Wrnd - Page 4
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 61 to 80 of 92
Thread: Wrnd
  1. #61
    Mar 2011
    Work in EG - Live in Port Elizabeth
    Default Re: Wrnd
    Quote Originally Posted by Kaptein Jack View Post
    I think the bottom line here, it is cheap DC-DC charger that does not have all the bells and whistles of the units costing R4500+, still a good buy though for the price.
    I differ from this quote
    In my previous vehicle i had the D 250 S CTEK witch gave me joy and no trouble.
    With this vehicle i have build my own installation with the WRND charger and have to say it`s working very well and i have the same joy from this system that i had from the 3 times more expensive CTEK system
    I have just returned from a two week Kgalagadi/Namibia trip and is pleased with my WRND system.
    Franna
    Swambo= Porsche Boxster
    Myself= Triton 3.2 Auto.... Cirrus Inter-cooler,63 mm Powerflo Exhaust and Unichip installed/Tuned by KSD
    Imagine Trailvan 4x4 caravan.
  2. #62
    Wartburg.
    Thanked: 495
    Default Re: Wrnd
    I have to agree, I have two WRND chargers and they work great, have never had a issue with them and no complaints.
    Both are used with 12v from the vehicle as well as solar, was the main reason for going with the WRND
    Excelent product at a good price.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  3. #63
    May 2007
    Welgelegen, Cape Town
    Thanked: 136
    Default Re: Wrnd
    [QUOTE=DC Polokwane;4294481]Is this the fuse that you've put in on the positive wire close to the battery? or the one on the charger?
    The positive wire could be damaged and is somehow making a short by touching the chassis.
    The charger could be damaged? All their products is tested before shipping so is unlikely but not impossible.
    Double check all your wiring, make double sure all positive/negative connections are correct.
    Do you have a multi-meter? Check all in and outgoing voltages on your system.[/QUOTE
    It is the fuse on the WRND, incomming power, measuring 13.47 volts
    Toyota D4D Legend 45
    Nissan Kingcab 2007 4x4
    Bushlapa Vlooi 652
  4. #64
    May 2007
    Thanked: 136
    Default Re: Wrnd
    As soon as I connect the aux batts to the system, it blows the main 30amp fuse on the unit.
    Bushlapa Vlooi 652
  5. #65
    Feb 2016
    Thanked: 607
    Default Re: Wrnd
    Have you tested the health of your auxiliary battery?
  6. #66
    Polokwane
    Thanked: 478
    Default Re: Wrnd
    If your connections are as per post #38 sans the ignition wire then the unit should work.
    Remove the fridge and test, if it still blows the fuse then you might have a faulty unit or you might have damaged the unit with a incorrect connections?
  7. #67
    May 2007
    Thanked: 136
    Default Re: Wrnd
    I disconnected all wires from the unit, then started adding the main power source, with the new fuse, motor running, power comes on the unit, red light, connect aux batts, neg, then pos, bang the fuse goes.
    Bushlapa Vlooi 652
  8. #68
    Sep 2018
    Thanked: 98
    Default Re: Wrnd
    Above you say aux batts (plural). Are they wired in series or parrallel?
  9. #69
    May 2007
    Thanked: 136
    Default Re: Wrnd
    Parallel
    Bushlapa Vlooi 652
  10. #70
    Sep 2018
    Thanked: 98
    Default Re: Wrnd
    Parallel
    From all you have said in this thread, I suspect that the fault lies with the WRND.
  11. #71
    May 2007
    Thanked: 136
    Default Re: Wrnd
    Unit was faulty, replaced, all good now
    Bushlapa Vlooi 652
  12. #72
    Wartburg.
    Thanked: 495
    Default Re: Wrnd
    Thanks for the feedback.
    I'm sure now that it is working right you are going to love it.
  13. #73
    Mar 2011
    Default Re: Wrnd
    Give again feedback after properly tested
    Sure you will be happy with the product as the rest of us is.
    Franna
  14. #74
    May 2007
    Thanked: 136
    Default Re: Wrnd
    So tested all, charging, aux batts, fridges, and main batt, no issues what so ever.
    Also installed a little battery volt, ah and watt meter, "nifty" little gadget..
    Bushlapa Vlooi 652
  15. #75
    May 2007
    Thanked: 136
    Default Re: Wrnd
    Double post
    Bushlapa Vlooi 652
  16. #76
    Mar 2011
    Default Re: Wrnd
    Any pictures of your installation?
    Franna
  17. #77
    May 2007
    Thanked: 136
    Default Re: Wrnd
    Ok. so please see attached a pic of my deurmekaar installation, but it works.
    So, main feed comes in from the alternator, connected to "CAR" on the DC_DC.
    Then the aux Batts ( I have two 102"s connected in parrallel) are connected to the "Aux" batt connection going to the Brad Harrisons marked AUX Batt connection.
    PV is connected to my solar panel as you can see the green light is burning, meaning solar is charging
    The Battery Protector, to get power, is connected directly to one of the aux batts, with a 10amp fuse.
    The fridges get their power via the the two terminals on the Battery Protector.
    And then I connected the Bat Volt, AH watt meter in the "fridge line" showing me amps etc drawn by the fridges.
    Oh yes, I have left the cut off switch, remember I installed it to prevent any drain from the main batt in the engine compartment, but since I have a new unit, this is not a problem any more.
    So yes, it looks messy, will one day tidy it all up, but for now, it is fine..it works and I am happy.
    Bushlapa Vlooi 652
  18. #78
    Feb 2016
    Thanked: 607
    Default Wrnd
    Ek sou voorstel jy maak daardie skermpie en sy kabels iewers vas. As hy heeltyd so gaan hang (soos in jou volgende post se foto) dan gaan die kabels eendag hulleself loswerk van waar dit op die skermpie vas soldeer is
    Jy kan hom mooi panel mount:
  19. #79
    May 2007
    Thanked: 136
    Default Re: Wrnd
    Sjoe dis regtig netjies!
    Bushlapa Vlooi 652
  20. #80
    May 2007
    Thanked: 136
    Default Re: Wrnd
    I must find somebody in Cape Town that can tidy up my crows nest..
    Bushlapa Vlooi 652
