto.... Cirrus Inter-cooler,63 mm Powerflo Exhaust and Unichip installed/Tuned by KSD
    Imagine Trailvan 4x4 caravan.
