Can I drive on 4H on tarred roads?
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 46
    Default Can I drive on 4H on tarred roads?
    Hi guys,
    Been told can't do it with the Jimny but can I with the pajero?
    White River
    Thanked: 875
    Default Re: Can I drive on 4H on tarred roads?
    4H makes use of the central diff lock, so no, you'll get wind up and break something.
    2011 JK Wrangler Rubicon 3.8
  3. The Following 2 Users Say Thank You to TonyP For This Useful Post:
    Barberton
    Thanked: 1106
    Quote Originally Posted by KPakkiri View Post
    Hi guys,
    Yes, the Pajero has a centre diff. In 4H it is open and you can drive like that on tar.
    4HLc is the next option up and that is a locked centre diff. In this setting you will get wind-up on any grippy surface and then damage is likely to occur somewhere if you try hard enough.
  5. The Following 2 Users Say Thank You to RoelfleRoux For This Useful Post:
    Jan 2017
    Rustenburg
    Thanked: 975
    Hi guys,
    With the oajero it is fine. As long as you don't put it in Hlc
    Nov 2012
    Thanked: 976
    My pajero is permanently in 4H
    Choose life
  8. The Following User Says Thank You to Coenoes For This Useful Post:
  9. #6
    Richardsbay, KZN
    Thanked: 12020
    Quote Originally Posted by Coenoes View Post
    Same here.
    Walker Evans, Photographer
  10. #7
    Magaliesburg
    Thanked: 16
    In my Triton it is always in 4H.
    2018 Mitsubishi Triton Extreme Auto
  11. #8
    Waterfall
    Thanked: 614
    4HLC is equivalent to 4H on the Jimny, 4H is equivalent to an All Wheel drive car, so no problem driving like that 24/7.
    Any minority that advocates for gun control is either wilfully ignorant, or has never opened a history book.
    The problem with collective punishment - is that sooner or later you're part of the collective.
  12. #9
    Thanked: 601
    Do you have a setting for 2H in your paj? If you have, why would you like to drive in 4H on tarred roads?
    If you don't have 2H then your vehicle is an all time 4x4 which many of the SUV's are. Meaning it usually sends more power to the back wheels and a 'smart' centre diff prevents wind-up.
    Pieter
  13. #10
    Thanked: 129
    Quote Originally Posted by bones View Post
    Do you have a setting for 2H in your paj? If you have, why would you like to drive in 4H on tarred roads?.
    It sometimes happens that you are driving very steep gravel mountain pass where the worst parts are paved for better traction and to protect the road and it sometimes incudes bends as well.
    Carlisleshoekspruit Pass near Rhodes comes to mind.
    I also once had to drive up a mountain to a communications tower which had a very steep winding road with a concrete surface all the way. At the start there is a sign warning you to use only 4x4 low range for safety reasons.
  14. #11
    Richardsbay, KZN
    Thanked: 12020
    The Super Select System has a 2H setting yes. The 4H affords extra traction on tar especially in the wet.
  15. The Following 3 Users Say Thank You to Riaan van Wyk For This Useful Post:
  16. #12
    White River
    Thanked: 875
    ooops, I was unaware that the Paj was an all wheel drive vehicle. Sorry for the misleading information.
  17. The Following User Says Thank You to TonyP For This Useful Post:
  18. #13
    Richardsbay, KZN
    Thanked: 12020
  19. #14
    Richardsbay, KZN
    Thanked: 12020
    OP, I seem to recall you have a Gen2 Pajero? As far as I know they were fitted with the " Easy Select" system which doesn't allow driving on tar in 4H, might be wrong though.
  20. #15
    Barberton
    Thanked: 1106
    Quote Originally Posted by Riaan van Wyk View Post
    My first Pajero (3.0V6 Gen2) was back in the early 90's and it was already running the Super Select with centre diff.
  21. The Following User Says Thank You to RoelfleRoux For This Useful Post:
  22. #16
    Jan 2016
    Thanked: 1137
    Everything's already been said, but I just want to add some personal experience. We were on holiday in Mpumalanga this week and conditions were often wet and slippery. I went hiking at Mount Sheba on Wednesday (stunning...) and the drive up Robber's Pass proved quite entertaining. I didn't engage 4H and the combination of sharp, slippery bends, swb and lots of torque under power in 2nd gear caused me to spin out, fortunately with no drama. I hooked 4H and it clawed the road like a cat. I only switched back to 2H on Friday by the time we reached dry conditions at Alzu on the N4. There wasn't a noticeable difference in fuel consumption. I'm going to use 4H much more often in less than perfect conditions on tar from now on!
    2001 Gen 3 Pajero swb 3.2 Di-D
  23. The Following 4 Users Say Thank You to Jens78 For This Useful Post:
  24. #17
    Richardsbay, KZN
    Thanked: 12020
    Roelf thanks. Daft moment I had, SS was launched in 1991 and not 2001 as my foggy brain told me this morning.
  25. #18
    Barberton
    Thanked: 1106
    Hehe...
    We all know what Chris Christoffersen had to say about Sunday mornings
  26. #19
    Richardsbay, KZN
    Thanked: 12020
    Hehe...
    You understand then
  27. #20
    Thanked: 601
    Interesting system. So then you have the option to drive 2H and 4H open centre diff as normal all time 4x4's, which is fine.
    With my bakkie if you select 4H centre diff automatically locks and I will use this only in extreme situations for a short period of time, as viertrek said, on tar.
    Pieter
