Supersprings ?
Results 1 to 18 of 18
Thread: Supersprings ?
    Oct 2012
    Default Supersprings ?
    Does anybody know anything about this product, good or bad?
    http://www.supersprings.co.za/information/
    That Mighty Amarok
    Swart Tires wat ek self gekoop het
    Pull over wat my ouma gebrei het
    Vensters waar deur ek kan sien
    Engine voor
    Exhaust agter
    Default Re: Supersprings ?
    Quote Originally Posted by Snyks View Post
    seems similar to Add-A-Spring? same thing?
    Great product. Does what it says it will.
    Gavin
    Tshwanetoria
    Very interesting. I don't claim to be well informed, so lets see if their claim of being well known in SA, can be substantiated by other forum members?
    Seems a viable option, depending on costs.
    Used it. performed well for more than 5 years on the Hardbody.
    Once fitted it will give you approx. 20-30mm lift, depending on the height/bolting selected.
    I did not notice any difference in harder ride quality.
    Nato
    '13 Nissan Navara 2.5TDCI DC 4X4
    Ex '08 Nissan Hardbody 3.0 TD 4x4
    Oct 2012
    Was quoted 2.5K, installed at my home. From the replies so far, I am very tempted
    That Mighty Amarok
    Engine voor
    Exhaust agter
    Tshwanetoria
    Same here
    Just remember - if there is not a load on the vehicle, your rear shocks might be too short and will top out.
    Gavin
    Feb 2016
    Paarl
    I've used something similar: Loadhog
    For the purposes of this thread I will refer to bakkie A and bakkie B, which is different manufacturers, lest a can of worms and rapid derailment be the outcome. I had 2 delivery bakkies (A) and a service bakkie (B) the latter of which was driven by a technician that repairs pool pumps. Bakkie B was also a 1 tonner. Once or twice when used it got around to 700kgs and began to sag.
    Decided as a cost saving when I needed another delivery bakkie, to get the technician a Bantam and utilize his 1 ton bakkie as delivery vehicle. I solved the sagging problem with Loadhog. Even up to 1.2 ton it was still level.
    1996 Discovery 1 (SOLD)
    2001 Mercedes C180 (SOLD)
    2012 Nissan Xtrail 2.0 (Weekend Wagon)
    2010 Kia Sedona 2.9Crdi (Written off)
    Oct 2006
    Orapa
    I had them on my Navara and they worked a charm. Well worth the money.
    In Rock we trust
    Waste money not time
    Brackenfell
    Quote Originally Posted by PottieP View Post
    Hi PottieP
    Het jy standaard shackles op gehad met die helpers of Extended shackles?
    My skoonpa het shackles opgesit maar dit is beter as tevore, maar die vere lÍ plat. Hy is tussen dit en retension (hier in die Kaap klink dit nie vir my of the Vere manne goeie werk meer doen nie)
    Hy sleep van tyd tot tyd die karavaan.
    Melkbosstrand
    Following as it might be a decent option when I tow
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
    Oct 2006
    Orapa
    I had standard shackles on. I also had Camil shocks front and back. Had to add the supersprings, because of the extra weight of the canopy and longrange fuel tank.
    In Rock we trust
    Quick question, did it effect your flex in anyway?
    2017 3.2 Ford Ranger Wildtrak D/C
    Old Man Emu lift kit
    Stofpad Box rocksliders
    Aline Dagger
    BFG KO2 285-75-16
    Stanium aluminium canopy with some goodies and stuff inside
    and loads of attitude
    Oct 2006
    Orapa
    Yes it did, but it never was an issue overlanding.
    In Rock we trust
    Tshwanetoria
    Bump
    Tshwanetoria
    It would seem that Supersprings are not so well known after all?
    Henties
    I donít know Supersprings, but I had Loadhog fitted to my LC 60 series original springs. Same principal. The rear spring packs were tired and a small basket of strawberries made the rear sag. With the loadhogs fitted it looked and felt right again. Very good low cost solution for sagging springs and constant load carrying.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
