Results 1 to 15 of 15
    Feb 2018
    Look behind you...
    Thanked: 247
    Default Nissan 1400 Service Help
    How often should it be serviced?
    What spec oil does it use?
    What is the oil capacity?
    Nigel
    Thanked: 2487
    Default Re: Nissan 1400 Service Help
    Oil capacity just over 3l.
    10kkm is fine.
    15w40. If it is a high miler, 25w50 (API SL)
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
  3. The Following User Says Thank You to Henris For This Useful Post:
    Feb 2018
    Look behind you...
    Thanked: 247
    10kkm is fine.
    Awesome thanks!
    Sint-Michielgestel
    Thanked: 6
    Let me know if you need more info, I have the service manual. I service every 10k kms and do points every 2nd service.
    Jannas
    Nissan Terrano II 2.7 TDI - 2000 - ex
    Nissan Qashqai 2.0 Acenta (petrol) - 2012
    Nissan 1400 Champ - 1996
    Nigel
    Thanked: 2487
    Quote Originally Posted by Jannas View Post
    ..................... and do points every 2nd service.
    Have a look at an Accuspark kit. Fitted one about 2 weeks ago and it is brilliant.
    http://www.accuspark.co.uk/search.html
    Uniglide
  7. The Following 2 Users Say Thank You to Henris For This Useful Post:
    Feb 2012
    Bloubergrant
    Thanked: 171
    Wow, good old days. Always serviced mine. Can remember when spark plugs and points were replaced, it was tricky to start. Had to use Top Dead Center on piston one(plug out, screw driver in hole, turn engine until the piston at its highest point), switch ignition ON, turn distributor until you hear the click from the spark, then start. Then set 10 degrees faster or slower, cannot remember. Enjoy great work horses!
    SJ 413 - "98 model coily, until son gets license
    2007 Hilux 2.5 D4D SOLD
    Sint-Michielgestel
    Thanked: 6
    I don’t see anything for Nissan’s? Is it a conversion kit?
    Jannas
    Nigel
    Thanked: 2487
    I will get that kit no. Else talk to Louis Kriel. +27832876045.
    Uniglide
  11. The Following User Says Thank You to Henris For This Useful Post:
  12. #9
    May 2013
    Thanked: 13
    Good day.
    Does anyone have a pdf of nissan 1400 workshop manual?
  13. #10
    Sint-Michielgestel
    Thanked: 6
    Sorry , but I only had the physical manual that I left with my brother in-law in South-Africa when I emigrated. There was a cd inside if I remember correctly, so I will check with him, maybe he can make you a copy.
    Jannas
  14. The Following User Says Thank You to Jannas For This Useful Post:
  15. #11
    Jun 2008
    Pietermaritzburg
    Thanked: 27
    Hi Jannes, do you perhaps still have the service manual A14 or a downloadable file. PM me if you do. Thanks
    2017 Ford Ranger D/Cab 2.2 TdCi XLS 4x4 Auto
  16. #12
    Jun 2008
    Pietermaritzburg
    Thanked: 27
    Hi Henris, was acuspark kit 36 for 140y. I have a 1995 A14.
  17. #13
    Nigel
    Thanked: 2487
    Quote Originally Posted by regmark View Post
    Ooooo, I can't remember.
    What I do remember is that the dizzy needs to turn a bit. The timing is not at the same place as the points were.
    Uniglide
  18. #14
    Sint-Michielgestel
    Thanked: 6
    I will get it for you, I will find out tomorrow if they still have it.
    Jannas
  19. #15
    Sint-Michielgestel
    Thanked: 6
    PM sent
    Jannas
