Oil capacity just over 3l.
10kkm is fine.
15w40. If it is a high miler, 25w50 (API SL)
How often should it be serviced?
What spec oil does it use?
What is the oil capacity?
10kkm is fine.
Uniglide
+27 zero eight 2 four 95 9252
Have a look at an Accuspark kit. Fitted one about 2 weeks ago and it is brilliant.
http://www.accuspark.co.uk/search.html
Uniglide
Wow, good old days. Always serviced mine. Can remember when spark plugs and points were replaced, it was tricky to start. Had to use Top Dead Center on piston one(plug out, screw driver in hole, turn engine until the piston at its highest point), switch ignition ON, turn distributor until you hear the click from the spark, then start. Then set 10 degrees faster or slower, cannot remember. Enjoy great work horses!
SJ 413 - "98 model coily, until son gets license
Mitsubishi Triton DC 3.2 A/T 4X4
2007 Hilux 2.5 D4D SOLD
I will get that kit no. Else talk to Louis Kriel. +27832876045.
Uniglide
Good day.
Does anyone have a pdf of nissan 1400 workshop manual?
Sorry , but I only had the physical manual that I left with my brother in-law in South-Africa when I emigrated. There was a cd inside if I remember correctly, so I will check with him, maybe he can make you a copy.
