DIY fireplace/oven
Results 1 to 20 of 30
    Thanked: 82
    Default DIY fireplace/oven
    Now that “Winter is Coming” I want to build my own fireplace with secondary combustion and glass door. Will 3CR12 be the best choice? , 5mm thick? Also have the number of the glass place that will make and temper the glass front. Anyone done this before? Why buy if you can make it yourself?
  2. The Following User Says Thank You to emileheyns For This Useful Post:
    Thanked: 46
    Default Re: DIY fireplace/oven
    Hi
    I am in the process of making a masonry heater using the picture below. I started last winter and didn't finish and froze by butt off, so I'm finishing before this winter.
    This design has a re-circulation chamber so cleaner burn and less bad stuff into the atmosphere, but there are as many variations as there are nations on earth.
    This is more efficient than cast iron heaters simply because they have more mass, they take a long time to heat up but will radiate heat for many hours.
    Apologies if I say things you already know.
    There is an inner part and an outer part. The inner part must be built on a layer of sand so it can expand and contract. The must be a gap between the inner and
    outer part as not to cause cracking in the outer part.
    The brick laying is not the best as it's not my thing, metal fab is. The saw was a gift from a friend and now hangs in my workshop because my wife doesn't want it hanging above the fire place as per my suggestion.
    I am making small steel doors for the openings on the side, these openings are for cleaning the flues.
    I welded railway cleats (I don't know the proper name) together to make the T brackets to hold the sleeper.
    I used 4mm mild steel plate for the door.
    I got the glass from an old oven but I think you can use that glass for 3D printer beds www.3Dprintingstore.co.za .
    I will put flexible fire cement between the metal parts and brickwork to create a seal.
    Clearance must be left for the door to expand.
    The wall at the back of the masonry heater divides the lounge and kitchen and is sort of central in my house, and should keep it warm.
    I don't know the answers to your questions but I hope this helps for something.
    Will post progress and again after first fire and let you know the results.
  4. The Following 5 Users Say Thank You to moseswal For This Useful Post:
  5. #3
    Thanked: 46
    Hi
    Today I started with the bottom part of the chimney. This will sit on top of the brick work.
  6. The Following 3 Users Say Thank You to moseswal For This Useful Post:
  7. #4
    Thanked: 149
    Did you use firebricks or clay bricks ?
  8. #5
    Apr 2018
    Fraserburg
    Thanked: 937
    How do you achieve the inner part on sand? This looks ideal for the Karoo.
  9. #6
    Thanked: 46
    Clay bricks, I figured it will be OK because the bricks are fired at a high temperature.
  10. #7
    Thanked: 46
    I put a thin layer of sand on the slab and built on top of it.
  11. The Following User Says Thank You to moseswal For This Useful Post:
  12. #8
    Feb 2012
    Bloubergrant
    Thanked: 137
    Wow, I think you are too humble - that is a work of engineering proportion and very well finished off!
    Congratulations!
    Mitsubishi Triton DC 3.2 A/T 4X4
    2007 Hilux 2.5 D4D SOLD
  13. The Following User Says Thank You to Johan Engelbrecht For This Useful Post:
  14. #9
    Thanked: 46
    Hi
    Thanks Johan
    See the second part of the chimney tacked up.
  15. #10
    Thanked: 734
    To answer the OP's question, 3CR12 does not like heat. I guess it is still better than mild steel. I have a braai pan I've used for about 15 years made from 1.2 mm 304 stainless. I'd be inclined to use 1.6mm 304 grade stainless steel rather than 3.0mm 3CR12. I'm talking from my personal observations.
    That said I've also been looking at videos of the german/swiss/austrian "kachelofen" construction. Many of these have side benches built onto them. You can get them locally made for you at some 100k a pop. They have special bricks and cement with which to build these with. One point I've noted about these constructions is that they draw air from outside.
    https://www.youtube.com/watch?v=kPbprpfQGVY
    Note how after building the oven that he lights a smoke and checks the draw. It's very important that these fireplaces draw properly or you can release too much CO2 into the room. That could be a reason for drawing from outside - I'm not sure.
    The outer skin of these ovens are usually glazed ceramic tiles.
  16. The Following User Says Thank You to Heinz Modricky For This Useful Post:
  17. #11
    Thanked: 46
    I seem welded the flues and made the damper.
    I turned the bushes on the lathe. This one has a blind hole and is sealed.
    I welded in a bar that stops the damper at 100% closed position.
    The bar stops the damper at the 100% open position.
    This section slips into the bottom section.
  18. The Following User Says Thank You to moseswal For This Useful Post:
  19. #12
    Thanked: 46
    Ash box
    Cutting the plates
  20. #13
    Thanked: 46
    Chimney top that will protrude through the roof. The flange is to bolt a tornado type cowl to it. That should help create a negative pressure in the flues that will be helpful for cold starts.
    Getting ready to spray.
  21. #14
    Thanked: 46
    The ash box
    Fitting the chimney
    Mocking up the tornado
  22. The Following User Says Thank You to moseswal For This Useful Post:
  23. #15
    durban
    Thanked: 1121
    Looking good .Is this a one of or have you done a couple ?
  24. #16
    Mooi River
    Thanked: 64
    are you going to fit a door with a glass on that fireplace?
    2000 Ford Courier DC 2.5TD 4x4
    2009 Fiat 500
    2001 Merc C200K
    2007 Disco 3 TDV6 manual
  25. #17
    Thanked: 46
    Hi
    This is the first one.
    There is a glass in the door.
  26. #18
    Thanked: 46
    I installed the top part of the chimney, I need to seal it where it meets the roof.
    I started making the horizontal flue doors.
  27. #19
    Thanked: 46
    More progress on the doors
  28. The Following User Says Thank You to moseswal For This Useful Post:
  29. #20
    Sep 2011
    Potch/Brits
    Thanked: 583
    Damn you are good with steel.
    Your build looks good
  30. The Following User Says Thank You to carlp For This Useful Post:
