Results 1 to 14 of 14
    Mar 2017
    Grahamstown
    Default Land Rover Series 3 Geabox Identification
    Morning Everyone
    Can somebody please help my to identify this gearbox?
    It is my 1984? Land Rover Series 3S (with ADE236 engine).
ID:	518893   Click image for larger version.
ID:	518894   Click image for larger version.
    cape Town - 0624206806
    Thanked: 524
    Santana box.
    Very good full synchro box but you donít get spares for them.
    Thats a Series 3S (called an R6 here) the diesel model is pretty scarce (has low ratio diffs)
    Mar 2017
    Grahamstown
    Default Re: Land Rover Series 3 Geabox Identification
    Thanks GaryFrank
    I thought as much, but wan't sure.
    Would I be able to put one of the 5-speed boxes into this monster? If so, which one would be able to handle the torque?
    I would really like a bit more speed (or at least lower revs at 100Km/H).
    Thanked: 524
    The LT77 is a good option (early Rangy)
    The LT85 has got very short gears (1st & 2nd) itís also a Santana box
    The R380 is strongest but pricy
    Problem is that they are all way too long and your gearshift is gonna be hard up against the seat box
    Thanked: 524
    Keep her original (canít believe I said that)
    Mar 2017
    Grahamstown
    Hi GaryFrank
    I would like to keep her as original as possible, but if I can't get spares for this box, then I
    need to start thinking about other options.
    Just for interest sake, would a Fairy overdrive fit on this box? Would it be worth it if I can find one?
    Thanked: 524
    There was a Toro overdrive for the Santana box, dunno if itís the same as the Fairy....(R8k second hand )
    You should have the lower ratio diffs if sheís original - 3,54 instead of 4,7...
    Those boxes pop up on gumtree every now and then....R5k
    May 2021
    Uitenhage
    I have a Series 3, 82í model, 2.25 diesel and first gear is jumping out when it isn't under load. I am planning to fix it but found someone selling a spare box. Can't find the ID nr on spare box. Will it fitClick image for larger version.
ID:	615135Click image for larger version.
    Thanked: 524
    There should be a serial number of sorts on the selector cover above the front prop drive housing. This will tell you everything about the box.
    The only real difference between boxes is the bell housing being +/- 10mm smaller on the 2.6 6 pot.
    Obviously not comparing S2 (synchro on 3/4 only, clutch slave vertical on the drivers side) and the S3 with synchoís on 1/2 and 3/4, clutch slave horizontal on the passengers side
    Thanked: 524
    1st gear jumping out is normally the brass bushing that 1st & 2nd share. The bushing is pinned onto the main shaft and seizes into the gear if your oil level is low. (Bush breaks in half)
    The replacement bush is a 2 piece affair. Not too expensive..... but you have to completely strip the box to replace it.
    Thanked: 524
    Duplicate
    May 2021
    Uitenhage
    GaryFrank
    Thank you for the clarity on both box and ID. What shop would you recommend for finding spares on the old lady? Eastern Cape has slim pickings
    Thanked: 524
    All the best suppliers are down here in Cape Town
    You can try David Kinghorn-JLR 4x4
    071 8801 499
    Heís my supplier (and knows more about Landys)
    Dec 2014
    Thanked: 2989
    Plus 1 for David!!
    He'll courier to you, no problem, too.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
