UPS batteries and maintenance
Results 1 to 6 of 6
    Thanked: 208
    Default UPS batteries and maintenance
    I bought myself a 24v, 2400vA inverter in a box purely for load shedding survival, TV, DSTV and WiFi router.
    The supplier did not have batteries in stock, maybe a blessing in disguise?
    My question is what batteries should I buy? And if there is no load shedding for an extended period should I periodically switch off the supply to cycle the batteries?
    Finally where is the best place to buy deep cycle batteries?
    4x4 less.
    Gaborone, Botswana
    Thanked: 1115
    Default Re: UPS batteries and maintenance
    I'm using the First National Battery (Exide/Raylite/Chloride) SMF100 102Ah Leisure batteries with my inverters at home. The battery with the treaded posts.
    Kobus
  3. The Following User Says Thank You to KobusDJ For This Useful Post:
    Jan 2017
    Thanked: 154
    I have the same question re switching off the power source in order to cycle the batteries...
    “If you want to go into the bush, take a Ford. If you want to get back, take a Landcruiser!”
    Series 80 'Cruiser GX Diesel 1996
    Cooper ST Maxx 265/75/16 tyres;
    ARB bullbar; 9000kg T-Max winch; Outback roofrack; Double fuel tank; Outback Extreme spare wheel carrier x 2; Air Spring boosters; Racor diesel filter; NL dual battery set-up; 2 x 100w solar panels; Big Country gullwings, Front Runner drawer system; Stofpad 4x4 drop-down fridge slide; NL 78-litre double door fridge/freezer; NL 60-litre freezer; Eeziawn rooftop tent; Eeziawn awning.
    SWAMBO: Honda CRV 2.2 Diesel
    Previously: '98 Defender 110 HT TDi, Landy SIII S/W, Hilux D/C 4x4,
    Isuzu 2,3 4x4, Isuzu 2,0 4x4, Isuzu 1600 4x4, Chev Nomad, Cheetah beach buggy!
    Rangeview Krugersdorp
    Thanked: 1199
    I exercise all my batteries on 1st of every month.
    All in top condition still after maybe 6 or 7 years.
    Hyundai Getz 1.6 2010
  6. The Following User Says Thank You to duncang For This Useful Post:
    Thanked: 208
    Thanks Duncan, what does exercise entail please?
    4x4 less.
    Ellisras
    Thanked: 517
    Quote Originally Posted by Brian1 View Post
    ... where is the best place to buy deep cycle batteries?
    I suggest you contact the Dixon factory directly -
    Street address:
    Nuffield Street ,Duncanville
    Vereeniging
    Postal address:
    PO Box 81
    Vereeniging
    1930
    Telephone number:
    +27 (16) 455-1800 +27 (87) 050-1167
    Fax number:
    +27 (16) 422-4759
    Email:
    [email protected]
    [email protected]
