Results 1 to 7 of 7
    Feb 2015
    johannesburg
    Thanked: 31
    Default My Supercab Fridge mod
    just finishing up my little project, and thought i'd share...
    Because i use my van for work and leisure, i made a shelf with a frame for toolboxes (houses 6 ammo boxes with tools and spares etc), and then when the weekend hits, i replace the shelf with my birding shelf.
    The idea was to make the area behind my seat modular, replacing the shelf depending on the purpose.
    Toolboxes for work:
ID:	524448Click image for larger version.
    Shelf for Fridge for when we go camping / Birding:
ID:	524450Click image for larger version.
ID:	524451Click image for larger version.
ID:	524452Click image for larger version.
ID:	524453Click image for larger version.
ID:	524454Click image for larger version.
ID:	524455Click image for larger version.
    now just to see what items to put in the ammo boxes (probably eating utenils, braai stuff, camera etc...)
    third shelf will be a solid board with thick sponge for when i take the dog for walkies...
    All exciting stuff this... :-)
  2. The Following 6 Users Say Thank You to Philyian For This Useful Post:
    Jan 2016
    Pinetown
    Thanked: 437
    Default Re: My Supercab Fridge mod
    That is flippen kiff. Very well done and practical too.
    Si Vis Pacem Parabellum
    2012 Hilux 2x4 D/L
    A few basic mods.
  4. The Following User Says Thank You to Wandering_Soul For This Useful Post:
  5. #3
    Maputo
    Thanked: 47
    The extra rattles that this would create will drive me insane, but nice idea.
    Gauteng
    Thanked: 957
    That was exactly my idea when I wanted to replace the Everest with a SuperCab. However, I see that space is a bit of a squeeze. It looks big when it is empty but decided in the end to keep the Everest.
    Very well executed anyway!
    May 2012
    Morgan Bay
    Thanked: 123
    Did the same with my supercab and a 80l National Luna.Moved my jack etc out compartment underneath freezer to back of bakkie.Dont want to retreive these with a flat and loaded freezer.Works well and nice to have coolies in Kruger without having to get out.Put a Hella plug in tool compartment and routed through to battery
    Thanked: 12
    Quote Originally Posted by Philyian View Post
    Toolboxes for work:
    Hi,
    How did you fix the plywood to the cab or is it loose.
    Want to do exactly the same.
  9. The Following User Says Thank You to JTF For This Useful Post:
  10. #7
    Feb 2015
    johannesburg
    Thanked: 31
    Quote Originally Posted by JTF View Post
    Hi,
    I used rivnuts. The 2 holes already existed In the child seat anchor points. So all i did was put a rivnut in, and make sure the holes line up of my board.
    After doing some reading regarding where others also put a fridge at the back, they advised to anchor it properly, as one guy olled his cab, and the fridge almost landed on his head. So i drilled 2 more holes, and added another 2 rivnuts
ID:	525585Click image for larger version.
  11. The Following 2 Users Say Thank You to Philyian For This Useful Post:
