Three point screwdriver
Results 1 to 20 of 24
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Default Three point screwdriver
    Does anyone know of a place (preferably Centurion/Gauteng area) that sells three-pronged/three-point screw drivers or bits?
    It basically looks like a philips bit, but only has three prongs.
    Jul 2013
    cape town
    Thanked: 630
    Default Re: Three point screwdriver
    I think you are referring to a tri wing screwdriver.
    I know they are advertised on bid or buy.
    I assume you want to mess around with a gaming console
  3. The Following User Says Thank You to Ocin For This Useful Post:
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Quote Originally Posted by Ocin View Post
    Thank you for the feedback. At least I now know what ist called, so will be easier to track them down.
    Its actually for a Ducati. I want to change my handlebar setup a little bit, but the controls have these silly crews, and none of the local tool/hardware shops have a clue what I'm talking about. I don't want to go to Ducati, if I don't have to...
    Apr 2012
    Bela Bela
    Thanked: 253
Name:	DSC_0329 small.jpg
    Not sure what size you need but hardware stores such as Builders, Chamberlains etc sell sets of bits that includes these plus flat, torx, posi-drive, hex and many others.
    Pete
    ADVENTURE BEFORE DEMENTIA
  6. The Following User Says Thank You to petewill For This Useful Post:
    Mar 2018
    Randfontein
    Thanked: 144
    check your local "China town" type shops. They always have weird bits and bobs
    Langebaan
    Thanked: 17
    I am using one of these. It has a range of Phillips, flat, torx, tri, Allen bits in various sizes.
    I suppose there will be sets with bigger tips as well.
    https://www.livecopper.co.za/product...t-set-45-piece
  9. The Following User Says Thank You to rian skip For This Useful Post:
  10. #7
    Thanked: 316
    Adendorf in Centurion... www.tooltime.co.za
    2017 Mitsubishi Triton 2.4 D/C 4X4 Auto Diesel
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    My ULTIMATE dual battery box
  11. #8
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Quote Originally Posted by SinWolf View Post
    Thank you.
    I phoned them, they said they donít have it; either in sets or single bits.
    Perhaps Iíll should just go there and check.
  12. #9
    Apr 2012
    Bela Bela
    Thanked: 253
    Pete
  13. #10
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Quote Originally Posted by petewill View Post
    Thank you Pete,
    I forgot about tools4wood...
  14. #11
    Thanked: 940
    Just take this into account for those sets of hexagonal bits...
    If you need to get a flat, Philips, Pozidriv and or hex driver into a recessed opening for the screw, the detachable bit (actually the holder,) may be too short or fat to fit into the opening to get the screw out.
    I will still need to by a separate Torx T10 driver for my job.
  15. The Following User Says Thank You to MarcR For This Useful Post:
  16. #12
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Quote Originally Posted by MarcR View Post
    Good point. I cannot remember how deep they are recessed. I'll confirm before I buy anything.
  17. #13
    Dec 2006
    Thanked: 7
    Depending on size you require , you can also try Communica in Samrand, they have a fair amount of funny bits and drivers
  18. #14
    Jan 2007
    Tamboerskloof, Cape Town
    Thanked: 136
    Post Re: Three point screwdriver
    Have you tried Christensen Tools? Apparently their JHB branch is in Jeppestown: https://christensen.co.za/contact
    There is only one...
  19. #15
    Dec 2014
    Thanked: 1916
    The Snap-On guys that drive around will likely have them, too.
    Call them and ask for the closest dealer and give him a shout.
    Wurth should also have them.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  20. #16
    Thanked: 200
    I have a few....pop me a PM and I can come around to your place, you can use them and I leave with the bits?
    Si vis pacem, para bellum
  21. #17
    Apr 2016
    Thanked: 64
    These screws are deliberately unique to stop people opening the device.
    I can often undo them with a smaller flat screwdriver that fits into one of the wings (not good for the screwdriver!)
    Failing that: drill the head off or use an easyout to remove the screw.
    Replace the screw with one that has a recognised head!
  22. #18
    La Mercy
    Thanked: 14
    If it is a triwing ,check RS components Ltd, they have it price depends on size.
  23. #19
    Thanked: 732
    As far as I know, these heads are used on TP screws (Thermo plastic) which assemble plastic casings/housings for radios, toys, etc.. So maybe try a radio/e;ectronics repair shop as well.
    (TP threads are similar to self tapping threads, just that the flange is wider and thinner (like a blade shaped thread, rather than the V shape). This is so that the thread can cut its own thread into plastic by displacing as little plastic as possible.
  24. #20
    Thanked: 732
    Just a thought, why not grind down an allen key to match the head. Try not to overheat the tip and soften it.
