Diesel filter housing - 2006 Isuzu kb300
Results 1 to 16 of 16
    Apr 2019
    Default Diesel filter housing - 2006 Isuzu kb300
    Morning everyone.
    I recently broke the bleeding screw off inside the priming pump/filter housing.
    Dealers dont supply screw only complete housing.
    Ill probably need a new housing as the chances of stripping the thread while getting broken screw out is highly likely.
    Does anyone know where i can source a generic housing as dealer wants 2k .
    Much appreciated
    King Williams Town
    Default Re: Diesel filter housing - 2006 Isuzu kb300
    Try midas
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Apr 2019
    Try midas
    Nothing
    Mar 2017
    Try A1 bakkie spares. They should have
    King Williams Town
    Quote Originally Posted by Ibk View Post
    Morning everyone.
    Much appreciated
    Can you not drill a small hole into broken screw then use an easy out to get it out.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
    Apr 2019
    That was my initial plan however Ive been warned that the threading may damage very easily and that once new screw is fitted it wont seal 100%
    I'm inclined to try anyway, trouble is sourcing this screw... Going to a few scrapyards this afternoon so lets see.
    Would anyone know why on earth an aluminium screw is used in this setup? Weight reduction on a 2006 KB 300? Hardly...
    Apr 2019
    Thanks jelo
    This is right on top of my Christmas list, if my budget allowed I would of had it yesterday.
    Done load of research on this and seems this and regular Delo 400 would render my ride bulletproof
    Thanks jelo
    nope
    the KB300 breaks like all other vehicles when driven hard
    Sep 2012
    johannersburg
    nope
    If not maintained yes i agree otherwise no ur very wrong
    ISUZU KB300LX DMAX mine / 1.4tdci with software exhaust and intercooler and watermeth injection /dad-kb300 dteq kb5 4x4 /uncle kb300 4x2 dteq kb5 /step dad. Kb6 kb300 4x4 auto all double cabs
    Wilderness
    Try and use a small punch and hammer to see if you can start turning the broken bolt. If it moves keep on going. Drill the bolt out. If the thread gets damaged tap to a bigger size. If it leaks use thread tape or a rubber 0 ring.
    First check if the bolt does not protrude on the inside, then it would be easy to remove.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Nov 2017
    The aluminium screw should be easy to drill out - just don't drill too deep, it should have the hole in the centre which you can guage the depth and use the hole as a drill guide. Try a lh thread drill bit on a reversable drill - usually as it bites into the screw, it will unscrew the screw.
    For the screw, try your nearest brake and clutch repair guys, they should have a box with different bleed screws.
    Apr 2019
    Thanks for all the feedback guys.
    Still a few scrapyards to visit then Ill take it from there. Ill post updated
    Brackenfell
    Quote Originally Posted by giolanman View Post
    I agree with giolanman. Those Isuzu's(Go Big) are still almost like the original kannie doods. After that they became more modern with more electronics.
    I owned one that I bought from original owner with 310k on clock and sold it within 3 hours of listing after owning it for 7 great years. Sold with 413k on clock.
    service every 10k with delo 400 (previous owner did same but used Engen Dieselube 700). Most expensive part replaced was the starter and battery. A couple of maintenance goodies etc..
    Apr 2019
    cant agree more. I actually inherited in from my grandfather, He only put on 100k kms since 2006.
    One of my first trips was to Nelspruit pulling around 3tons. Ive done slight offroading at de wildt but man this thing works. hauling serious loads often i actually sometimes feel sorry for her.
    No idea what oils were used but i changed everything to delo400 and bot402 as researched on this forum.
    I did notice she started leaking oil slightly after a long hard trip but nothing more than a pint between services. (Im thinking that the delo might have 'cleaned' a bit more than it was supposed to)
    Otherwise im extremely happy, economy around 12k/l and very comfortable compared to other brands of similar year...
    These things hardly break unless you doe it yourself like in my case
    Thanks again guys
    Apr 2019
    Morning everyone.
    After searching for said part at numerous auto parts shops and scrapyards I was strongly advised against trying to fix it by a reputable fueling and injection parts store.
    According to them the cost associated with injector pump/injectors failing due to incorrect seal at filter housing is not worth trying to save R1800 for a new unit. Apparently air from leaking seal kills said parts. It makes sense to me and dont feel like gambling so I fitted new housing and had to charge battery due to all the failed starting attempts.
    Started within a couple of turns this morning and all good!
