56L Snowmaster Rattling
Results 1 to 8 of 8
    Dec 2012
    Thanked: 11
    Default 56L Snowmaster Rattling
    Good day all,
    I am the proud owner of a new 56L snowmaster fridge freezer.
    Here are some pics:
    https://photos.app.goo.gl/bAS39UXJxhuS6jQAA
    It got delivered this week, after a very excited un-boxing experience and running it on AC overnight to test it out. I decided to take it for a test drive on the way to work this morning.
    However I very quickly noticed a very irritating rattling noise when I went over small bumps. One that would drive me absolutely crazy on a dirt road.
    I can tell by the sound of the noise that its got to do with the copper piping / radiator inside the fridge. Its almost like a pipe is hitting one of the fins or something.
    Is this normal, or am I just unlucky that something inside my fridge is 5mm to close to something else?
    To have to return it for this is just going to be a night mare. What are the chances I can just open it up and bend whatever is rattling by 3mm?
    Suzuki Jimny 2015
    Ford Focus Mk1 2003
    Tshwanetoria
    Thanked: 339
    Default Re: 56L Snowmaster Rattling
    "Returning" it should not be a nightmare. Just take it to the supplier in Isando (Quite close to you) and have them check it out. Open on Saturdays as well.
    Bought the same one on Black Friday at a massive discount - works superbly.
    No sorry, got the 65l low profile one (same difference :-) ). Only fridge low enough to fit underneath the tonneau cover of the Amarok.
    Polokwane
    Thanked: 196
    Was there something inside the fridge? Otherwise the loose baskets tend to rattle.
    Nov 2006
    Bronkhorstspruit
    Thanked: 35
    Hi. Talk to Warren Bennet 073 one37 0six78 he will assist you.
    Hercules Pieterse
    2.8 Powerstroke Tdi Kalahari 2007
    Accent GLS 2012
    Ex - i20 2011
    Ex - Discovery Tdi 1995
    Ex - Nissan Sani 1994
    082 389 2639
    Dec 2012
    Thanked: 11
    There was 1 coke, so you have a valid point here. I think there could be rattle coming from the baskets. But this particular sound was definitely there in the compressor compartment.
    Suzuki Jimny 2015
    Ford Focus Mk1 2003
  6. The Following User Says Thank You to Zapnologica For This Useful Post:
    Dec 2012
    Thanked: 11
    Quote Originally Posted by DFNDR-GP View Post
    Thank you very much,
    Will do so.
    Suzuki Jimny 2015
    Ford Focus Mk1 2003
    Thanked: 215
    Also remember that the compressor is mounted on rubber feet to allow for some movement. This movement will make some noise when jolted (bad road etc) is it not maybe that that you are hearing?
    Nov 2006
    Bronkhorstspruit
    Thanked: 35
    My fridge also makes a noise also must be the compressor. I asked them to look at it by snowmaster, it's better but still makes a noise sometimes
    Hercules Pieterse
    Accent GLS 2012
    Ex - i20 2011
    082 389 2639
