Leasure Wheels article Ama V6 vs X Class 350d
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 44
    Thanked: 104
    Default Leasure Wheels article Ama V6 vs X Class 350d
    In the latest Leisure wheels article Hannes Grobler tests the 2 vehicles on a Dyno. 165kw Amarok V6 made 20HP more on the dyno than the 190Kw X class. Mercedes being optimistic with their figures or VW again being conservative?
    Darryn Van Rooyen
    2014 D/C Amarok 4Motion H/L Auto - 76mm Decat Downpipe and Revo Stage 1 Tune
    Current: 1987 Citi Sport 1.6
  2. The Following User Says Thank You to dazza For This Useful Post:
    Feb 2012
    Thanked: 369
    Default Re: Leasure Wheels article Ama V6 vs X Class 350d
    what is the difference between kw, hp and nm? how much kw is 20hp? is kw and hp calculated based on torque? Does the relationship between kw and hp have more to do with torque than each other? What does a Dyno measure, hp, kw or nm? Does measure nm and then extrapolate kw and hp? Or does it measure all three independently?
    So many questions.
    Is VW better than Mercedes?
    No.
    Is VW better than Nissan?
    Maybe.
    Regards,
    William
    D4 v8 --Sold
    Quote Originally Posted by Murray Walker
    “I don't make mistakes. I make prophecies which immediately turn out to be wrong.”
    Jan 2014
    Northern KZN
    Thanked: 225
    I suspect the Mercs sold here is "slightly" down tuned due to several factors. Diesel quality, climatic conditions, etc.
    Groetnis
    Jan 2015
    Vredenburg
    Thanked: 943
    Quote Originally Posted by willben View Post
    So many questions.
    No.
    Maybe.
    No....
    Well based on their flawed airconditioning design since they started moving the battery to the engine bay Is would have to say YES.
    There is a huge problem with their airconditioning failing because the battery gasses enter the airconditioning systems and erodes these interior evaporator. Two of my close friends reported this problem and when I took my car for an aircon service I was surprised to see a Mercedes dash completely stripped. I asked the owner of the airconditioning shop and he explained to me that this is indeed a regular occurrence.
    So don't let your judgement be clouded by badges and their high price tags dear sir...
  6. The Following User Says Thank You to Karoo Klong For This Useful Post:
    Thanked: 526
    Actual article here, with the figures being:
    The X-Class peaked at 208hp or 155kW at 3 000r/min at the wheels. These figures are fairly accurate given that the manufacturer claims 190kW at the flywheel, taking into account the expected drivetrain losses of a four-wheel-drive vehicle.
    The Amarok produced 228hp or 170kW at 3 000r/min at the wheels. These figures mean that the Amarok makes more power on the wheels than the manufacturer claims it makes at the flywheel.
    Tyrannosaurus R5 and a second hand British Tata
    Quote Originally Posted by 2beFree View Post
    Jan your signature says it all
    Jan 2014
    Northern KZN
    Thanked: 225
    I must say, in my neck of the woods, I just don`t see these x class Mercs on the road, and when i do see one it is the 250. The only 350 I have seen so far is the one belonging to the local Merc dealer. It seems the peoples have not been bamboozled by the Merc/Nis creation around here.
    Groetnis
    Thanked: 526
    And then the conclusion:
    Both bakkies are exceptional in all conditions and all testers were hard-pressed to decide which they would sign a cheque for. However, the Amarok is more than R200 000 cheaper than the X-Class in standard trim. “Only very passionate Mercedes-Benz fans would opt for the X-Class. The reasonable man would go for the Amarok every time,” concluded Grobler
  10. The Following User Says Thank You to JanB For This Useful Post:
  11. #8
    Feb 2012
    Thanked: 369
    Quote Originally Posted by Karoo Klong View Post
    No....
    Oh no, the air conditioning I forgot about that. Seeing as that is the only measure by which I judge a vehicle I guess then VW is better than MB.
    I will try not to be clouded by my air conditioning issues in future.
    Regards,
    William
    D4 v8 --Sold
  12. The Following User Says Thank You to willben For This Useful Post:
  13. #9
    Brits
    Thanked: 432
    Quote Originally Posted by dazza View Post
    VW has always been conservative with their numbers with anything that has a turbo on it.
    Renault Duster 1.5Dci 4WD
  14. #10
    Jan 2015
    Vredenburg
    Thanked: 943
    You do that yes.
    You better believe it.
  15. The Following User Says Thank You to Karoo Klong For This Useful Post:
  16. #11
    Barberton
    Thanked: 1182
    So many questions.
    No.
    Maybe.
    1) 20 Hp = 14.9kW
    2) kW and Hp is the same thing, only expressed in different units. Just like kilograms and pounds.
    3) kW is derived directly from torque, but incorporates the speed at which it is applied.
    The formula reads: kW=2 Χ Pi x Nm x rpm / 60000
  17. The Following 5 Users Say Thank You to RoelfleRoux For This Useful Post:
  18. #12
    Doing Time in CKGR
    Thanked: 184
    A friend of mine is a Product Controller at the Wolfsburg factory and she has just taken delivery of her 190kW Amarok.
    Her response to one of my questions was ... absolutely wicked power ... but unnecessary
    These images are of her vehicle whilst out on a training run.
Name:	VW 190KW 1.jpg
ID:	526403   Click image for larger version.
Name:	VW 190KW 3.jpg
ID:	526404   Click image for larger version.
Name:	VW 190KW 2.jpg
    VW Amarok V6 4Motion Highline Plus
    Defender 130 HCPU TD5
    SOLD - D4 SDV6 HSE
  19. The Following User Says Thank You to Oreo For This Useful Post:
  20. #13
    Tshwanetoria
    Thanked: 745
    So many questions.
    No.
    Maybe.
    Define "better" for us
  21. #14
    Thanked: 104
    Would be cool to see if there is actually a "real" difference in power between the 165 and 190kw Amarok when they surface here
    Darryn Van Rooyen
  22. #15
    Feb 2012
    Thanked: 369
    in every conceivable way you can imagine, except for price, the Mercedes is "better" than the VolksSturmWagen.
    Regards,
    William
    D4 v8 --Sold
  23. #16
    Jan 2014
    Northern KZN
    Thanked: 225
    Your opinion and experience, or another source?
    Groetnis
  24. #17
    Feb 2012
    Thanked: 369
    Ok I can't do this anymore. I'm just trolling guys. Relax. I was just touching you on your studio.
    Regards,
    William
    D4 v8 --Sold
  25. The Following User Says Thank You to willben For This Useful Post:
  26. #18
    Tshwanetoria
    Thanked: 745
    Please don't waste our time
  27. The Following User Says Thank You to hatjohan For This Useful Post:
  28. #19
    Dec 2006
    Thanked: 865
    When-ever I read these articles, and even more so the comments made on which is better, I ask myself what it's based on.
    Better for whom. Better for the Kalahari farmer who every 2nd day covers 200km of bad corrugations, and rescue sheep off a koppie, or better for the lady of the house who needs a foh-by-foh to fetch the children from Waterkloof high.
    Why not just stick to raw fact, and stay away from opinions and perceptions.
    Sakkie Coetzee
  29. The Following 10 Users Say Thank You to Sakkie For This Useful Post:
  30. #20
    Thanked: 526
    Ag nee wat Sakkie, dan was die forum lankal dood.
    The original LW article referenced stated that the VW's engine power is more than the Merc, based on actual testing. It then quotes Hannes Grobler as saying that he thinks the Amarok is a much better buy.
    You can actually happily debate which of these two are the "best" as they are aimed at exactly the same market.
