Loadbox charging
Results 1 to 15 of 15
    Aug 2018
    Paarl
    Thanked: 8
    Default Loadbox charging
    Hi I want to charge my xtra battery.
    If I run a wire from my engine bay battery to my loadbox and attach a bh plug to it.
    What do I need to charge my battery and prevent my xtra battery from draining my cranking battery.
    Please help I am clueless.
    Somerset West when not in Jhb
    Thanked: 89
    Default Re: Loadbox charging
    You will need some sort of protection in the form of a DC-DC charger or a solenoid system.
    Please share your requirements, such as loads on the 2nd battery, application - camping for x days, overlanding etc. It will determine your system design.
    Did you have a look at the Sticky called 'Electrickery for camping'? It will have all your questions answered..
    ORRA Callsign: X130
  3. The Following 2 Users Say Thank You to Subok For This Useful Post:
    Thanked: 89
    ORRA Callsign: X130
    Aug 2018
    Paarl
    Thanked: 8
    Will be mostly for running fridge while driving but also if needed to camp for weekend running fridge and x2 lights.
    Jun 2013
    Thanked: 1747
    BMW R1200R
    Polokwane
    Thanked: 206
    Elspark
    Thanked: 538
    Check the temperature limitations of he DC.-DC charger if you are planning to use it in the bin or engine bay.
    I lost one due to overheating in the loadbin. Even with two cooling fans it did not make it.
    Tshwanetoria
    Thanked: 343
    Indeed! It gave me the confidence to do my own installation. I went for the NL DC-DC and Bat box. Why do you need confidence? In the end it may be a straight forward job, but do it wrong, that very expensive vehicle of yours may go up in flames. Or you may be left stranded with warm beer
    Why did I do it myself? For the enjoyment of the project and satisfaction a well done job gives me.
    Aug 2018
    Paarl
    Thanked: 8
    Hi please give me a detailed discription what you did.
    Tshwanetoria
    Thanked: 343
    Quote Originally Posted by fatbike View Post
    So simple, it is actually embarrassing:
    • 16mm pos and neg cables from start battery to load bin. Pos 30 amp fused at battery.
    • Routed in a sleave underneath vehicle, making sure there is no opportunity for pinching/chafing/ hooking or heating from exhaust.
    • Connected to a NL DC/DC 25 Charger. Charger also connected to Ignition as per instructions and temperature sensor connected to aux battery as per instructions. The NL instructions are VERY clear and easy to follow.
    • I bought the special at Outdoor Warehouse during Dec, so I also got the NL monitor. That was actually the most difficult part to install, since that cable was a bit short to follow the easiest rout, so I had to take out the back seats and console to do a straight line installation to the dash. Apparently you do get a longer cable but I believe that would have been too long. I do not like meters of winded cable in my vehicle. I would HIGHLY recommend getting that monitor - it gives you certainty about the condition of the charging system as well as of the batteries. (If you get any other brand - also try to get one with a monitor it is really not negotiable)
    • DC/DC charger connected to NL Auxcillaiary Battery box with 16mm cable, Pos again fused 30 amp. Charger and Bat box within 50 cm from each other.
    • Used a 105 amp/h Discoverer Calsium deep cycle battery
    The system is also solar ready, which will follow shortly by means of two 80W panels.
    At the moment I am running a 56l Snowmaster freezer and a few 12 v led lights and other smaller stuff from the system.
    If you want to do it yourself - get a proper crimping tool.
    Enjoy!!
    Thanks to Elders, Fluffy, Eggie, SarelF and ALL the others that did the Thread on this.
    Polokwane
    Thanked: 206
    Why did I do it myself? For the enjoyment of the project and satisfaction a well-done job gives me.
    Why did I do it myself? Because if things go wrong in the bush you know exactly what's going on with your system.
  13. The Following User Says Thank You to DC Polokwane For This Useful Post:
  14. #12
    Apr 2017
    If you are unsure about all the wires, plugs, etc. the National Luna Portable Power Pack (or similar products from other places) does everything you require.
    You only need to route the 16mm wire from starter battery to the back.
    https://www.nationalluna.com/product...cable-hardware
    https://www.4x4direct.co.za/battery-...-luna-box.html
    Groot berge en lang grondpaaie
  15. The Following User Says Thank You to pietas For This Useful Post:
  16. #13
    Brackenfell
    Thanked: 181
    I am using the Cyrix combiner, work like a charm for me. But you might have other requirement. If you go this route 4x4 direct price decent, but I got the unit cheaper at On Track -solar company based in Somerset west @ builders warehouse (the interchange IIRC)
  17. #14
    Aug 2018
    Paarl
    Thanked: 8
    Hi can you give me more info
  18. #15
    Brackenfell
    Thanked: 181
    The cyrix works exacly like an cole hersee solenoid as used with nl split charge. They just added their own intelligent switch with it that has a timer delay.
    The cyrix (relay) switches and allows power to the second battery when voltage greater than 12.8 is measured. But charges at what the alternator supplies.
    Make sure whether your vehicle has an smart/variable output alternator. If so dc2dc might be better then
