DIY Canopy Build
Results 1 to 7 of 7
    Thanked: 42
    Default DIY Canopy Build
    Hi
    I decided to make a canopy for our family 4x4 trips and "homework".
    I made the frame from steel because at the time I could not weld aluminium. I also wanted it strong to load stuff on top.
    I made a bolt on roof rack.
    Roof rack notching.
    I installed rubbers around the door frames to keep out the rain and locks on the doors. I pop riveted alu square tube to the rear door to stiffen it.
    I removed the AC motor from this 10L compressor and bolted this DC compressor onto the tank and wired to the existing pressure switch.
    I ran a pipe to the other side with quick connector for convenience.
    Besides pumping the wheels after 4x4ing it comes in handy for pumping the bicycle wheels before hitting the trails,
    but mostly for boasting to other 4x4 enthusiasts "inbuilt compressor whoooo"
    I installed LED strip lights but didn't realize I had bought the purple ones. You can't see nothing but it's nice to set a mood.
    I installed riv-nuts for the front roof rack.
    I bolted the legs in place and used a straight edge from the roof rack on the canopy to mark the height of the legs.
    The roof racks line up perfectly. The front one causes vibration and wind noise when going over 100km\h so I remove it when I'm done using it.
    The heart break begins. I wanted the canopy roof to be at the same level as the bakkie roof so I welded the roll bar to the table to lower it to fit under the canopy.
    Here is the canopy and roof racks in action when I redid my ceilings (homework).
    It's not the nices looking canopy but overall it does the job, is robust, didn't cost as much as buying one and I enjoyed the build.
  2. The Following 5 Users Say Thank You to moseswal For This Useful Post:
    Gaborone, Botswana
    Thanked: 1195
    Default Re: DIY Canopy Build
    Well done.
    Kobus
    Thanked: 42
    Thanks Kobus
    Thanked: 42
    More fab work
    Mar 2019
    Well done, it looks awesome. Nice to see what can be done at a fraction of the cost compared to the "off-the-shelf" ones.
    I am also busy with my project, building my DIY camping canopy. Will post some pics....
    UPDATES: Pics of canopy fitted on the Rok. Fits very well. a Few minor changes, but otherwise VERY happy!
ID:	525651Click image for larger version.
ID:	524763   Click image for larger version.
ID:	524764   Click image for larger version.
ID:	524765   Click image for larger version.
ID:	524766   Click image for larger version.
ID:	524767   Click image for larger version.
ID:	524768   Click image for larger version.
ID:	524769   Click image for larger version.
  7. The Following 6 Users Say Thank You to Latitjuig For This Useful Post:
    Jan 2016
    king william's town
    Thanked: 423
    Looks great, well done...
  9. The Following User Says Thank You to haboob For This Useful Post:
  10. #7
    Thanked: 42
    Latitjuig, it looks amazing, love the angles on the sheet metal wool.
