Fooling Around with a Middle Aged Gypsy.......with Pics - Page 8
Page 8 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 141 to 160 of 260
  1. #141
    Bethlehem
    Thanked: 2881
    Default Re: Fooling Around with a Middle Aged Gypsy.......with Pics
    Well..........just spoke to my two eldest kids, they're at Lush in Clarens.
    Its raining cats and dogs there.
    The little vantjie sounds dry, and they're enjoying it immensely............sleeping high, dry and mighty, looking down on all the poor sods around them in their tents
    I cant wait to have it back, want to do the lekker stuff next week........:
    INTERIOR
    1) Sort those lift up boards under the mattresses........................................ .................................................. ...DONE
    2) Clad the frame fronts with alu chequered plate............................................. ...............................................DONE
    3) Sort that front window with an alu square frame, and get canvas utility pockets in there...................................DONE
    4) Remove all cupboard/cabinet doors, replace with canvas............................................ ...................................DONE
    5) Utilise the door for canvas utility bags for cutlery, maybe crockery too, braai stuff, etc etc. I'm actually considering utilising the whole door "real esate", as Henk puts it, for this. I dont want to get in and out the whole time to get to stuff............................................. ..........DONE
    6) Small utility "box" at the front bed for cell phones, keys, etc etc - there's a 10cm space available next to the 3/4 mattress..DONE
    7) Clad wheel arches with veneer - I'm not happy with the sloppy look, even though they will be "hidden" in the cupboards...TO DO
    Decide on what fridge to use. 12 volt Double Door or a "flip up" National Luna.............................................. ...DONE
    9) VERY sturdy frame for said fridge. This is where the lower National Luna is a huge advantage, no tall fridge swaying around........TO DO
    10) Wire up 220volt to inside multi plug, and outside multi plug. That's the ONLY 220v I want...............................DONE
    11) Charger and DC Battery hidden under Cupboard, on axle.............................................. ..............................TO DO
    12) 2 x Lumeno LED's on roof, remove existing ones. Also one LED outside. And 2 smaller ones at the rear bed for reading.....TO DO
    13) Solar input at existing 220v input to quick connect solar panels............................................ ..........................TO DO
    14) Remove ALL existing wiring, coupler wires included, and re-wire from afresh. Nice , tidy and hidden as much as possible........TO DO
    15) Decide...........re-do the existing (nice-ish) wooden veneer inside, or paint. I''l probably paint for a new fresh funky look............DONE
    16) Curtain rails or blinds. I'm leaning towards blinds I think, permanently fixed, just open or close the thing as we want................TO DO
    17) Extra cupboard next to the fridge. Alu frame, very thin wood, cover with canvas............................................ .....TO DO
    1 Cover existing cupboard with canvas, also with zipped canvas door. I want all cupboards/cabinets to look the same...............DONE
    19) Same with existing little booze cabinet - canvas covered, zipped front. This can become a bathroom cabinet thing for the females..DONE
    20) (edit) - I'll probably also like an extra LED here and there inside a cupboard/cabinet here and there
    21) Replace old window handles/plastic thingies.......................................... .................................................. .............DONE
    22) New Door Stop, same as Xplorer........................................... .................................................. ............................DONE
    I think that's about that. I'll get to the exterior later, and also the chassis - but not really much to do there. I may want to get it a bit of a lift. And replace those wheel spats with something blacker/bolder.
    "Everything You See, I Owe to Spaghetti" (Sophia Loren)
  2. #142
    Bosveldsig, Nylstroom/Modimolle
    Thanked: 175
    Hi Petri,
    This is what we did on the BL-Kewer.
    First had it at the back and it did not work, moved the strip to the front but not all the way.
    Used 3 mm LED's, the 5 mm were to bright, found that they must be about 10-20 mm away from the front edge else it sort of blinds you when you stand in front of it.
    Suggest you play around with it a bit before permanently fixing it (was a bit of a job getting it off and stuck back on again x 3 before final try #4)
    Just place the switch where you can easily reach it and don't bump it when you place items in the cupboards, moved ours out of harm inside.
Name:	IMG_20190420_124024 (1024x768).jpg
ID:	526147   Click image for larger version.
Name:	IMG_20190420_124042 (1024x768).jpg
    Danie & Marinda - die wiele is rond, dus moet hulle hardloop - afgetree nou leef ons net.
    2017 BL - Kewer B1115 RUS WA GP - bos en kamp tyd
    2016 Ford Fiesta Ecoboost - daaglikse ryding
    2013 Ford Ranger 3.2 DC XLT 4x4 - nuwe rondloop ry ding, nou sleep ons! (2017)
    2011 Echo 4, die RUSWA-ZN - (verkoop 44 000 km)
    2010 Ford Ranger 2.5 DT DC XLT 4x4 - rondloop ry ding met "bietjie ekstra" krag (Verkoop 177 000 km)
    2005 Chev Aveo - Afgeskryf (2016 130 000)
    2005 Opel Corsa 17DTi - Geruil (warm enjin 180 000)
    2003 Opel Corsa 17DTi - Geruil (warm enjin 150 00)
    2000 Nissan Hardbody - Geruil (pyne by die duisended 52 000 km)
    1998 Opel Kadett - Dogter se wiele geword in 2003 (baie warm enjin 116 000 km)
    1990 Datsun 1800 short wheelbase - Pa se ou plaas bakkie, na die Nissan die pad gevat het met sy probleme in 2003 (117 00km)
    1990 Hilux 2.4D - en hy kon loop, pomp en top gewerk aan.
    1984 Opel Commondore - het gehardloop
    1983 Safary 3 karavaan - verkoop en begin tent in 2000 (51 000 km)
    1980 Ford Granada 3.0 - warm enjin afgeskryf
    1969 VW 1600 TL - geen einde nie, warm enjin en geruil
    1968 VW 1600 L - geen einde en baie warm enjin, verkoop in 1998 (328 000 myl/525 000 km)
  3. The Following User Says Thank You to Danie S For This Useful Post:
  4. #143
    Bethlehem
    Thanked: 2881
    Die vantjie staan nog by die Lush Festival venue naby Clarens - die pad is BAIE diep slote getrap en BAIE modder, so ek sal hom so die naweek se kant gaan oppik. Gaan hom onnodig opneuk deur daai spore, die Prado se pens het gesleep op plekke.
    Het dan lekker baaaaaie tyd om hom mooi op te dollie
  5. #144
    Bethlehem
    Thanked: 2881
    Front window frame sorted, MUCH stiffer now. Used alu frames and Connect - Its lying around.
    I intend having a canvas baggie thingie made up there, nice easy to reach space for the one sleeping there
  6. #145
    Bethlehem
    Thanked: 2881
    Those canvas baggies - something like this (in yellow). For magazines, maybe a cellphone, charger, etc etc - stuff like that
  7. #146
    Bethlehem
    Thanked: 2881
    Nice open and big space underneath the front bed. I'll decide if I want compartments there, and where.
    Lid is easy to lift, and lift wide open. Had to cut a corner away though, for the little kassie that's in the way. Nothing serious.
    That's all for now Folks.........next week I'll tackle that rear bed and finish that off.
ID:	526762   Click image for larger version.
ID:	526763   Click image for larger version.
  8. #147
    Thanked: 175
    Nice, put the corner you cut off on the bed frame and secure.
    Really start to look good, cant wait for the finished product
  9. #148
    Bethlehem
    Thanked: 2881
    Quote Originally Posted by Danie S View Post
    ............nie daaraan gedink nie thanks
    I'm in 2 minds today........paint the interior or not. Guess I'll paint - just being lazy now
  10. #149
    Bethlehem
    Thanked: 2881
    Rear bed is in. Nice and huge, 150 x 187cm. Huge space underneath for soft stuff.
    Had to re-cut the "fixed" part......the larger lid did'nt fit through the door........another lesson quickly learnt in the exciting world of caravan renovations..........whatever you do, first see if it fits through the door, or do it inside
    I'm thinking either alu plate at the front.........but also have a sort of idea here. Webbing....?? Nice, strong, light, and you can see what's packed underneath. I think webbing could be something different.
    Maybe attached with hooks to the frame, so that you can remove it if necessary to take out something without lifting the lid.
    Lid will HAVE to get shocks - its a moerofa heavy mattress.
  11. #150
    Bethlehem
    Thanked: 2881
    Space along the bed is VERY small.......but yes. I was actually thinking of making it one full width bed, but no. Maybe even some sort of bedside canvassy kassie thingy, for magazines/phones/attachment points for reading lights/Marlboro's
    We'd still be able to sit on the mattress' edge for getting our PJ's on........or off
  12. #151
    Bethlehem
    Thanked: 2881
    Some small stuff done, like new window fittings riveted into the new alu frame, new door stopper, etc etc etc.
ID:	527070   Click image for larger version.
  13. #152
    Dec 2014
    Thanked: 1491
    Why not extend the fixed part of the base to the edges and you have your bedside table, with additional space under it?...
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  14. The Following User Says Thank You to JohnnoK For This Useful Post:
  15. #153
    Bethlehem
    Thanked: 2881
    John, something like this??
  16. #154
    Bethlehem
    Thanked: 2881
    Ek het nou al weer 'n Hot Dog Stalletjie, die keer darem een met slaapplek
    Removed all the cupboard/cabinet doors.........if ANYONE has any use for them, free to a good home. Its from a 83 Caravette 4. But please be quick Guys, if you need them shout now. I'm chucking them on Monday.
  17. #155
    Bethlehem
    Thanked: 2881
    Door removed
  18. #156
    Bethlehem
    Thanked: 2881
    Removed those "knoppe" that locks the roof, filled with silicon.
ID:	527133   Click image for larger version.
  19. #157
    Bethlehem
    Thanked: 2881
    All fronts to be replaced with zipped canvas
ID:	527135   Click image for larger version.
  20. #158
    Bethlehem
    Thanked: 2881
    And definitely painting the veneer.......HUGE job, I'd have to fill up all the bad spots/old screw holes/angles and finish of to get a smooooooth finish.
    Also removed the brown strips, I'm thinking light grey (almost white) with a bit darker finish strips.
    I think it would look nice with an alu chequered plate here and there, maybe a piece of webbing under the beds, etc etc etc, and "vrolike" blinds, something light with blueish/greyish/maybe even redish stripes.
    I want funky and functional.
  21. #159
    Bethlehem
    Thanked: 2881
    This is my sort of idea with the canvas fronts.
    VERY graphic artwork, definitely not for sensitive viewers
  22. #160
    Dec 2014
    Thanked: 1491
    Exactly like that, and you score a bit more pakplek under the table, too.
    Maybe close the front and sides and hinge the top to flip up?
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  23. The Following User Says Thank You to JohnnoK For This Useful Post:
