Loadshed problem advice please
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 52
    Default Loadshed problem advice please
    With the stage 4 in place and stage 5 or 6 looming:
    I find that my two linked 102AH batteries feeding 12v supply to 1 000W inverter do not recharge fully between outages.
    So after three or four outages I can no longer draw power from the system without harming the batteries due to pulling them down too far.
    When fully charged we get through up to a 4 hour cut without problems.
    That is using a mains battery charger and a 90W solar panel through a controller to re-charge.
    Even on a fully sunny day they do not bring that batteries up to full charge in time for the next cut.
    When cloudy then of course it is even worse.
    So now my question:
    Do I buy additional batteries or another solar panel or what ?
    It seems to me I just need to re-charge at a faster rate ? Maybe a more aggressive charger ?
    Obviously (at least in my case) cost is critical.
    I am sure many others will be experiencing similar issues.
    Any suggestions from our forum fundies ?
    ISUZU KB 280 DT LE NOW POWERED BY THIS AMAZING COMMUNITY
    Platkar = Chevy Spark 1.2
    Jan 2019
    Default Re: Loadshed problem advice please
    The problem is both ways, you will need more batteries to last the longer outages but you will definitely need more panels to get them charged. For your current problem you will have to add more panels in parallel to get more amps in the battery. It would also help to buy 24v panels then they charge with less sun.
    AND Retired
    More panels = faster charge
    Bigger batteries means less discharge as a % of capacity, but that doesn't matter, you still need more panels.
    Your controller must just be able to handle the extra Watts and then of course the batteries must be able to handle the faster charge.
    Which controller are you using,.make and model?
    Discovery Landrover 3 tdv6 2008
    Volvo S40 T5 2006
    Aug 2017
    Do you have the model details for the charge controller, then we can try and give better advice.
    Edit: sorry, seen its already asked - my phone takes forever to refresh
    I don't understand this bit:
    "That is using a mains battery charger and a 90W solar panel through a controller to re-charge."
    Aug 2017
    Sounds like a typical camping setup.
    When mains is available, the charge controller will charge from there, if no mains is available, it will revert to the PV panel to charge.
    Sinoville Pretoria
    May not be applicable in this case, but a modern proper inverter / controller can accept both solar, mains and/ or gennie charge, being able to differentiate and control all 3. Mains first plus solar, then when mains fail, solar only, when batteries become depleted, will start gennie or request you to start gennie, if no auto starter
    Henk Pretorius D4 3,0 SDV6 HSE
    EX AFRICII SEMPER NOVUS
    Oct 2018
    Pietermaritzburg
    Your mains charger should be 20A so that both batteries can get fully charged after a 50% DoD. To charge fully from solar you will need about 250w of panels and about a 20A Solar Charger. The problem here is that mains charging and solar charging at the same time will be too high.
    Rather just leave the solar as is at 90w and use a 20A mains charger.
    My take would be to increase the charging rate but it is already very high. Longer term this will shorten the life of the battery. With this in mind I would not increase the charging rate any further by using a bigger solar panel. If you go to a 2nd battery I would suggest you look at the SMF100 100Ah being sold by Battery Centre. Going at below R2 000 depending on the discount you get.
    If you have a 2nd battery then we can look at increasing the charge rate. I have mentioned the 12V 7A intelligent chargers before. They cut off to a trickle charge (13.6V) as soon as the battery is full. These chargers can be used in || to boost the excisting charge rate and at about R150 adding 2-3 of them is far cheaper than a bigger panel provided our loadshedding is of such a nature that we get a few hours grid between shedding. One can also charge the 2nd battery by these chargers when disconnecting it from the other one to ensure each battery is properly charged and only re-connect the 2 batteries in || at loadshedding time.
    If a 24V system is used via a charge controller one will also have to connect and re-connect back to 12V.
    It is still important to know what solar controller is being used to know the present charge rates.
    Friemersheim, Southern Cape
    Both the mains battery charger solar charge controller is connected to battery..
    So in effect getting charge from mains and panel.
    I utilise this with my PWM controller, which follows the SOC of the battery.
    After bulk charge is finished I remove the mains charger
    Okahandja, Windhoek
    Quote Originally Posted by Peter1949 View Post
    What are you using now?
    Johan Kriel
    LCs, Hilux and Echo Chobe
    https://www.victronenergy.com/blog/2...r-pwm-or-mppt/
    Maybe its the controller that needs a rebook at...read link above.
    Volvo S40 T5 2006
    Quote Originally Posted by Shade View Post
    Peter as yet to identify his charge controller.
    Cape Town - RSA
    is it ok to run multiple chargers on a battery bank?
    In Peter's case the mains charger and Solar. In my case 20amp dumb charger and 5 amp smart charger?
    Ex - 2005 Cherokee CRD
    At times it could be risky. I once blew up a very nice pure sine when I connected a real cheapo modified sine to the same battery. Since then I am very careful and would only try with a nearly full battery and a low rating fuse for both chargers when testing.
    Wow guys - thanks for all the info.
    Still dark outside now and about to hit the next shedding.
    I will check the details re controller, battery type and inverter detail and post later when back on line.
    Thanks a lot for all comments so far.
    Its category One today going to 2 at 09h00 so you will be better
    sounds dodgy to me
    Wartburg.
    Peter I have a 105 amp hr Deltec deep cycle battery for you if you want it.
    I bought it in December, but the battery wasn't the problem.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
