220V - best quick coupling entry point into Hilux DC
Results 1 to 9 of 9
    Fourways, Jhb
    Default 220V - best quick coupling entry point into Hilux DC
    My fridge is located in the back of my Hilux Double Cab.
    For 220V charging I'd like to install a permanent 'quick coupling' solution when using an extension cable at chalets etc..
    Where is the best point to run a 220V cable into the cab?
    Ideally I'd like this to be near the back of the cab - as opposed to via the firewall.
    All advice welcome.
    Toyota Hilux 2.5 D4D SRX https://www.facebook.com/wild.safaris.5/
    The greatness of a nation and its moral progress can be judged by the way its animals are treated - Ghandi
    Jan 2017
    Default Re: 220V - best quick coupling entry point into Hilux DC
    Ive been investigating this same idea. Caravan plugs look they might work, if you can find a male inlet and a female extension lead.
    04 Discovery II V8 Auto - The Duchess
    Jan 2009
    Caravan Female Coupler at the end of you lead and caravan inlet box in your canopy.
    Both available at 4x4 Direct or your nearest caravan shop.
    The word Dzombo is derived from the Tsonga word Dzombolo meaning to wait for something that is slow in coming.
    Named after one of the Magnificent Seven, sadly killed by a Poacher Oct 1995 @ 50 years old.
    Dzombo1 Ex Army LR TD upgraded to 200 Tdi
    Dzombo2 1997 Discovery 300Tdi man
    Dzombo3 2000 Jeep GC 3.0 Diesel a/t
    Dzombo4 2005 Hilux KZTE Legend 35
    Platkar 2017 Fortuner 2.8 4x4 Auto.
    Camping in a Bokwa.
    Bushveld
    I'm also thinking of doing the same inside my canopy but running it through a distribution box first for the circuit breakers. Only thing is I'm looking for a real small DB box as I'll only really be connecting a CTEK charger for the battery and then connecting my fridge to it as well. The rest like lights can still on the battery from the fuse box.
    Where would one find a small DB box fit for purpose without having a big white box you get from builders?
    Jan 2009
    I bought a plug type box think they call it a 4x4 (referring to the size), with a blank cover, as well as a din rail mounting circuit breaker, mounted that on a short piece of din rail on the inside, with the appropriate hole on the blanking plate and used entry glands via the knockouts for cable entry and exits.
    Camping in a Bokwa.
    May 2012
    Quote Originally Posted by Choppie81 View Post
    You can find them at the electrical wholesalers or Builders should have
    CBI Ready Board Mini DB. Easy to modify and expand on
    (SUPERCHARGED ZOMBIE ZOOK)
    (DEFENDER 130 300HP V8 "MR PUGLY")
    --->YouTube channel<---
    Hendri Mouton (Zombie)
    Bushveld
    Quote Originally Posted by Sandboarder View Post
    Thanks, I’ll go and have a look.
    Dec 2006
    The following works for me.
    I have installed one of the caravan connector boxes at the back of the canopy to connect the lead from the plug (included a BH for solar panel), and inside canopy I have one of those 220V multiplugs with surge protector
    (Double click on thumbnails turns pic's right side up)
Name:	Canopy 220V resized.jpg
ID:	524760   Click image for larger version.
Name:	Canopy 220V & Solar.jpg
    Jan 2016
    king william's town
    Buy about a 30m reel with electric cable used by builders. Mount this where you want it, fitting the plug on the outside.
    When you need it you just pull the plug to the power source, fit the caravan plug (if needed), t just plug in the three prong plug if it is not needed. You then plug the fridge and whatever else, into the reel and it is done, you have power.
    When finished, unplug the leads from the reel. Roll up the reel and you are ready to go. Works well for me...
