1993 3.0 V6 Pajero - SOLD : 2001 3.2 Di-D Pajero - SOLD
2005 Touareg R5 2.5 TDi - SOLD : 2007 Pajero LWB 3.2 Di-D
My YouTube channel
Touareg Manuals Google Drive Folder : Pajero Manuals Google Drive Folder
The clever ones are being outbred & overruled by the not so clever ones. Pair that with unchecked selfishness. We are heading for a fall!
My YouTube channel
Holiday travelling, the Pajero has just clocked over to 350'000km.
My YouTube channel
Managed to get the economy down to 9.2l/100kms driving at 110km/h GPS with A/C on.
Day to day running around 11-12.
My YouTube channel
It has to be said this thread is much more boring than the one on your Touareg.
Current: Mercedes-Benz ML350 4Matic
SWAMBO: 2020 Renault Koleos 2.5 Dynamique
My YouTube channel
My YouTube channel
My YouTube channel
Those are great figures..Even if at 100kmh
Starter said goodbye
It must have been worked on in the past. Solenoid had no spring inside.
Luckily the ring gear ate the bendix, and not the other way round.
Asked Mitsu for bendix kit and solenoid. R6k
Brand new complete starter from Midas - R1900 delivered to my door.
Simple job. Battery disconnect, ATF dipstick tube out. + Cable and spade off starter. Two 14mm bolts and out she comes.
My YouTube channel
Ek sou gedink het 2x10mm boute. Seker overengineered. Hoop daai cinesium solonoid hou. Hou daai ou parte…
My Pajero is the Gen 4 with the Aisin gearbox and within the last month Mitsubishi quoted me just over R11k + VAT for this kit that I thought may be a good idea to carry as a spare on our present excursion. Not at R11k.
They also quoted over R8k for a new SCV and I got one from Masterparts for R1773.
Gen 4 Pajero GLX 3.2 DiD
My YouTube channel
Hoop jou geluk is beter as myne, maar daai cheap starters hou nie baie lank nie.
Ek vermoed dis dalk agv battery.
Daai 3.2 engine vat baie oomph om te start.
Ek is al op my derde battery in ses jaar. Hulle hou gewoonlik so 2-2.5 jaar.
As hy een keer my drop en hy is ouer as twee jaar koop ek nuwe battery.
As jy nie vroeg spring nie is die voltage drop dalk te kwaai vir die cheap starter.
Ek is OK daarmee. Starter ruil is minder as 'n uur en ek kan drie starters koop vir die prys van een solenoid en bendix by agente.
My YouTube channel
Gewoontlik die chinese solonoid wat oppak.
Autoelcs wil nie eens meer aan n chinese starter werk oor die swak solonoids, waarvoor hulle moet pa staan.
Probeer die battery omruil net voor die 2 jaar waarborg om is.
My YouTube channel
I have been chasing a rear suspension knock for months.
I saw some play on the trailing arm bush on the hub side. Bushes didn't look bad but there was some play. Eventually bit the bullet and ordered a bush kit
At the price a bit disappointed. Would have liked the edges to be chamfered to make it easier to get them in. It was a PITA. Also had to take a bit of material from the sleeve on the ID to get the bolt to go through.
Eventually got them in, after removing the old bush sleeve.
Replacement bushes are considerably harder and a tighter fit.
Knock is gone, and car actually feels softer but more solid at the same time.
https://go4lo.co.za/products/mitsubi...m-hub-bush-kit
My YouTube channel
