Series 1 firewall & chassis repair/rebuild
Results 1 to 20 of 21
    Thanked: 382
    Default Series 1 firewall & chassis repair/rebuild
    Got some interesting jobs in....
    First is an 86 chassis that was “repaired” by a “so called” (and recommended) welder.....
    Half the job is cutting out everything that Tarzan “repaired”
    The other half is trying to save the rear crossmember......Tarzan plakked a lot of plates inside the RCM to try and strengthen his carp work.
    5 levels .... battery tray is level,
    two inner levels are true,
    Back level (RCM) is 42mm out, RCM sticks out 24mm
    Front level (SCM) is 48mm out. Bumper is welded to the chassis
  2. The Following User Says Thank You to GaryFrank For This Useful Post:
    Thanked: 382
    Default Re: Series 1 firewall & chassis repair/rebuild
    Dunno what happened but there’s now multiple threads
    Thanked: 382
    Cut off the RCM and cut all the repairs off. Then I started cutting and repairing the rust holes
    Thanked: 382
    Easy repair..... cut & weld
    Thanked: 382
    Thanked: 382
    The first firewall is a 1953, pressed foot wells
    I’m hoping someone here has one and can take a pic of the top plate (below the windscreen)
    Firewall looks a bit rough, but isn’t a right off
    Thanked: 382
    The second firewall is a 1957 but that will have to wait a bit
    Jul 2015
    Kilkivan
    Thanked: 216
    I have a few firewall here.
    Which part did you want a pic off. As in a close up or a general wide view.
    I did not think they would get that rusty over there. More like here in OZ I would have thought.
    Thanked: 382
    I’m looking for a pic of the top of the firewall where the windscreen seal would fit.
    Thanked: 382
    Close up from engine side and drivers side
    Jul 2015
    Kilkivan
    Thanked: 216
    Hows this for a start.
    80 firewall 02 by [url=https://www.flickr.com/photos/[email protected]/]
    80 firewall 01 by [url=https://www.flickr.com/photos/[email protected]/
    Sep 2008
    Thanked: 139
    Looking at the chassis in your first photo it appears to be an 80 inch (1950 - 1953) recognisable from the engine mounts, straight outriggers and the 2.5 inch front spring mounts. The firewall you have there has the sidelights in the front of the firewall - they were fitted up to 1951.
    1951 Land Rover Series I 80" 2-litre ioe tilt (project)
    1975 Land Rover Series III 88" 2.25 p soft top (workhorse)
    1998 Land Rover Defender 90 2.8i CSW (expedition vehicle)
    1977 Land Rover Series III 109" 2.25 p station wagon (sold)
    Jul 2015
    Kilkivan
    Thanked: 216
    I wondered why this was not in the Land Rover section.
    80 inch Land Rovers were from 1948 to 53. 48, 49 and early 50 had narrow front springs with the swinging shackle on the front. Then they changed to the wider front springs and swinging shackle on the rear of the spring.
    The photo I put up is the same model as the OP was asking for.
    If he wants a photo of a 57 I have one of those too.
  15. #14
    Thanked: 382
    Dunno what happened last night with the rolling blackouts, but I’ve got multiple posts all over the forum.
    I’m working with the info given by the customers.
    The firewall is off an 80, we think it’s a 53?
    The chassis is supposedly a 86?
    Pics of the firewall is exactly what I’m looking for - could you zoom in. This one had a galvanized plate folded over the back lip and screwed to the front flat.
    I’ll post more pics
    Chassis number is on the RH engine mount, behind the battery mount
  16. #15
    Thanked: 382
ID:	522882Click image for larger version.
ID:	522883Click image for larger version.
ID:	522884Click image for larger version.
    Said galvanized capping
  17. #16
    Thanked: 9718
    right-click, save image as..., then open it with a pic viewer on Windoze
  18. The Following User Says Thank You to jelo For This Useful Post:
  19. #17
    Thanked: 382
    Pics aren’t showing what I want....
    Top of the firewall (inside - above the dash) there is a “lip” ...stands 20mm above the engine side of the firewall.
    On the engine side, there is a horizontal lip (+ - 30mm) that runs backwards towards the inside upright
    Did the front lip butt up to the inside upright? (Horizontal and then vertical)
    Or did it just run horizontally and got tacked to the inside upright
    I figure that the galvanized capping is a DIY fix?
  20. #18
    Thanked: 382
    Tickford49.... the first pic looks about right.
    Can you zoom in right there (front & back pls)
  21. #19
    Thanked: 382
    Next question .... these angled plates in the footwells.....original or a hole cover? Click image for larger version.
  22. #20
    Thanked: 382
    In the footwells, there are angled “plates” ...is this original or is it a DIY rust cover ??Click image for larger version.
