Quick WRMD question
Results 1 to 11 of 11
    Mar 2011
    Salt Rock
    Default Quick WRMD question
    Hello all
    Busy with a dual battery install, and have purchased WRMD charger.
    Instructions say to install unit vertically - ie with wires running downwards out of unit..
    I have built battery box with a side to do this...
    Only problem is, with unit installed like this, there is no way I will ever be able to see what indicator lights are doing..
    Battery is located in engine bay
    I'm considering installing the unit sideways - wires running horizontally out, or simply sitting flat on top of second battery?
    Any thoughts on this?
    Thanked: 240
    Default Re: Quick WRMD question
    I think vertically is just a practical suggestion. Would like to hear any reason not to mount it in any other way.
  3. The Following User Says Thank You to ekkekan For This Useful Post:
    Mar 2011
    Salt Rock
    Thanks Ekkekan
    Thought the same, and have done so
    Thanked: 60
    I have seen the unit mounted sideways in a camping trailer, worked just fine. I too see no reason why it would be a problem, it's just an electronic device
    Geoff Craig
    '09 Toyota Fortuner 3.0 D-4D 4x4
    (M)
    '14 VW Polo 1.2 TSI HL (SWAMBO's)
    '10 Conqueror Comfort
    4x4 Action Group membership
    #0074
  6. The Following User Says Thank You to Wave For This Useful Post:
    Thanked: 101
    Mine is mounted upside down in my battery box. It just makes more sense for me to run the wiring like that and I have not had a moments trouble from it.
    It is always in the Patrol keeping the battery topped up. The fridge works a few times every month and no problems.
    Perhaps they want it right side up to protect against water penetration.
    Nissan Patrol 4.8 GRX
    Nissan Hardbody 2.4
  8. The Following User Says Thank You to pgreeff For This Useful Post:
  9. #6
    May 2012
    Thanked: 694
    Thanks for this. I am busy figuring out how to attach my WRND to my battery box as we speak.... Also noticed the request to isntall upright. Also could not figure out why....
    "Grent" Vitara
    EX- EL JIMBO - RED AND "FAST"
  10. #7
    Thanked: 101
    I was a typical male and didn't bother reading the manual so I didn't see that part.
    Nissan Hardbody 2.4
  11. #8
    Cape Town - RSA
    Thanked: 245
    Can only presume thats to keep water from coming in the top, or to let heat rise out of the top.
    Water seems more likely but then its not a waterproof system so who knows.
    Ex - 2005 Cherokee CRD
  12. #9
    Mar 2011
    Salt Rock
    Thanks all for the input..
    Water pentration also occurred to me, but its sitting pretty high up, just below bonnet, so hopefully ok..
    I've gone with a sideways mount, but have space to change it..
    Just didn't make sense to not be able to see the indicator lights
  13. #10
    Thanked: 335
    Mine is mounted sideways no problem.
    Ross
  14. The Following User Says Thank You to RMackay For This Useful Post:
  15. #11
    Apr 2012
    Bela Bela
    Thanked: 151
    Mine has been mounted sideways in the engine compartment just below the bonnet for over a year now and works perfectly. The only thing that has happened is that the label is starting to peel. As far as I am aware it is waterproof.
    Pete
    ADVENTURE BEFORE DEMENTIA
  16. The Following 2 Users Say Thank You to petewill For This Useful Post:
