Nissan Navara D40 rear leaf springs NEED HELP
Results 1 to 5 of 5
    Apr 2019
    Shah Alam
    Default Nissan Navara D40 rear leaf springs NEED HELP
    hi guys
    I've got the Navara D40 2.5 Diesel 4x2 (2WD) Calibre. It looks and has the same ride height as the 4x4 version so...
    recently I noticed the rear leaf springs are starting to sag and even bend up (vs arch downwards) UNLOADED! the right side is definitely off- vs left which is flat.
    so I've been calling around the spares suppliers and none have the 2WD leaf spring
    code:
    55020-JR01C
    but they have the 4WD springs code:
    55020-JR21C
    does anyone have experience, that the 4WD springs would fit my truck?
    I've yet to actually measure the springs hole-to-hole...
    Apr 2019
    Shah Alam
    Default Re: Nissan Navara D40 rear leaf springs NEED HELP
    ah I found out something about this today.
    I spotted a Navara LE (4WD model) in the basement car park today and I got to take pictures of both our springs...
ID:	526047 This is my Navara D40 2WD (note my blue double shackles)
    and
ID:	526048the Navara D40 4WD....
    note the difference?
    leaf springs are mounted differently, and has different spring configurations.
    Brisbane
    Thanked: 310
    This is pretty normal practice. Especially with Nissan.
    Brackenfell
    Thanked: 258
    This is mine
    2012 d40 2.5 le spanish spec 4x4
    Apr 2019
    Shah Alam
    wow very different for sure.
    thanks guys- turn out the springs were fine. didn't have to replace them for now.
