Diy shower arm
Results 1 to 20 of 20
Thread: Diy shower arm
    durban
    Thanked: 1121
    Default Diy shower arm
    My clients original plumber must have been 4 foot tall because he put the shower arm so low. There was nothing in the shops that could fix this so I had a bash at making my own shower arm. I machined a cylinder and flange to accomodate the riser pipe and then tig weld some stainless pipe to get the correct height. I then made a very time consuming bracket and it came out real nice. I need to either find a pipe bending company or buy or make my own dies because tig welding bends on small pipe is very time consuming, especially if you are a bad welder.My 6'3" client is very happy.
  2. The Following 12 Users Say Thank You to plunger For This Useful Post:
    Dec 2014
    Thanked: 1920
    Default Re: Diy shower arm
    Looks good!
    How much did your 6'3'' client have to hoes for the bespoke bracket?
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Apr 2017
    Durban North
    Thanked: 2081
    A lot
    durban
    Thanked: 1121
    I sold it for R450.00
    Sep 2011
    Potch/Brits
    Thanked: 583
    Waaay to cheap. Your client must appreciate you a lot!
    Now is good time to invest in a pipe bender. Always a good excuse to get more tools.
  7. The Following User Says Thank You to carlp For This Useful Post:
    Gaborone, Botswana
    Thanked: 1208
    This must have been a few hours work.
    Kobus
    JHB
    Thanked: 139
    Had a similar problem. This sorted it.
    https://www.bathroom.co.za/our-produ...mm-50030129901
    Tshwanetoria
    Thanked: 801
    In general, plumbers seem to be height disabled
    At 6'3", I VERY often encounter shower heads that are way too low.
    OT, but the same applies to FNB ATM's
  11. The Following User Says Thank You to hatjohan For This Useful Post:
  12. #9
    Tshwanetoria
    Thanked: 801
  13. #10
    Jun 2016
    Thanked: 41
    I have looked down on many a shower head in my time.
    Standing at 7foot its one of the perks of life.
    My shower head is adjustable on a rail.
  14. #11
    Apr 2017
    Durban North
    Thanked: 2081
    Absolutely not,no height issues.... shower outlet's are fitted at a average height of 2200mm ... If we did your shower for you we would stand you in the shower with the arm and rose and establish a height, so at 7ft tall you would be fine with the height until your 5'5" wife came in and said "It's to damn High, move it down"
  15. The Following User Says Thank You to Dudleytheplumber For This Useful Post:
  16. #12
    durban
    Thanked: 1121
    Quote Originally Posted by Dudleytheplumber View Post
    Dudley ,yes you would then have to put in two showers and a his ,hers diverter..
  17. #13
    Robertson/ Larissa, Greece
    Thanked: 3380
    I can so relate. I'm at 1.85m and wifey at 1.5m Constant fight about shower height!
  18. The Following User Says Thank You to Francois Theron For This Useful Post:
  19. #14
    Tshwanetoria
    Thanked: 801
    You not too old to shower at the same time?
  20. The Following User Says Thank You to hatjohan For This Useful Post:
  21. #15
    Thanked: 3380
    Never too old for certain pleasures
  22. #16
    Apr 2017
    Durban North
    Thanked: 2081
    His and hers is definitely the way to go
  23. #17
    Thanked: 948
    My mate, a 6' 8" plumber has sadly passed on. But he put a couple of units in that at 6' I struggled to reach...
    When he asked his journeyman how high do you set a urinal, he said, "...ock height"
    "The problem with internet quotes is that they are very often unverified."
    -Abraham Lincoln
  24. The Following User Says Thank You to MarcR For This Useful Post:
  25. #18
    Apr 2017
    Durban North
    Thanked: 2081
    That's basin height is Cock height., check it out, urinal need to be lower, that's where some big knobs hang out
    Quote Originally Posted by MarcR View Post
  26. The Following User Says Thank You to Dudleytheplumber For This Useful Post:
  27. #19
    Thanked: 38
    Now try that with a Urinal!
    Life starts
    where the comfort-zone ends.
  28. The Following User Says Thank You to Mick For This Useful Post:
  29. #20
    Apr 2017
    Durban North
    Thanked: 2081
    What height does she like the urinal at
