Results 1 to 20 of 21
    Thanked: 33
    Default Jeep - TPMS Sensor laying around?
    hi guys
    i know that some of you swap rims and tyres etc.. Does anyone have a spare TPMS sensor 433Mhz laying around? This is for my Grand Cherokee 2011 however some of the wrangler models are the same
    2011 Jeep Grand Cherokee Overland 5.7
    Previous Jeeps:
    2012 JKU Rubicon 3.6 V6 on 37's with Synergy 5" Lift Kit with Fox 2.0 Factory Racing Shocks with Synergy Adjustable Control Arms
    2010 JKU Rubicon 3.8 V6 on 35's with Synergy 4" Lift Kit with Fox 2.0 Factory Racing Shocks
    2008 JKU Sahara 2.8 CRD 6sp Man on 33's with Full Traction 3"
    Thanked: 151
    Default Re: Jeep - TPMS Sensor laying around?
    Im also looking for my 2012 WK2, have you had any luck yet bud?
    2018 Toyota Hilux 2.8 GD6
    2016 Toyota Fortuner GD6 Auto
    2012 Jeep Grand Cherokee 3.0CRD
    2011 Jeep Cherokee
    2006 Jeep Grand Cherokee 3.0CRD-50mm EFS Lift, GDE Tune
    2009 Jeep Rubicon-50mm Coil Lift, Branches, Free Flow, K&N, MT`s
    2013 Suzuki Vitara-40mm lift
    2012 Suzuki Jimny-Fully Kitted.
    2007 Jeep Cherokee-Std
    Thanked: 33
    Quote Originally Posted by Jay4 View Post
    No, no luck unfortunatly, there must be plenty lying around for the guys that swap rims on the JK's and dont move TPM into it.
    Im going to go to a tyre shop at lunch and have them remove spare from Rim and see if it has a TPMS sensor in it. if so,ill move that to the right rear wheel and fit standard valve on spare.
    otherwise ill buy a new one
    Previous Jeeps:
    Thanked: 151
    Have you got a broken valve stem or what is your issue?
    My valve stem is broken, ive just ordered two off Ebay FYI
    2011 Jeep Cherokee
    Thanked: 33
    Its started off by reading 4 bar when the tyre was 2.4 bar. now its not registering at all.
    It seems bent inside the rim.
    Previous Jeeps:
    Thanked: 151
    Dam!!!!
    They seem very cheep on Ebay from reputable sellers, will see how mine pans out, maybe thats an option?
    2011 Jeep Cherokee
    Sep 2015
    Home
    Thanked: 556
    I imported 4 from a Chinese seller on eBay, took 6 weeks to get here, just under R600.
    Oct 2007
    Wichenford, United Kingdom
    Thanked: 179
    Quote Originally Posted by HeavyG View Post
    That is very, very cheap. Three years ago I need to replace one on my 2005 Jeep GC and the cost was well in excess of R1500 and that was with an Inde and not the dealer as the dealer was more expensive.
    2012 Jeep Grand Cherokee Overland Summit CRD chased by a 2018 Buccaneer Cruiser twin axle caravan.
    Thanked: 33
    Thanks for the idea, i only managed to find one post on ebay for my model number TPM. I ordered one for about R420.
    lets see if it arrives and is correct and working
    Previous Jeeps:
  10. The Following User Says Thank You to rickJK For This Useful Post:
    Thanked: 151
    Ive done the same, waiting for it to arrive now...
    2011 Jeep Cherokee
    May 2007
    Helderkruin, Gauteng
    Thanked: 7
    Want to fit 18" wheels with AT tyres for my upcoming Namibia trip, how easy is it to remove the TPMS sensors from the 20" wheels and then fit on the 18" wheels?
    VW California 4Motion (MAD suspension)
    '13 Jeep GC 3.0 CRD Overland
    SLK200 facelift
    TT 3.2 Roadster
    Pajero 3.2 GLS Shorty Gen4
    '95 Vitara JLX Cabrio
    BMW GS1200R
    Dragstar 1100
    Vulcan 1500
    Honda XL500S
    '81 Vespa PX200
    Oryx
    Thanked: 33
    Mine Arrived and works. Its a different part number but apparently the newer part. The TPM is grey instead of black, both 433Mhz and it works correctly. Local tyre shop removed old one and inserted new one.
    Previous Jeeps:
  14. The Following User Says Thank You to rickJK For This Useful Post:
  15. #13
    Thanked: 33
    Quote Originally Posted by harryx4x4 View Post
    I had my TPM valves removed from my stock wrangler wheels and moved to my new rims and it worked perfectly.
    I just had my old faulty TPM removed now and a new one installed and i can see the old ones valve is damaged more so since removal.
    They pulled it out from the front. It was done this way as it was already faulty and not going to be used again. The sensor screws off with a torx bolt.
    Im pretty sure that if u remove the valve out into the rim and not back through the front of the rim it could be used again, but it would be a mission.
    this is obviously what they did on my JK back then.
    Previous Jeeps:
  16. #14
    Thanked: 1785
    Quote Originally Posted by rickJK View Post
    Do you maybe have a link to the page where you ordered yours?
  17. #15
    Harrismith
    Thanked: 268
    I got a set lying at my place from Rubi , will check MHZ
  18. #16
    Thanked: 33
    Quote Originally Posted by apviljoen2 View Post
    think it was this one
    https://www.ebay.com/itm/5-NEW-OEM-5...ts=Make%3AJeep
    Previous Jeeps:
  19. #17
    Sep 2015
    Home
    Thanked: 556
    If anyone needs a set of 56029398AB sensors (5x), let me know. I had a brainfart and ordered the wrong ones.
  20. #18
    Thanked: 353
    I have what I believe is a Wrangler mag rim with a TPMS in, if anyone still needs one?
    Si vis pacem, para bellum
  21. #19
    Thanked: 33
    Quote Originally Posted by thabogrobler View Post
    I have 2 x spare for a 2011 Wk2 aswell
    Previous Jeeps:
  22. #20
    Thanked: 44
    I wouldn't mind to take this of your hands if it is still available. I have sent you a PM as well.
    Deon
