Discovery 4 Freeflow exhaust on a Diesel?
Results 1 to 20 of 29
    Mar 2012
    Fourways
    Thanked: 387
    Default Freeflow exhaust on a Diesel?
    My exhaust has its fair share of dings, scrapes, cat removal and welds from the life the car lives so I am looking at fitting a new exhaust. We have recently discovered a leak on the exhaust which explains why the V6 growl sounded so sexy.
    Is there any benefit of fitting a freeflow exhaust to the 3.0 Diesel?
    Rob,
    D4 SDV6 HSE ARB Bullbar, Compos, BFG 265/65R18s, Big Country drawers, National Luna 52L, Dometic 50L, Spare Wheel Carrier, Roof Rack, Hardshell RTT, FR 50" LED Bar, Lift Rods, Mantec Snorkel, C-TEK Dual batt system, 270 Ostrichwing, Maxtrax, TXG Rock Sliders, IIDtool, shelf
    Sandton
    Thanked: 73
    Default Re: Freeflow exhaust on a Diesel?
    Be Carefull !!
    I played around with free flow systems on my D3. Took it to the Dyno afterwards and the power was down by up to 10% on some systems.
    I think Viper Exhausts are the guys to talk to.
    GASMAN
    Land Rover D3 TDV6 HSE 2007 - Goldilocks - Gone
    Land Rover D4 SDV6 HSE 2012 - Voeniks
    Ratel Bullbar
    Ratel Snorkel
    Ratel Rock Sliders
    Ratel Offroad Tow Hitch
    Melville & Moon Seat Covers
    TORQTUNE Map
    ORRA Z 173
    Apr 2019
    Thanked: 35
    The less back pressure for a turbo diesel lowers egt and the turbo spools earlier , i removed both my silencers from my 300 tdi and my egt was lower as well as low down power improved alot.
    Thanked: 9730
    Quote Originally Posted by DETOUR-GP View Post
    less turbo lag, faster spool up, lower exhaust gas temperatures
    no negatives except extra noise
  5. The Following User Says Thank You to jelo For This Useful Post:
    Wellington
    Thanked: 436
    Its an interesting topic
    A while ago I had a chat with the local Powerflow guys and he was of the opinion a freeflow on a diesel doesnt really make much sense
    You dont gain anything, and with the wrong system in place, could have a drop in power
    Some car, some bike and two legs
    Feb 2015
    Thanked: 69
    I am no expert, but any turbo motor, diesel or petrol, will benefit from a more free flowing system.
    There is however a lot of discussion about the size of the exhaust, to fit any form of silencer or not, and the size of these.
    Straight pipe is very loud though, so one silencer is probably the way to go?
    Now for the pro's to comment...
    2016 Ford Everest 3.2Tdci XLT AWD A/T - Mods have begun!
    2010 BMW 320i AT (SWAMBO)
    Always go for the deepest mud, muddy stories make the best memories!
    Thanked: 9730
    Quote Originally Posted by hcs View Post
    the only way you will have a drop in power is if you try and fool the downstream lambda sensor and the catalytic converter sensor if present: the ECU then gets conflicting info on the O2 levels and reverts to a safer map
    but whatever, I'm tired of saying things and getting some hearsay rebuttal
  9. The Following 3 Users Say Thank You to jelo For This Useful Post:
    Wellington
    Thanked: 436
    Hearsay.. aint that about 99% of the posts on this forum anyway?
  11. The Following User Says Thank You to hcs For This Useful Post:
  12. #9
    Jun 2015
    Pretoria East
    Thanked: 490
    I would stay clear from this chap at Powerflow (unless he was maybe referring to non-turbo diesels). On my 79 V8 Cruiser the De Graaf 76mm freeflow had a significant improvement in power delivery. A turbo diesel gain enough power in my opinion to warrant the expense.
    A vehicle still under warrantee is another subject as the manufacturer may not honor claims afterwards.
    Dirk Theron
    Land Cruiser FJ
    Hilux 2.8 GD-6 Auto 4x4
    BL865 Ratel4
    Life’s a journey, enjoy the ride
  13. #10
    Mar 2016
    Thanked: 1814
    The best exhaust on a diesel, is no exhaust
  14. The Following 2 Users Say Thank You to Oppies3800 For This Useful Post:
  15. #11
    Thanked: 9730
    Quote Originally Posted by DCTheron View Post
    indeed
    No turbo diesel exhaust needs to have a tuned length header or be tuned for scavenging. It needs as big an exhaust and downpipe possible (without being silly) to get as much of the exhaust gases away from the impeller as fast as possible.
    Now there MIGHT and I say again, there MIGHT be extreme conditions of gas/fluid dynamics where you COULD get the gas velocity to be PERFECT using a tuned extraction system downstream of the turbo, but without extensive modelling systems, I doubt you'd get more than a 5% improvement over a plain old freeflow pipe.
  16. #12
    Wellington
    Thanked: 436
    Roddy knows his stuff so I would trust him. Keep in mind, this was on my old 2.5 Ranger that I inquired about at the time. We ended up just replacing the stock exhaust
  17. #13
    Feb 2015
    Thanked: 69
    JBC Performance exhausts in Bloem builds amazing exhausts.
    Maybe give Johan a call? They have a page on facebook.
    They do a lot of diesel Cruisers and Rangers
  18. #14
    Thanked: 911
    I haven't heard of a turbo diesel that did NOT benefit from a freeflow. As said by others, just be careful to add enough of a silencer so you don't spoil the vehicle with a too noisy exhaust.
  19. #15
    Mar 2012
    Fourways
    Thanked: 387
    Thanks for the comments gents, seems like the general consensus is that the car will benefit from the freeflow.
    I will look at doing it and will post my findings in this thread for others who may be considering doing the same
    Rob,
  20. #16
    Thanked: 9730
    as mentioned, be careful of all sensors, that's where modern cars need the most attention
  21. The Following User Says Thank You to jelo For This Useful Post:
  22. #17
    Nov 2006
    Thanked: 408
    I can add to what hcs said, I also dealt with Roddy at Powerflow Bellville, also wrt a 2.5 Ranger and I received the same reply.
    On his recommendation we settled for a pipe one size down from max (63mm?) and a small straight through silencer at the back to make everything fit.
    Must say leaving the workshop didnt blow back my hair.
    The tuning at KSD however was a different story.
    Looks like its time for a second opinion/upgrade because every bit helps.
    If you live each day as if it was your last, someday you'll most certainly be right. SJ
  23. #18
    Carletonville
    Thanked: 598
    Quote Originally Posted by Oppies3800 View Post
    This is what I have been told over and over. Besides the noise, no reason for an exhaust on a TD. Mine is hardly 1 meter long from turbo to tip. I dump on the passanger side, so I can't hear it, or my wife for that matter. Win, win.
  24. #19
    Jan 2011
    Thanked: 37
    On my previous Fortuner I also installed the 76mm De Graaff system and only real difference was a slight reduction in spooling time and a reduction in EGT. Fuel consumption and max power stayed the same (already had the chip in). KSD commented that you will have to adjust the tune to make use of the lower EGTs but my goal was not more power, just lower EGTs so I did go for the "Stage 2" tune.
    2017 Toyota Fortuner 2.8 GD6 4x4 iMT
    2016 Hyundai Tucson 1.6 T-GDi
    2019 Bush Lapa Miskruier BL1861
  25. #20
    Thanked: 269
    Start wih a freeflow with no boxes in, if the noise is a problem you can add a box or two later.
    Neil
