Fooling Around with a Middle Aged Gypsy.......with Pics - Page 2
Page 2 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 21 to 40 of 294
  1. #21
    Bethlehem
    Thanked: 4242
    Default Re: Fooling Around with a Middle Aged Gypsy.......with Pics
    John Post 19.........thanks a MILL Man!!
    Shocks won't "soften" the ride, they damp out suspension oscillation.
    .........meaning "side by side" movement?? Sorry man my British is somewhat - well - not so British.
    Thanks again, you have very logical answers.
    Im clearly NO expert here, but I think if tyres can be deflated a bit, and maybe at a later stage shocks added, and wieght saved wherever possible, the sum total of all of that will give a "softer/smoother" ride for the fittings etc etc inside.
    edit..........John the axles are under the leaf packs.
    2008 Mercedes Benz CL 500........................"Bullet"
    2006 Mercedes Benz C 180K........................"Sussie"[/COLOR]
  2. #22
    Thanked: 229
    How heavy is the nose.At the ball.
    if too light, the spare wheel is the sway culprit.
    Does it have angle iron strip all around strengthening the join between floor and the walls.
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
  3. The Following User Says Thank You to Robbief For This Useful Post:
  4. #23
    Bethlehem
    Thanked: 4242
    Quote Originally Posted by Robbief View Post
    Robbie - jy slaan die spyker op die kop dink ek.
    1) Havent weighed the nose, but I suspect its light.......yesterday when towing it, it had a sort of "bounciness" on the towball. I didnt feel it but saw it in the rearview mirror.
    2) I actually sort of tried it out, swaying the Prado gently, and yes, it does have a very definite "rear end sway" in it before settling down (quickly, must say).
    It also stands too high behind the Prado, I'll definitely be moving my gooseneck down.
    I would'nt be comfortable with this as it is now, swerving for something at speed. Not major, but yes, I didnt feel confident.
    Thanks a LOT for drawing my attention to this!!!8)
    3) Dunno about that angle strip - it has an alu strip underneath, but not sure how it was done, will look, thanks a mill for that.8)
  5. #24
    Struisbaai
    Thanked: 816
    Petri why not build the beds like a drawer system.Using 25mm alu square tubing.Attach that to the walls somehow for extra strength and build drawers on slides under the bed.
    2015 Land Cruiser 79 D/C V8 Diesel Turbo
    2000 Prado 90 KZTE SWB.
    Bush Lapa Boskriek No 607 - Die Kriek
  6. #25
    Bethlehem
    Thanked: 4242
    Quote Originally Posted by LC Man View Post
    Thats what Im thinking.
    Center drawer under the bed, and 2 "flip up" lids either side.
    And yes, attach the "sides" to the wall. One kan mos camouflage them under that alu plate?? If not, a row of bolts outside may not look THAT bad anyway. Its there for a purpose.
    I'll just have the mattresses made up in 3 sections, anders gaan dit my irriteer.
    En ek kan dalk myself seermaak
    .............Jy moet se hoe jy wil he ek moet maak, jyt eerste opsie
  7. #26
    Dec 2014
    Thanked: 1794
    Probably not the most sensible word, in hindsight..Up and down movements of the axle as it travels the road.
    In a vehicle, shock absorbers reduce the effect of traveling over rough ground, leading to improved ride quality and vehicle handling. While shock absorbers serve the purpose of limiting excessive suspension movement, their intended sole purpose is to damp spring oscillations. Shock absorbers use valving of oil and gasses to absorb excess energy from the springs. Spring rates are chosen by the manufacturer based on the weight of the vehicle, loaded and unloaded. Some people use shocks to modify spring rates but this is not the correct use. Along with hysteresis in the tire itself, they damp the energy stored in the motion of the unsprung weight up and down. Effective wheel bounce damping may require tuning shocks to an optimal resistance.
    Spring-based shock absorbers commonly use coil springs or leaf springs, though torsion bars are used in torsional shocks as well. Ideal springs alone, however, are not shock absorbers, as springs only store and do not dissipate or absorb energy. Vehicles typically employ both hydraulic shock absorbers and springs or torsion bars. In this combination, "shock absorber" refers specifically to the hydraulic piston that absorbs and dissipates vibration. Now, composite suspension system are used mainly in 2 wheelers and also leaf spring are made up of composite material in 4 wheelers.
    https://en.wikipedia.org/wiki/Shock_absorber
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  8. The Following User Says Thank You to JohnnoK For This Useful Post:
  9. #27
    Thanked: 229
    Anything bolted to the walls for strength must have something inside and outside
    to stop the bolts compressing [squeezing] the walls.
    Robbie
    Fortuner D4D
  10. The Following User Says Thank You to Robbief For This Useful Post:
  11. #28
    Rangeview Krugersdorp
    Thanked: 1201
    Sadly the "walls " are hollow without any strength.
    Hyundai Getz 1.6 2010
  12. #29
    Thanked: 213
    Petri sorry ek sal moet vra, wat sÍ jou Blond van die gedoente?
    Watch this space ...
    Currently enjoying my new platkar: Alfa MiTo Quadrifoglio Verde - she's a beauty!
    JKU Rubicon Pentastar (sold )
    JKU CRD (sold)
    XJ 4liter (sold )
  13. #30
    Bethlehem
    Thanked: 4242
    Quote Originally Posted by Jeepiscool View Post
    "Dit lyk cute Bokkie, hoekom staan hy so hoog?"
  14. The Following User Says Thank You to Petri Oosthuizen For This Useful Post:
  15. #31
    Dec 2014
    Thanked: 1794
    I must admit, when I read the title of this thread I wasn't expecting an old caravan...
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  16. #32
    Thanked: 216
    Petri I have never towed a caravan as I have no use for them, but maybe you should do the planned spacers to the axle before deciding to lower the gooseneck on the Prado?
  17. #33
    Bethlehem
    Thanked: 4242
    Quote Originally Posted by Wicd View Post
    Petri I have never towed a caravan as I have no use for them, but maybe you should do the planned spacers to the axle before deciding to lower the gooseneck on the Prado?[/COLOR]
    Wicus ja, ook nogal so gedink. Anders is die g/neck nou weer te lag vir die bote en bike trailer.
    I definitely think Robbie is on the money with that rear spare contributing to the (slight) sway.
    But will fine tune that - when packed and a little more weight on the nose etc etc I think all should be well.
    Or. then, if all else fails, move the spare and carrier somewhere else.8)
  18. #34
    Oct 2012
    Thanked: 82
    Dude ! I just read the title, and now Iím a bit disappointed that itís only about a caravan. Cool lookin caravan tho
  19. #35
    Sinoville Pretoria
    Thanked: 567
    Petri,
    As jy enigsins grondpad en ook sinkplaatpaaie gaan gebruik, vervang alle houtskroefies in deure ens met boutjies en moertjies. Daai deure skud los in die eerste kilometer op n sinkplaatpad.
    En maak seker jou yskas se deur gaan nie oop op grondpaaie nie, met ekstra knip
    En ek dink nie jy moet beddens ens aan beide vloer en kante vasmaak nie. Die woonwa fleks en gaan nie hou van koppelings wat vloer en muur verbind nie
    Henk Pretorius D4 3,0 SDV6 HSE
    EX AFRICII SEMPER NOVUS
  20. The Following User Says Thank You to julius caesar For This Useful Post:
  21. #36
    Bethlehem
    Thanked: 4242
    henk ja dankie vir die raad - ek het nogal vanoggend aan dieselfde ding gele en dink - ek wil nie te veel neuk met die mure nie. As daai mure gaan flex teen die staalraam gaan iets ingee.
    Eventually wil ek maar al die deure met canvas vervang - maar thanks vir die bolt and nut tip.
    Ek dink ek moet ALLES onder heuphoogte in die van strip en klaarkry, die 2 beddens se rame laat maak, en van daar af kyk na die yskas opsies en so meer.
    Please keep it coming Guys, you are being FAR more helpful here than you can imagine.8)
  22. #37
    Brits
    Thanked: 432
    Kyk eers hoe is die huidige hout rame vas gesit. As deel van die struktuur aan die nure vas is sal jy dit weer so moet doen anders gaan die mure te veel flex.
    Renault Duster 1.5Dci 4WD
  23. The Following User Says Thank You to JuanB For This Useful Post:
  24. #38
    Dec 2014
    Thanked: 1794
    Bear in mind, this could be from the weight of the tyre contributing to the swing from an inertia point of view rather than making the hitch too light.
    IOW, the weight of the spare is adding to the momentum of the swing.
    Go for a drive on a quiet road and do a test "swing" of the wheel to induce a sway, then remove the spare and do the swing again, now, put the spare on the A frame and try again, should give you an idea of the effect it has.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  25. The Following User Says Thank You to JohnnoK For This Useful Post:
  26. #39
    Bethlehem
    Thanked: 4242
    Quote Originally Posted by JuanB View Post
    Hoor wat jy se BAIE dankie!!!8)
    ......gou gaan kyk, daar is nie 'n bestaande "raam" nie en die houtstruktuur raak nie heeltemal aan die mure nie, so lyk my ek is OK daar.
  27. #40
    Feb 2013
    Strand
    Thanked: 81
    Hier is die verduideliking vir jou swing probleem:
    https://www.youtube.com/watch?v=4jk9H5AB4lM
