Problem with geyser in van
Results 1 to 3 of 3
    Jul 2010
    Sasolburg
    Default Problem with geyser in van
    Hi All
    I fit a Hansen GE3 geyser in my offroad van but if we open the taps and the pump starts water is coming out at the pressure relieve valve.
    I contacted Hansen and they suggest that i reduce the pump pressure by setting it on the pump. I did try it with no luck.
    Anybody else who experience this.
    Ettiene
    2016 ISUZU KB 300 LX D/C AUTO 4X4
    SWAMBO 2013 NISSAN JUKE
    Oct 2012
    Vredenburg
    Thanked: 175
    Default Re: Problem with geyser in van
    Sounds like a clogged inlet screen/filter.
    There's only 3 reasons to stand up : to get the remote , to go to the bathroom or because you're the Real Slim Shady.
    2002 Patrol 4.5 GRX
    2001 Terrano 2 TD27
    2012 1600 Pypkar Rum mobile
  3. The Following User Says Thank You to nisjeep For This Useful Post:
    Jul 2013
    Thanked: 239
    Hi
    As i am also interested in caravan water heaters ( have an xplorer with attwood works on same principal as hansen).
    Attaced a link to hansen web page.
    Lots of info and brochures.
    See their recommendation for pumps.
    Also a presure reduction regulator they can supply.
    As suggested investigate the filters.
    http://www.hansenproducts.co.za/water-pumps.html
  5. The Following User Says Thank You to janseekat For This Useful Post:
