Charging battery up to what V is ok.
Results 1 to 10 of 10
    Dec 2013
    Paarl
    Thanked: 506
    Default Charging battery up to what V is ok.
    When charging a 12V 105 battery from mains with a car battery charger up to what volts is is still safe. ?
    Mainly used it in my vehicle but now with loadshedding i moved it into the house so we can use it with an inverter to run a tv and light or two
    Reason I ask is I see the volts go up to just over 14V. (Battery is in box that have Volt meter build in.
    Is this ok or should I have the battery charger checked out.
    Friemersheim, Southern Cape
    Thanked: 2124
    Default Re: Charging battery up to what V is ok.
    Would help if actual battery details are known.
    Dec 2013
    Paarl
    Thanked: 506
    Varta 105A
    Thanked: 2124
    Actual charts or specs for these are hard to find.
    This Ilink found on another forum ...for the LSF105 battery
    http://jci_media.s3.amazonaws.com/va...nal_150x75.pdf
    Seems 14.4V is limit to go to.
    Float charge @ 13.4V
    Thanked: 301
    With an intelligent charger going up to 14.7V is fine but then trickle or float at 13.6V.
    Dec 2013
    Paarl
    Thanked: 506
    Thank you kindly.
    The charger i am using is national luna.
    Dec 2013
    Paarl
    Thanked: 506
    Dankie prof
    Apr 2016
    Thanked: 52
    Make that 13.5V as battery float voltage in our hot climate..
    Thanked: 301
    Richard you are right but the figures I mentioned are values from some commercial chargers and not adjustable. I found a charger that would also keeps a battery at 14.6V but constantly discharging a bit and that does not introduce gassing as one would normally think will happen at a constant 14.6V.
    Dec 2006
    Thanked: 862
    Just something to keep in mind. That "up to 200 cycles" is the reason why conventional batteries are not ideal for an inverter backup system.
    If you plan on using it often, you should seriously consider going good quality deep cycle. 3000 cycles capability is not uncommon.
    With the way eksdom is going lately 200 cycles is not much.
    Sakkie Coetzee
