Snomaster question
Results 1 to 11 of 11
    Aug 2015
    Thanked: 55
    Default Snomaster question
    Morning Forumites,
    I took the plunge and bought my first 12v/220v fridge/freezer, a 56L Dual Snomaster. Very good quality and bit bigger than I anticipated.
    Came with cover and nice wireless remote. Took it out of the box and connect to AC for the first night to test. After reading a bit on the forum I set the freezer (small compartment) to -2 and the fridge (big compartment) to 0.
    Next morning the -2 stood at -7 and the 0 stood at -4. Is this correct that it gets colder than the set range? Was in the home and ambient temp was about 18-21. Installed dual battery system on Friday and wanted to test on DC but for some reason while driving my hella point wiggles and disconnects and reconnect so the fridge whenever checked after driving was not on.
    Current: 2018 Ford Ranger 2.2 XLT AT DC 4x2 with 1985 Jurgens Fleetline L
    Sold: 2015 Ford Ranger 2.2 XL MT DC 4x2, Sold: 2013 Ford Focus 1.6 5DR Trend, Sold: 2010 Ford Ranger 2.5TD Supercab, Sold: 2007 Ford Bantam 1.6 XLE, Sold: 2006 Ford Focus 1.6 5DR Sport
    Ellisras
    Thanked: 375
    Default Re: Snomaster question
    I have 2. One 11y old 60L and one 1year ol 66L Twin door. Both drop to about 2 degrees lower than the setting, compressor switches off. Then when the temp rises to approx 2deg above the setting, it starts. The newer on is slightly more accurate though. I found if the fidges are empty you might get more erratic start stop cycles.
    2000 Patrol GU 4.2D(onkey) beyond 830 000 km
    Thanked: 213
    And... The way I understand is that with the SnoMaster (unlike the NL), you can choose any of the two compartments to be the fridge and/or freezer...
    2017 Mitsubishi Triton 2.4 D/C 4X4 6 Auto Diesel
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    Aug 2015
    Thanked: 55
    Yes apologies, I had to mention both compartments are empty
    Feb 2013
    Thanked: 288
    Quote Originally Posted by SinWolf View Post
    And... The way I understand is that with the SnoMaster (unlike the NL), you can choose any of the two compartments to be the fridgeand/or freezer...
    Correct.
    Land Rover Defender Puma
    Previous ride: Defender 90 tD5
    Aug 2015
    Thanked: 55
    Correct, that to me was the deciding factor. Have had the Dometic on my wish-list for more than a year and then the Snomaster popped up with a special price.
    Constantia Kloof
    Thanked: 530
    Quote Originally Posted by Bluefin06 View Post
    Morning Forumites,
    I own the bdc110 model.
    What you describe re the temperature is normal, it is much more stable once filled. Also, I have done some experiments where I set the left compartment to -15 and the right compartment to +2 and it managed to maintain these temperatures.
    On the supplied "Hella/ lighter" combo plug; Cut it off and fit a standard Hella connector and you won't have issues with intermittant connectivity.
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
  8. The Following User Says Thank You to Koebelwagen For This Useful Post:
    Polokwane
    Thanked: 283
    When set on 0 my Snomaster 60l will vary between -1 and +1
    May 2007
    Welgelegen, Cape Town
    Thanked: 123
    Remove the Hella and fit a Brad Harrison..will never come loose.
    Toyota D4D Legend 45
    Nissan Kingcab 2007 4x4
    Bushlapa Vlooi 652
  11. The Following 4 Users Say Thank You to Kaptein Jack For This Useful Post:
    Aug 2015
    Thanked: 55
    Thanks for all the replies. Popped into 4x4 Megaworld and they will fit a BH and then all should be smooth sailing after that.
  13. The Following User Says Thank You to Bluefin06 For This Useful Post:
  14. #11
    Mar 2015
    Thanked: 68
    i cut my cable about 20/30cm away from the cigarette plug end and put a Brad Harrison on each end, this way of something happened to my power box/BH plug or anything foreseen i can still use the cigarette lighter connection as well. the end lays in one of the fridge jacket pockets. i just like redundancy...
    Ford Ranger 3.2 Auto 4x4 XLT
    Paj DiD SWB Auto
    E92 335i 430kw at the wheels!
    VW G6 GTi DSG
  15. The Following User Says Thank You to Kish2604 For This Useful Post:
