Where can I get my struts pumped?
Results 1 to 14 of 14
    Thanked: 234
    Default Where can I get my struts pumped?
    I have 4 gas struts assisting the lift of my Cheetahs roof.
    With the add of the solar panels I want them pumped a bit stiffer.
    Any recommendations in the Centurion area please?
    Jan 2017
    Thanked: 570
    Default Re: Where can I get my struts pumped?
    What i can recall is that they can only be pumped once. At least when I built a custom canopy a few years back that's what the guys from roadque told me when I bought the struts.
  3. The Following User Says Thank You to RPiet For This Useful Post:
    Wartburg
    Thanked: 1040
    Look for the nearest McNaughton's branch. They can adjust pressures in their struts - not sure if they can on others
  5. The Following User Says Thank You to mikeml For This Useful Post:
  6. #4
    Thanked: 234
    Eish. Closest seems to be Alberton.
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 945
    Bosch ?
    Chev Aveo and Atos and Polo.
  8. The Following User Says Thank You to duncang For This Useful Post:
  9. #6
    Thanked: 28
    Diesel Electric Pretoria West (old Church street just before the railway line bridge going west)
  10. The Following User Says Thank You to Mariuslg For This Useful Post:
  11. #7
    Gaborone
    Thanked: 929
    Can confirm that after talking in length to Bosch Diesel Electric where I bought new ones and pumped them to max 100 psi.
    They say when doing that, it is a one-time off and has to stay that way.
    Kalahari Safari
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
  12. The Following User Says Thank You to Kalahari Safari For This Useful Post:
  13. #8
    Feb 2013
    Thanked: 92
    I also recall Diesel Electric doing it.
    Watch out for going too stiff, you must still be able to close the roof. They can't be deflated again, so if you go too stiff you are buggered. Luckily replacing them shouldn't be too expensive, but still...
    Please give feedback about the install, how did it work out in the end etc?
    You probably heard people saying Africa is not for sissies. Well, neither is it for wussy equipment.
    Man who dies with most gear wins!
  14. #9
    Jan 2017
    Thanked: 570
    Quote Originally Posted by Kalahari Safari View Post
    Thanks. That confirms what I thought. I bought 3 different lengths when I was developing my canopy. They would only take them back if they were "unpumped", because pressure setting was a once off thing. I test fitted, returned the 2 that didn't fit, and then had the right sized units pumped to 120psi
  15. #10
    Thanked: 160
    They can be pumped multiple times BUT not deflated i.e. if you go over the right mark then you need to buy new ones.
    Road Queue in Silverton will pump them for you...
    2014 Land Cruiser 76 SW with extras
    2019 Jaguar Inkwe 4 Offroad Caravan
  16. The Following 2 Users Say Thank You to Trevor_Mathews For This Useful Post:
  17. #11
    Thanked: 234
    https://lani4travel.com/fitting-sola...o-the-cheetah/
  18. #12
    Thanked: 234
    Quote Originally Posted by Mariuslg View Post
    They couldn't help me with the struts I had.
    Autozone in Wonderboom fixed them for me without a problem.
  19. #13
    Thanked: 28
    Thanks for the feedback and good to know as they are on my doorstep!
  20. #14
    Thanked: 38
    I know you can get your abs pumped at Virgin Active for sure! Not sure about your struts though!
    Mahindra Scorpio Suv 2015 2.2 mHawk 4x4 7 seater
    Summit Everest trailer
    Mahindra XUV500 W8 2013
