Fridge freezer specs
Results 1 to 12 of 12
    Jun 2013
    Thanked: 2706
    Default Fridge freezer specs
    Hoping the mods will make this a sticky.
    I thought it would be useful to post up the specs of the different fridge freezers available as a quick reference: Please feel free to add.
    Waeco/Dometic CF 50
    Features:
    - Suitable for solar operation
    - Temperature range: +10 degrees Celsius to -18 degrees Celsius
    - Energy Class: A+
    - CF special electronics with soft start and turbo cooler
    - With priority circuit for 230 volts
    - Detachable lid (front lid mount)
    - Interior light
    - Vertical space for 2-litre bottles
    - Compatible with the car lighter (keeps the temperature set)
    - Intelligent, automatic turbo cooler
    - 3-Stage battery protection, set using the digital display
    - 4-Digit display
    - Display readout in Celsius or Fahrenheit
    - Temperature freely adjustable using the display
    - Display of current interior temperature
    - Status and error indication by 2 separate LED's
    - Memory function saves the last setting
    - Both measures at +5 Degrees C interior temperature
    - CF50 Fridge Insulation Jacket
    - Practical outside pockets
    - Fridge can be secured safely in vehicle
    - Top insulated with aluminium coated polyester
    - Direct access to control
    - Suits DC and AC models
    - Black lid and base and silver sides
    - Supplied with: Removable Wire basket, detachable carry handles
    Specifications:
    - AC: 100 - 240 volts
    - DC: 12/24 volts
    - 0.56 Ah/h at +20 Degrees C ambient temperature
    - 0.71 Ah/h at +32 Degrees C ambient temperature
    - Capacity: 47L (includes 8 litres for fresh food)
    - Power input: Approximately 45 watts
    - Material: Cabinet: PP
    - Material: Lid: PE
    - Dimensions: 63cm x 36cm x 48cm
    - Weight: 23kg
    - Warranty: 36 Months
    Stranger
    BMW R1200R
  2. The Following 2 Users Say Thank You to Stranger For This Useful Post:
    Jun 2013
    Thanked: 2706
    Default Re: Fridge freezer specs
    Snomaster 40L 12/220 volt Dual Camping Fridge
    Features:
    - 32.5ltr fridge with temperature setting 5 , 0 or -5deg
    - 7.5ltr freezer with a temperature setting of -12 to -22deg
    - 55mm insulation Stainless steel casing
    - Digital control
    - Remote control
    - Travel bag & baskets included
    Specifications:
    - Dimensions: 364cm x 650cm x 550cm
    - Weight: 23.50kg
    - Colour: Silver
    Stranger
    BMW R1200R
    Jun 2013
    Thanked: 2706
    NL 50 Twin Weekender Refrigerator & Freezer
    Dual Compartment Fridge/Freezer
    Danfoss designed BD35F Compressor
    Digital Temperature Controller
    Thermostat range 20ºC to -12ºC
    42mm High density polyurethane insulation
    Battery protection
    Built in battery monitor
    Internal LED Light
    Stainless steel Latches
    3 x Basket – (optional)
    Protection Cover – (optional)
    Base Mounting plate – (optional)
    3 Year Warranty
    38.3L (fridge) & 11.0L (freezer)
    9.6-31Vdc & 100-240Vac
    3 x baskets (Optional)
    710 x 385 x 506mm (Closed)
    710 x 385 x 845mm (Open)
    Weight – 24.0 kg
    Stranger
    BMW R1200R
  5. The Following User Says Thank You to Stranger For This Useful Post:
    Jun 2013
    Thanked: 2706
    Snomaster Single Door
    220/12volt fridge or freezer
    Powder coated cabinet
    Stainless steel hinges, locks and handles
    Lid open alarm
    Removable Lid
    2 Internal baskets included
    Temp Variance: -22⁰C to 10⁰C
    Digital thermostat
    66watt Snomaster compressor
    Internal power supply
    Polyurethane insulation
    Transit bag included
    5 amps on high speed, 2.5 amps on low speed
    Voltage Cut out pre-set 10.8 Amps
    Bottle opener
    Hinges, locks and handles are S/steel to enhances durability
    55mm insulation suitable for higher ambient conditions
    Transit bag and baskets are included in price
    Wireless monitor allows you to monitor your unit on long trips
    Larger Compressor allows for better cooling efficiency over a 24hour cycle
    7 year Warranty on Snomaster 66 Watt Compressor
    Size: 364 W x 640/680 D x 515 H
    Capacity: 42 Litres
    Weight: 23.5kg
    Wireless thermostat Monitor supplied
    Stranger
    BMW R1200R
    Mar 2017
    Okahandja
    Thanked: 751
    Thanks for this. Very usefull for me.
  8. The Following 2 Users Say Thank You to Erwin Schimper For This Useful Post:
  9. #6
    Jun 2013
    Thanked: 2706
    40L ENGEL
    The Engel Series II now has an interior LED light. This unit has all the features, efficiency and reliability you have come to expect from Engel. A rugged steel casing, steel lid and steel handles which double as tie down points. New longer battery life digital temperature read out built in.
    Supplied with both cords, the 12 volt cord that plugs straight into your vehicle’s cigarette socket and the 240 volt lead with three pin plug, Auto switching as standard removes the need for the user to switch power sources manually. Three Year Warranty. Replacement Cords: 12 Volt cord, 240 Volt cord. Please note that the external dimensions do not include the carry handles if fitted they increase the width by 50 mm each end.
    Weight 24 kg
    Dimensions 508 × 648 × 365 mm
    Stranger
    BMW R1200R
  10. #7
    Jun 2013
    Thanked: 2706
    40L ENGEL COMBI
    Engel are proud to announce it has added an exciting new model to its range of Portable Fridge / Freezers, the Combi. This model is the new combination Fridge and Freezer, with added features including the removable internal divider and thermostatically controlled fan. The MT45FCP gives three versatile configurations;
    Option 1. Freezer 17 Litres / Fridge 23 litres (total 39 Litres)
    Option 2. Freezer 22 litres / Fridge 16 Litres (total 39 Litres)
    Option 3. Refrigerator Only (Divider removed total 40 Litres)
    This model also includes the user friendly digital control with LED display as featured in the 50th Anniversary model, along with built in battery monitor.We have designed this new model in the industry standard Engel 40 Litre cabinet to ensure its compatibility with the current range of 40 Litre accessories.
    Stranger
    BMW R1200R
  11. #8
    Jun 2013
    Thanked: 2706
    National Luna NLR60 60l Fridge
    Overview
    A combination of 42mm and 60mm high-performance insulation allows for an extremely compact true fridge and freezer combination with independent thermostats. Ultimate versatility provides the choice between twin fridge, twin freezer or fridge + freezer.
    Features
    Most compact true Fridge and Freezer combination.
    Separate control for each compartment.
    Balance of 42mm and 60mm high-performance insulation.
    Stainless Steel body
    High-strength handles & locking latches.
    Internal LED light.
    Up to 5 baskets.
    3-level selectable battery protection.
    12Vdc, 24Vdc , 100-240Vac operation
    Specifications
    Actual volume: 24.2 litres (freezer) , 34.9 litres (fridge)
    External dimensions 750mm (W) x 425mm (D) x 535mm (H) (913mm with lid raised) Weight: 28.2kg
    Material Rigidised stainless steel exterior with smooth aluminium interior
    Baskets Up to 5 baskets optional
    Power supply: 12 / 24V DC, 100V - 240V AC
    Power consumption * 12V - 2.5Amps average running current. 1.53 - 2.26 amp/hour average power draw
    Average power consumption is measured with a setting of -10 in ambient temperatures of 32 and 43 degrees Celsius respectively
    Stranger
    BMW R1200R
  12. #9
    Jun 2013
    Thanked: 2706
    Bismarck B60L 60L Fridge Freezer
    Stainless Steel
    Outer Dimensions: (W x D x H) 66cm x 53cm x 57cm
    Inner Dimensions: (W x D x H) 49cm x 36cm x 41cm (minus compressor hump space +- 18cm H x 19cm W)
    Wall thickness = 65mm
    Weight: 20 kg
    DC 12V / 24V Power consumption: 50W
    AC voltage: AC 100 -120V / 220 - 240V / 50-60Hz (via supplied external adaptor)
    Temp range from -18 Deg C to 10 Deg C
    Refrigerant: R134a (safe for mobile use – non flammable)
    High/Low Speed mode (faster cooling but at higher power consumption – for e.g. when running on AC mains, or just after loading warm food, or just before having to go without power for a while)
    Adjustable battery protection cut-out setting (3 levels)
    Digital temperature Control & Display
    Strong carry handles & latches
    LED interior light
    12 Month Guarantee
    Stranger
    BMW R1200R
  13. #10
    Jun 2013
    Thanked: 2706
    Snomaster 60L Camping Fridge freezer BD/C-60D
    Features
    Dual 220/12v fridge/freezer
    Stainless steel cabinet
    Lid open Alarm
    3 Internal Baskets included.
    Temp. variance -22C - 10C
    Digital thermostat
    Interchangeable compartment settings
    66w Snomaster compressor
    5 Amps on high speed, 2.5 amps on low speed
    Voltage cut out can be set between 10 & 11.5 volts
    Benefits
    Stainless steel cabinet, hinges and handles enhances durability
    Stainless steel cabinet allow the polyurethane to be injected under high pressure, giving better insulation.
    60mm insulation suitable for higher ambient conditions.
    Wireless monitor allow you to monitor your temperature on long trips
    Larger compressor allows for better cooling efficiency over 24 hour cycle
    7 Year warranty on Snomaster 66w compressor
    Size
    715(W) x 450(D) x 525(H)
    Weight
    28.5kg
    Capacity
    24L / 28L Split
    Stranger
    BMW R1200R
  14. The Following User Says Thank You to Stranger For This Useful Post:
  15. #11
    Polokwane
    Thanked: 517
  16. The Following User Says Thank You to DC Polokwane For This Useful Post:
  17. #12
    Thanked: 110
    One of the most needed specs would be the power consumption but in most cases that is not supplied.
    Gerrit Laubscher
    Angola sempre
