Fooling Around with a Middle Aged Gypsy.......with Pics - Page 6
Page 6 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 101 to 120 of 294
  1. #101
    Thanked: 895
    Default Re: Fooling Around with a Middle Aged Gypsy.......with Pics
    Sika should be fine for that, remember, pop rivets are not watertight...
    Use blind rivets that are closed / sealed on the end. Once you have drilled the hole put a squirt of sealant in the hole before inserting the rivet. It works very well to prevent moisture ingress.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  2. The Following 2 Users Say Thank You to Paul#25 For This Useful Post:
  3. #102
    Bethlehem
    Thanked: 4242
    Thanks for great advise - again.
    My plan is to have some sort of canvas storage bag thing there, for books/phones/whatever, and have the bag "sunken" into the veneer (that's already taken off there anyway), hence I'm thinking of something sturdy(ish) to attach that bag to.
    The rest of the timber underneath and lower looks and sounds 100%, I've poked everywhere with a long needle and knife and I dont get anything soft/moist/rotten.
    I think I'll just put a frame in there with one or 2 "uprights".
    2008 Mercedes Benz CL 500........................"Bullet"
    2006 Mercedes Benz C 180K........................"Sussie"[/COLOR]
  4. #103
    Bethlehem
    Thanked: 4242
    Hoekom is almal so stil..........wat sien julle wat ek nie kan nie
    Of is almal stomgeslaan deur my incredible vakmanskap??
  5. #104
    Apr 2012
    Thanked: 65
    Lol, ek geniet jou vordering, ek verwag by Maandag 'n update dat hy klaar is
    2008 ISUZU KB300 D-TEQ 4x4 LX AUTO
  6. #105
    Struisbaai
    Thanked: 816
    Ek sal raas as ek sien daar is iets waarvan ek nie hou op my toekomstige karavaan.
    Jy doen baie goeie werk daar Petri.
    2015 Land Cruiser 79 D/C V8 Diesel Turbo
    2000 Prado 90 KZTE SWB.
    Bush Lapa Boskriek No 607 - Die Kriek
  7. #106
    Bethlehem
    Thanked: 4242
    Just received the bed frames. Nice and big, and VERY light.
    I've thought of having an island bed at the rear, but it just wont works - too narrow at the sides, and the overhead cupboards wo'nt be user friendly.
    Will just ask Jaco to move one of the "feet", and then I'll make it an off-center bed.
    Made the frames higher than it were, 38cm high.
    The front :
  8. #107
    Bethlehem
    Thanked: 4242
    Rear bed.........will become an off center double in an hours time
  9. #108
    Bethlehem
    Thanked: 4242
    Nice height, I'll se what I "clad" the fronts with, most probably black alu plate
  10. #109
    Bethlehem
    Thanked: 4242
    I'll be moving the rear bed to the LHS of the van (to the Right hand side in Pic), there are some rakkies and stuffies that I plan to make from canvas then right at the "foot" of the bed.
    I may also want to do a lightweight, canvas clad low little wardrobe or something against the opposite wall, and then there will be enough space to get it there.
    An island bed just wont work here, and LOTS of space wasted in this particular setup caravan.
    I'll see how to attach the bed frames.........just through the floor, or maybe add an alu strip or something in the width, and make the floor even "tauter".
  11. #110
    Thanked: 229
    No need for a strip if your floor is as solid as it looks.
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
  12. #111
    Bethlehem
    Thanked: 4242
    Ag Robbie, I need something solid underneath to secure the fronts to anyways, so can just as well put a 2mm or so alu square underneath and bolt it down for keeps.
    Either alu plates or I'm also thinking zipped canvas - you then dont need to lift the lids every time. But then I'll need something "solid" to stop stuff sliding around
  13. #112
    Bethlehem
    Thanked: 4242
    And the Island Bed is now an Off Center 195 x 155 cm Double bed
    MUCH nicer, lots of space at the wall for an additional little shallow cupboard thingie
  14. #113
    Bethlehem
    Thanked: 4242
    OK.............that front panel is a lot stiffer, added a DIY jobbie alu angle from inside the nose cone, and it works.
    Monday:
    1) Sealer on Floor, various coats - thanks for Tip
    2) Secure bed frames on floor, will figure out how to sommer integrally also further stiffen/strengthen the floor
    3) Reinforce the nose with alu square, and also a new alu window frame.
    Tuesday:
    To my tjommie at Battery Sentrum :
    1) Spacers
    2) Check and "find fault" underneath and repair/replace
    This needs to be sort of "towable" next weekend, my 2 oldest kids want to use it at Lush in Clarens.
ID:	525537   Click image for larger version.
  15. #114
    Thanked: 303
    Petri, maybe put a full length flat bar underneath the feet of the bed frames to spread the load a bit wider than the point load of the individual feet.
    Neil
  16. The Following User Says Thank You to neoT For This Useful Post:
  17. #115
    May 2018
    Halfway House
    Aaag each of them has a place.
    Those new Ratels and Xplorers etc etc are also SO nice.
    But ja, this is something "different", I wanted something cheap to turn into something funky and sort of personalised for the odd weekend away, the kids can also use it, and something to stay in when we go fishing and boating at Sterkfontein and Midmar and so on.
    We're not really this "dedicated" caravanners/campers (yet), so a R 300 000 van just doesn't warrant the financial outlay for now.
    When you go fishing at Sterkies, stay in the chalets. Especially if you are a pensioner they are so cheap its not worth towing the "van" or camping. However, a warning, bring your own camping cutlery and crockery etc as the stuff has been stolen so don't rely on the chalets being fully kitted out as they are supposed to be! Never the less, an absolute bargain of note. The other problem is you can't tow the boat and the caravan so you end up having to take 2 vehicles with 2 lots of petrol and 2 x tolls etc. You could tow a "train" which I have done before but consider it to be too dangerous and frankly I feel should be forbidden.
  18. #116
    Swakopmund
    Thanked: 192
    You know that yoir heading sounds a bit weird? I thought gypsy woman.....
    Or was I the only one? Common, confess!
    2014 Land Cruiser 76 V8 SW
    1994 Defender TDi 200
    Drive it like you stole it!!
  19. #117
    Dec 2014
    Thanked: 1794
    John - if you ask for Sika Flex in Bethlehem, the usual reply is "Nee Oom maar die Sealy is ook 'n goeie matras".
    Then the Oom is going to have to go and toetsrit one of his cars and hit the road to Bloem...
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  20. #118
    Dec 2014
    Thanked: 1794
    Monday:
    1) Dilute the first coat so it soaks into the ply, then let it dry enough to allow you to walk on it without being taai like fly paper. Apply the next few coats.
    I'd get 75x75x2 steel plates and put them under the feet and under the floor to spread the load. Use a bolt through the middle to secure the frame and 4 gutter screws on each corner with 2 nuts on the bottom and the end of the screw peened over with a hammoer.
    A dab of Duram 195 to seal the holes underneath after that.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  21. #119
    Dec 2014
    Thanked: 1794
    Quote Originally Posted by neoT View Post
    Or this, but I'd still also go underneath to give the floor a bit of relief, too. Or those monster fender washers would do, too.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  22. The Following User Says Thank You to JohnnoK For This Useful Post:
  23. #120
    Dec 2014
    Thanked: 1794
    Quote Originally Posted by JJ-Namibia View Post
    Nope, you aren't alone, was a bit of a let down to start reading further, but it has turned out a lot more informative for me, so a win.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
