Results 1 to 9 of 9
    Feb 2015
    Thanked: 113
    Default Everest 3.2 Dash Rattle - HELP!!
    I have a very irritating dash rattle somewhere in front of the driver seat in my 2016 Everest 3.2.
    I have done the basic pressure tests everywhere to see if it goes away, and nothing.
    The rattle is only there at idle and between 1500rpm and 2000rpm. But it doesn't always happen...
    I'm hoping someone has had this and it's fixed?
    It's going to make me crazy...
    2000 Land Rover Defender 90 2.8i
    Instagram: defender90_2.8i
    2016 Ford Everest 3.2Tdci XLT AWD A/T
    Always go for the deepest mud, muddy stories make the best memories!
    Feb 2013
    Strand
    Thanked: 99
    Default Re: Everest 3.2 Dash Rattle - HELP!!
    Sell it
    Thanked: 9
    Check the plastic covers on the front of your windscreen.The scratch against the glass.They clip off.Cut n mm off on the bottom of the plastic cover.Took mine to Ford Bloem and the technical guy said its a common problem on all the Ford models.
    Ford Ranger 2.2 4x4 2018
    Jeep 3.7 Cherokee 4x4 1996
    Toyota Raider SFA 2.2 4X4 1994
    Mar 2007
    Irene
    Thanked: 76
    That would be the plastic covers on the OUTSIDE of the windscreen not the inside!, sometimes dirt gets trapped and that causes that sound
    Feb 2015
    Thanked: 113
    I knew that was a problem with dust getting in there on the pre-facelift Rangers.
    I did check that, but the plastic cover looks different on the Everest, so I didn't think of that.
    Thanks will have a look this afternoon.
    Feb 2015
    Thanked: 113
    Quote Originally Posted by kenskind View Post
    Sell it
    Maybe in 4 years when my tax benefit is done.
    Awesome vehicle in every single way except for the rattle, which I will sort out
    Mar 2007
    Thanked: 8
    My 2.2 has the same rattle. Very irritating. Please give some feedback once you were able to solve the problem.
    Feb 2015
    Thanked: 113
    Quote Originally Posted by ofe001 View Post
    Had a look yesterday, and there was a lot of dust in there. cleaned majority of the dust out.
    The noise isn't gone, but the noise is different, so that seems to be the problem area.
    What exactly do you mean by cutting away a mm?
    Thanked: 9
    Quote Originally Posted by Henko88 View Post
    Just trim the plastic piece at the bottom end where it presses against the windscreen.
