Small solar kit
Results 1 to 10 of 10
Thread: Small solar kit
    Richardsbay, KZN
    Thanked: 3875
    Default Small solar kit
    http://www.sunfire.co.za/wp/product/...r-home-system/
    Has anybody used these? Thinking getting one for the two/ three night camps we do. For lighting ( if really needed) and charging cellphones. Sells for 600 bucks.
    Walker Evans, Photographer
    Sep 2011
    Thanked: 17
    Default Re: Small solar kit
    Quote Originally Posted by Riaan van Wyk View Post
    A Friend of mine got one and it works like a charm!! I am getting one as well, at the China shops they sell for R450.00
    Richardsbay, KZN
    Thanked: 3875
    Quote Originally Posted by Lappies View Post
    Thanks Lappies, didn't think of looking at the China Shop to see if they have them here.
    Wilderness
    Thanked: 881
    I have 2 sets similar to that. They work fantastic and take up very little space.
    2011 Isuzu 300d-teq 4x4 d/c
    Thanked: 737
    What batteries do they have, those little alarm lead acids?
    Wilderness
    Thanked: 881
    One has a 6v alarm jobbie and the other has a set of smaller rechargeables.
    Jun 2012
    Thanked: 236
    Riaan,
    I have a non-solar setup that might also be worth considering.
    2 gate-motor batteries, that fit tightly into tiny ammo boxes (name?).
    Each of these has a Lumeno battery buddy on top. This means that you can charge them from a ciggarette lighter port in the vehicle or from 220V wherever. During day-time driving we'll charge the one that we have been using.
    Then an assortment of Lumeno splitter cables, lights, even a remote switch. Honestly I think we recharge the batteries way before it's required, as they last long.
    For USB, you can add a ciggie-port USB adapter.
    You can add pretty much anything that is light load and can work off a cigarette light port. We've used a 12v fan as well in this way.
    Have a look at the Lumeno range; and let me know if you have questions on my setup.
    Make it happen!
    2018 Mobi Lodge
  8. The Following User Says Thank You to Toccata (Roelof) For This Useful Post:
    Richardsbay, KZN
    Thanked: 3875
    Quote Originally Posted by Toccata (Roelof) View Post
    Riaan,
    Thank you Roelof, charging the batteries from the vehicle won't work for me, we drive very little with the car when at the places we frequent. Good advice for those who do though!
    Dec 2006
    Durbanville, Otjiwarongo
    Thanked: 74
    There are a number of similar chinese ones on the market and they all seem pretty much the same. Mine is very similar to the one pictured but different name and they are the bomb. Had ours set up in a remote ablution block with no lights. Way better than brushing your teeth by head lamp light. The phone charger Octopus"is a"bit flimsy though. We used it for about 5 days like that and in the kitchen area. No issues.
    On that note; I also used a bunch of these solar fairy lights. They cast light at about full moon strength around the camp. Made the camp look very pretty and meant you did not need head lamps to walk around.
  11. The Following User Says Thank You to Biggles For This Useful Post:
    Richardsbay, KZN
    Thanked: 3875
    Quote Originally Posted by Biggles View Post
    Thanks Biggles. Will visit the local "China Shop" as soon as I have time - they apparently have a whole range of these type of things, will check out the fairy lights also.
