Moonshine
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 44
Thread: Moonshine
    Thanked: 421
    Default Moonshine
    Iím playing with an idea .....
    Which would be the best option-
    Direct heat .... gas cooker or an element
    Or indirect heat .... water jacket with a diesel burner
    Jun 2016
    Secunda
    Thanked: 12
    Default Re: Moonshine
    Hi Gary,
    It all depends on your budget and what you wish to achieve.
    Are you chasing higher purity or taste?
    If it is for a first time try I would suggest gas hob, since it is much easier to control manually.
    A decent thermometer at the pot and one at the top of the still.
    I played with different options and eventually settled for the electrical element route with PID controllers.
    Considering indirect heat by means of water jacket can be achieved, but I believe your economy would be less that direct heat due to other forms of heat losses and heat transfer issues/designs. But on a small scale I cannot see that it will have a huge difference.
    Last edited by Ratelrooi; 2019/03/27 at 12:42 PM. Reason: Replied on indirect heat
    2013 Nissan Navara 3.0 DCi 4x4 D/C - Rooigevaar
    2015 Nissan Hardbody NP300 2.4 4x4 D/C - Kragtige Pakdonkie
    2012 VW Amarok 2.0TSI D/C 4x2 - SOLD (Needed a 4x4)
    2010 VW CC 2.0TSI DSG - SOLD
    2008 VW Golf 5 2.0 Trendline - SOLD
    Thanked: 13036
    Gary is a dairy fabricator/builder. Complexity isn't an issue.
    Gary, it's about maintaining the correct temp of the pot and the volatile gases, as mentioned.
    Based on your background, I reckon direct heat but using PID controllers. So I'd say controlled electrical.
    Electrical is just easier. AND SAFER. Many a still has exploded because of gas.
    Thanked: 421
    Default Moonshine
    Pity.....Iíve got a diesel hot water boiler and a PHE lying in the store, doing nothing.....
    In the Dairy industry, all heat is indirect......
    So basically 2 x 2kw elements via SSRís fired by a PID controller (fuzzy logic)
    Or.... a coil in the keg
    Have a 50lt keg left over from my biodiesel days.....
    Looking for purity more than anything else.
    Thanked: 13036
    well purity needs a proper column still and even better a fractal still, heat is only a means of evaporating the alcohol at precisely the correct temps
    Dec 2014
    Thanked: 1800
    I have a heavy duty 2 burner cooker you can try if you want.
    This sort of thing...
    I'd still go indirect heat like a Bain Marie type setup just to have a bit more control, though.
    Gas tends to be too little or too much and you will struggle to get the required range for the alcohol to boil off.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 421
    I thought the idea was to get away from open flames ....
    I just donít like the idea of shoving an element directly into the product
    cape town
    Thanked: 361
    i'm adding an arbitrary comment here, so i can follow any further discussions.
    My still is on its way as we speak
    My family has been making schnaps for generations in Austria, on my recent visit, the secret family recipe was handed over.
    Soon the project starts in earnest.
    Thanked: 421
    Damn thatís a nice still......Iím looking at a stainless steel jobbie.....diy obviously
    Also looking at vacuum options - THC & CBD.....and maybe some gin
    Thanked: 13036
    you'd prefer gas flames and 90% ethanol?
    joburg
    Thanked: 441
    Does anyone make prohibition era type moonshine / whiskey ? Original recipes, original method, copper still, flame and even as far as the beard and dungarees (teeth optional) ? I'd be keen on some of that.
    Thanked: 13036
    Quote Originally Posted by sparewheel View Post
    I can try.
    - got the still
    - got the gas flame
    - will have to grow a beard
    - will have to buy the dungarees
    - my teeth aren't wonderful
    - will research the sour mash recipe in my distilling book
    Baardman Brewery did a proper sour mash ferment and distill the other day, not sure it turned out that well though.
    It's easy enough to do yourself.
    https://www.clawhammersupply.com/blo...make-sour-mash
    Thanked: 13036
    Quote Originally Posted by dieterf View Post
    i
    1) beautiful hand hammered still
    2) how secret is secret?
    cape town
    Thanked: 361
    The still in the picture is the family unit, ensconced in the family "boat house" on the shore of Bodensee (lake Constance) and duly used by my cousin, ironically a senior police officer
    He has been making schnaps with his dad and my grandpa for decades!
    I bought this unit on his advice, in the air as we speak!
    re the secret, its not really that secret, the trick according to the masters:
    is good quality clean fruit with good brix.
    A good mash fermentation with minimal but the correct starter yeast, good, slow, not to warm fermentation and then a slow controlled, double distill process.
    The instructions were documented for me in german and i have translated.
    If anyone wishes to read them, PM me, i am happy to share.
    Thanked: 421
    Iím still having a problem with direct heat.....
    All my experience in the dairy industry is telling me that itís not the best (or economical) option.
    Indirect heat is more controlled and itís virtually impossible to scorch the product. A PHE is more suited to a continuous plant, so thatís not gonna work too well.
    Jacketing the beer keg is inefficient because stainless isnít a good conductor.
    So..... a copper coil in the keg??
    Most hobby stills have an element inside the mash/wash, scorching is only a problem if you have grains/fruit in your boiler. If you are doing AG either sparge before ferment or separate grains from mash after ferment. Distilling on the grain can apparently give you some other interesting flavours( I don't know because I have never tried it).
    My boiler is the Still Spirits Boiler, it does not have an exposed element but more like an urn with the element under the base. I ferment on the grain and then separate the grains from the mash before distilling.
    If I were using a keg, my concern about distilling on the grain would be the clean up after, unless you have made a way to open the keg up with a large hole to scoop out the muck.
    Personally, if I was building a boiler from a keg, I would just chuck an element through the side. But if you have the materials and the ability to do the work then I think indirect heat would give you a more versatile boiler. From some of my research there are plenty of all Stainless jacketed boilers, so although stainless isn't your best option, it will work and the jacket won't decrease the volume inside the keg like a coil would.
    My 2c
    Dec 2014
    Thanked: 1800
    Gary, you are overthinking this... Chop a drum in half and support the keg in that so it has clearance all round and heat the water in the drum.
    That will be far easier to control temperature-wise.
    OR
    If you have the gear, (you probably do, given your job) you could always get fancy and make a boiler to feed the jacket around the keg, (or the coil inside the keg) and use fancy electronics to control the process, producing run-of-the-mill spookpis or, you could build a wood fired magafter in your yard at home and do it the traditional way and make some really fine Craft Hooch that is worthy of a master distiller.
    Either way, get a bloody move on already, I'm getting thirsty.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 13036
    just use one of those jacketed cheese vessels and run hot water through the jacket
    Thanked: 421
    Running costs and temperature fluctuations are a major factor.
    Electrical heating is gonna push up the running costs. Itís easy enough to control but the lower the volume, the more chance of scorching the product. (Yogurt 101)
    Gas is cheaper to run but harder to control (unless you chuck big money at it)
    Diesel/paraffin hot water boiler has got the lowest running costs and is fairly stable depending on the volume/storage capacity of the loop.
    We use a 300lt hot water tank (30kW electrical elements) to run a 1000lt/hr pasteurizer (continuous)
    The boiler can also be placed outside and plumbed into the still.
    cape town
    Thanked: 361
    Very clear instructions from cousin H, do NOT overheat the mash.
    I have instructions to build a second base within the distill burner. at a level of about 2cm above base, to cut to size and fit a second floor with holes in it, like a shower rose.
    On burning, to put a layer of water in the pot, level to this second base plat/rose and then add the mash on top.
